Old Sep 04, 2012, 09:23 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
What is the status on the V2 AG550? Status on the new servos? I just found out I need one sooner than later....
MCrites is offline Find More Posts by MCrites
Old Sep 04, 2012, 09:32 AM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
my goal is to ship 10 units tomorrow. (thursday at the latest) talk to gary on friday or saturday. this batch will go fast.
askman is offline Find More Posts by askman
Old Sep 04, 2012, 09:39 AM
MCrites is offline
Joined Jan 2012
Are any of the 10 available or presold? These aren't wit the new custom made servos correct?
I'll be using a GoPro but plan on a Nex or similar in the future... which yoke do you recommend?
Old Sep 04, 2012, 09:44 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
we do not presell. it will come with nex5 gimbal (4.7" width) and they will come with external pot and modified servos on most of them. I have like 8 servos modified, and waiting for the rest from gary. only one yoke choice unless you want a gopro version, which is available via special order. if people want larger yoke, they will have to wait for ag700
Old Sep 04, 2012, 09:51 AM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
As soon as Andrey ships them, I'll put them up on the site, and make an announcement here. The new standard configuration will be with the modified BLS950 on tilt, the external pot, a 2.8:1 tilt ratio and the new adjustable height camera tray. Other v2.0 changes include the alloy roll assembly and the new CF-based Isolated Mounting System (IMS). An option will now be offered to include a HoverFly Gimbal board.
David and John: Nice videos. . Where are you guys getting the instrumental music from?
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Sep 04, 2012, 09:59 AM
MCrites is offline
Joined Jan 2012
Awesome! My memory is correct in thinking I can mount the GoPro on the nex5 yoke with a tripod screw... right?
EDIT** You got the HF thing setup? Congrats!... damnit, might have to do that as well since it's so convenient.
Old Sep 04, 2012, 10:06 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
well, you can, but you will have to drop the camera mounting tray plate a lot to get the lens lined up and it may not tilt fully with that deep a base. .
Old Sep 04, 2012, 10:24 AM
MCrites is offline
Joined Jan 2012
Ahh ok... sounds like the time to review my camera/lens options. If I did want a GoPro yoke, what is the approx wait time/cost over the nex5?
Old Sep 04, 2012, 11:04 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
if you mount the gopro without case, it won't be a problem, but just the case adapter is very tall. I can do a gopro yoke. I can do one easy enough with this batch. . just pm gary and he can quote you a price on gopro yoke .
Old Sep 04, 2012, 11:09 AM
MCrites is offline
Joined Jan 2012
If I can run the GoPro without a clear protective case on the nex5 yoke and there isn't a problem I would really rather do that. I am considering the nex5 as my next camera anyway but with the gimbal, possible HF Gimbal Controller I should probably probably try to cut costs this month. Would be win/win because I could hold off on the Nex for another month or two and you don't have to dust off the GoPro yoke drawings
Old Sep 04, 2012, 11:52 AM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
I'm still down in SD, but when I get home this afternoon, I'll try and do a quick fit test with the GoPro in its protective case, and with the tripod mount. Lowering the tray won't be an issue, but if you lower it too much, like Andrey says, it will hit the back of the yoke.
A big part of the problem is that GoPro tripod mount is pretty tall. I'm thinking Andrey maybe could do a small, shorter adapter plate, similar to what we use on the GP iso-only mount for the F450. I'll check this out later.
-- Gary
Old Sep 04, 2012, 01:49 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
that 550 gimbal is looking quite awesome!
Adidas4275 is offline Find More Posts by Adidas4275
Old Sep 04, 2012, 02:07 PM
digitalCAM is offline
Find More Posts by digitalCAM
John
United States, WA, Mason
Joined Apr 2011
Originally Posted by Wingbreaker View Post
i think thats the best results ive seen from this thing. only issue is a weird jello wobble on transitions when I look at it full screen. other than that might be perfect.
Wing, thanks for the kind words. I'm not sure what you mean tho, when you say "on transitions" -- There were no cuts or transitions, it was just uninterrupted flight. Do you mean "transition" in some other context then video editing? Do you mean "to transition from going one direction to another" ?? I'll look and see if I can tell what you are seeing. Maybe I need to be aware of being smoother on changing directions. -- thanks, JOHN
digitalCAM is offline Find More Posts by digitalCAM
Old Sep 04, 2012, 02:13 PM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
movement in flight, i think that is normal though. looks good. I noticed wkm gimbal control likes slow steady left right forward back any combinations or sudden movement makes it wobble. what is your set-up? do you have the double grommet? mine is a bit more wobbly than this.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Sep 04, 2012, 02:14 PM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
does the askman gimbal have pots on both axis? is that pot just a replacement for the pot in the servo or does it connect to the gimbal controller?
Xnaron is offline Find More Posts by Xnaron
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 08:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
