This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Dec 27, 2012, 08:23 PM
captain MoMo is offline
Find More Posts by captain MoMo
Mach One
captain MoMo's Avatar
Joined Apr 2011
Originally Posted by 1moparman1 View Post
If you go back on this blog,you will see how Herb did his. Which is how i did mine Works great
10-4
captain MoMo is offline Find More Posts by captain MoMo
Old Jan 16, 2013, 04:32 AM
urrl is online now
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Some touch N go flybys
L-59 Touch N go tries (1 min 57 sec)
urrl is online now Find More Posts by urrl
Old Jan 16, 2013, 05:25 AM
Mach One
Joined Apr 2011
Originally Posted by urrl View Post
Nice urrl
Old Jan 16, 2013, 10:24 AM
urrl is online now
urrl's Avatar
Joined Aug 2010
Thanks. Here's some more I did this morning.
L-59 Better Touch N Go Landings (1 min 57 sec)
Old Jan 16, 2013, 02:29 PM
1moparman1 is offline
Find More Posts by 1moparman1
chillax! It's only a Hobby
1moparman1's Avatar
United States, CA, Millbrae
Joined Apr 2011
http://youtu.be/3qebWk2dVnM
urrl what kind of camera is that?
1moparman1 is offline Find More Posts by 1moparman1
Latest blog entry: Hk cri cri
Old Jan 18, 2013, 08:45 AM
urrl is online now
urrl's Avatar
Joined Aug 2010
http://www.hobbyking.com/hobbyking/s..._5MP_CMOS.html
Old Jan 25, 2013, 10:04 AM
urrl is online now
urrl's Avatar
Joined Aug 2010
The wing tanks seem to take away from the flight maneuverability with a 6S system. It felt like I was lugging the jet around, however it wasn't too bad. Scraped the tanks on landing though due to the low landing gear.
L-59 with wing tanks (0 min 0 sec)
Old Jan 26, 2013, 12:09 AM
Mach One
Joined Apr 2011
Urrl - ho wdo you mount your cameras?
Old Jan 26, 2013, 12:24 PM
urrl is online now
urrl's Avatar
Joined Aug 2010
With velcro on the tail and on the camera.
Old Jan 26, 2013, 01:40 PM
1moparman1's Avatar
Joined Apr 2011
I got one last week but can't get it to work
Just go to blue light and stop working from there
Old Jan 31, 2013, 06:29 PM
urrl is online now
urrl's Avatar
Joined Aug 2010
I'm not happy with regular bulbs; I can see the Xenons during the day easily.
I found a solution to strobe light interference; it is all digital servos. Ground test worked fine. Weather permitting I hope to fly tomorrow. Here is a short clip. There is absolutely no servo twitching with digital servos.
L-59 wing strobe lighting (0 min 35 sec)
The new digital elevator servos movements were acting like ailerons so I went into the tx programming and set one of the elevator servos on AUX3 and reversed the slope, then change the slope to a lesser incline till it matched the movement of the other elevator servo. Looks like buying a servo reverser was not necessary.
I used needle nose pliers to bend off the metal ears off of these all metal digital servos to make them fit.
Love these servos; the action is butter smooth and they are practically noiseless when they move.
http://www.hobbyking.com/hobbyking/s...10sec_23g.html
Old Feb 01, 2013, 11:12 AM
urrl is online now
urrl's Avatar
Joined Aug 2010
I purchased a 4 cell battery box for AAA sized batteries and connected the stobe modules in parallel to it. The box has an on-off switch and makes things much more convenient since I do not have to use a separate 3.7 LiPo for each strobe module.
L-59 6 Volt Battery Box for Strobe Lights (0 min 46 sec)
Here is a link:
http://www.radioshack.com/product/in...4&locale=en_US
Old Feb 16, 2013, 07:32 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Loaded
jimmy34256 is offline Find More Posts by jimmy34256
Old Mar 30, 2013, 06:22 PM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
My new HK L-59 is ready for maiden but I have some concerns and in need of some advice.
The all up weight is 4200g (with 100g extra weight in the nose for CG). The trust is 1700g.
Will it have enough power ?
The setup is :
Motor
http://www.nitroplanes.com/96m812-3674-1700kv.html
Fan
http://edfhobbies.com/index.php?rout...&product_id=83
2x 4S lipos (8S) compact zippy 4500mah 35C
120 ICE2 HV esc
Digital metal gear HK servos
RC Lander retracts
No white fuel tanks added , only the red ones in the end of each wing.
Current draw - 120 Amps, drops to 112 after a few seconds. About 3300Watts.
Is my all up weight normal ? is the thrust normal ? What is your AUW and thrust ?
sharonx is offline Find More Posts by sharonx
Old Mar 31, 2013, 12:18 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi Sharon,
Maybe I'll write a bit more tomorrow when I have more time ... but 3200 W seems plenty. Yes your weight is a bit on the high side (mine is posted somewhere above, I think; the lander retracts are heavy from what I recall) - but with a nice smooth asphalt runway you should be ok.
Your static thrust seems a bit low, but perhaps it was not measured right.
http://www.ecalc.ch/fancalc.htm
You have a very goof fan with a motor I don't know ... maybe the motor is ok.
Make sure you check the CG with what I list on the first page of this thread !
Herb is offline Find More Posts by Herb
Discussion L-39 90mm EDF rctoday Electric Ducted Fan Jet Talk 6 Dec 09, 2011 05:25 PM
Wanted WANTED A NICE 90MM EDF KIT like the red/wht HET L-39 I have a TJ100 PNP I'll trade. mechengineer03 Aircraft - Electric - Jets (FS/W) 0 Jul 23, 2011 06:44 PM
For Sale K&A L-39 Albatros EDF kit richardc951 Aircraft - Electric - Jets (FS/W) 0 Jun 01, 2011 07:16 PM
Wanted L-39 Savex Albatros 90mm EDF carl rich Aircraft - Electric - Jets (FS/W) 1 Oct 17, 2007 08:23 PM
