This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Apr 11, 2012, 08:24 PM
1moparman1 is online now
Find More Posts by 1moparman1
chillax! It's only a Hobby
1moparman1's Avatar
United States, CA, Millbrae
Joined Apr 2011
Originally Posted by Herb View Post
Here's the first set of fixes to the CMP L-39:
Thrust angle adjustment. I am using the fiberglass ducting that is included in the kit to make a "duct straightening" tailcone, with zero angle of incidence with respect to the fuselage:
Herb, did you just tape that on the rear of the tail??
i see mine has the same, the end is pointing up
1moparman1 is online now Find More Posts by 1moparman1
Latest blog entry: Hk cri cri
Old Apr 12, 2012, 10:56 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
No I glued the fiberglass correction exhaust with epoxy. I sanded both sides thoroughly before gluing them together - I don't want this thing to fly off in flight.
Hopefully this will correct most of the thrust angle issues.
The problem is more serious for 90mm fans that have a larger outer diameter (eg haoye or cs), because the fan then ends up sitting lower in the fuse. Unless of course you entirely redo the ply fan mount (which I did not).
Herb is offline Find More Posts by Herb
Old Apr 12, 2012, 02:09 PM
1moparman1's Avatar
Joined Apr 2011
Thanks, i see that now
Old Apr 13, 2012, 12:34 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Generally I think it might be a good idea on the L-39 not to cut the thrust tube too short until you've had the first flight
That way you can modify things a bit more easily. I am glad I did so on mine ...
Old Apr 13, 2012, 03:33 PM
1moparman1's Avatar
Joined Apr 2011
i was lucky, i did not cut it too much yet
i will fly it like that first, i am also doing 4000 8s up front that will help with the nose high flying
Old Apr 15, 2012, 01:12 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Well I flew her again yesterday (15mph winds ) and she still needs downthrust.
I programmed some throttle-to-elevator mixing now, we'll see if that does the trick. About five extra clicks of down at full throttle ...
I snapped the flimsy plastic steering servo arm off yesterday, so that had to be replaced.
Old Apr 15, 2012, 09:41 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Flew her again today, three times
I have now about five clicks of down mixed into the throttle, and she flies a LOT better.
I flew her on 8S and she flew well, but still a bit pitch sensitive (slightly rearward CG), then on 9S and she was slightly faster - but now the slightly forward CG (+3 oz in batt weight) makes her track nicely.
She really gains speed when she flies straight and level, faster than the T-45 for roughly the same amount of power. I did dremel out the intakes quite a bit and that seems to "ram" more air into the fan now.
I think I will stick with 9S 3000's from now on, and get rid of the 3oz of lead in the nose.
Red line (ca 75mm) is the farthest you want to go back on the CG. It flies but it is still quite pitch sensitive. Blue tape line is CMP wrong CG.
Old Apr 15, 2012, 11:28 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
great build and mods herb!! i love the flap hinge mod. cool struts too. do they finnaly sell them? lol nitrplanes never seems to have had them in stock in the past.
corsair nut is offline Find More Posts by corsair nut
Old Apr 17, 2012, 12:40 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I got the struts from scaleflying.com , NP never had them
They are ok but do have too much play imo, one of the steel clips flew off on a landing (or takeoff). I hope the struts won't disintegrate too soon ...
CMP did a really bad job on that wing & retract mounts , they should have known better The mains mounts are a joke.
Old Apr 20, 2012, 11:17 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The struts and retracts are now on sale at HK as well (not for long ) for $120
http://www.hobbyking.com/hobbyking/s...dProduct=19949
Old Apr 20, 2012, 10:37 PM
mavdriver is offline
Find More Posts by mavdriver
mavdriver's Avatar
United States, CA, Apple Valley
Joined May 2002
Nice is to late though they are out for now i want them bad hopefully they will be back in stock soon
mavdriver is offline Find More Posts by mavdriver
Old Apr 20, 2012, 10:42 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It's a nice flier - once all the various issues (wrong CG, weak main mounts, upthrust, flimsy struts, tailheavy etc ) have been sorted out
Short video from today :
Aero L-39 Albatros 90mm EDF 1200mm by CMP flyby (0 min 48 sec)
Old Apr 20, 2012, 10:45 PM
mavdriver's Avatar
Joined May 2002
Nice Herb congrats
Old Apr 25, 2012, 02:17 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks ... the 9S pack helps with the CG a bit but the L-39 still feels a bit tailheavy.
Old Apr 25, 2012, 02:25 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Have been working now on a way to secure the canopy.
I found that the pilots (esp. the front one) protrude too much into the fuselage space, which is a problem as the batteries take up a lot of space.
So I removed the two pilots with their little individual cockpit tubs; they can be inserted later for static display, when the battery is out of the way.
To secure the cockpit, I am using a ply tongue at the front, and a spring-loaded canopy latch at the back. That way there's no unsightly stuff showing up.
The canopy assembly has to be made rigid, with a good fit so it won't fly off. I use jb-weld since it is is very rigid when it dries (I learned this from keith sparks).
Now is also a good time to do some extra detailing.
Discussion L-39 90mm EDF rctoday Electric Ducted Fan Jet Talk 6 Dec 09, 2011 05:25 PM
Wanted WANTED A NICE 90MM EDF KIT like the red/wht HET L-39 I have a TJ100 PNP I'll trade. mechengineer03 Aircraft - Electric - Jets (FS/W) 0 Jul 23, 2011 06:44 PM
For Sale K&A L-39 Albatros EDF kit richardc951 Aircraft - Electric - Jets (FS/W) 0 Jun 01, 2011 07:16 PM
Wanted L-39 Savex Albatros 90mm EDF carl rich Aircraft - Electric - Jets (FS/W) 1 Oct 17, 2007 08:23 PM
