This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Oct 19, 2012, 01:30 PM
1moparman1 is online now
Find More Posts by 1moparman1
chillax! It's only a Hobby
1moparman1's Avatar
United States, CA, Millbrae
Joined Apr 2011
cool
just order one of those retract
1moparman1 is online now Find More Posts by 1moparman1
Latest blog entry: Hk cri cri
Old Oct 21, 2012, 04:56 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Lmeano_from_MO View Post
Herb,
Follow up on my recent order from Nitro’s ....and I got it yesterday in great shape. .. Do you mind if I post my mods here on your build log or should I move on to the HK L-59 build forum?
Jeff
Hi Jeff , glad everything worked out in the end !
As I said it is a nice kit (esp. in view of the price) but the packaging leaves a lot to be desired.
We are looking forward to seeing lots of pics of your build here !
Herb is offline Find More Posts by Herb
Old Oct 24, 2012, 01:43 PM
VladimirVRN is offline
Find More Posts by VladimirVRN
VladimirVRN's Avatar
Russia, Voronezhskaya oblast, Voronezh
Joined Dec 2010
Hello from Voronezh, Russia
Flights of flight group Star Sky, year 2012
Star Sky 2012 (3 min 24 sec)
VladimirVRN is offline Find More Posts by VladimirVRN
Old Oct 24, 2012, 07:18 PM
1moparman1's Avatar
Joined Apr 2011
http://youtu.be/J8OtEoBXuxU
That's so cool
I wish i have more money and time to fly in a place like that
Good Job
Old Oct 24, 2012, 11:36 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
very impressive video guys... well done!
BulletMaster is offline Find More Posts by BulletMaster
Old Oct 25, 2012, 01:41 AM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Vladimir, that is just cool!
Fantastic vid, thanks
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Oct 25, 2012, 04:27 AM
buckaroo is online now
Find More Posts by buckaroo
Banzai Institute
buckaroo's Avatar
United States, NY, West Seneca
Joined Oct 2005
That's way cool my Russian friends. Good job
Dean
buckaroo is online now Find More Posts by buckaroo
Old Oct 25, 2012, 05:10 AM
ravikoth is offline
Find More Posts by ravikoth
RAVI KOTHARI
Joined Nov 2005
Just Starting mine, Jet fan et all................
ravikoth is offline Find More Posts by ravikoth
Old Oct 25, 2012, 09:58 PM
Joined Dec 2010
Thank you!
Old Oct 25, 2012, 10:16 PM
Joined Dec 2010
THE STORY. It is flying the Star Sky, the year 2011.
Star Sky (6 min 52 sec)
Old Oct 28, 2012, 07:46 AM
Torchy is offline
Find More Posts by Torchy
United States, NY, New York
Joined Aug 2011
hi guys. Just wanted to ask if i could use a freewing 1750 kv 6 blade setup? it runs on 6s and powered by 85 amp esc. It will be a starting setup for me till i am comfortable with fiber glass kits. I have researched on my setup and it gives anywhere between 2300-2500 grams of thrust. I had it on a freewing ef-2000 with an AUW of 2569 grams. It flew with very good authority and speed in the 70-80 mph range.
So i am guessing if this airframe is not too far in weight and is technically cleaner in drag, inclusive of the fact that it is a single duct(output) vs the eurofighter twin duct. One can assume performance should be on par or better.
In all cases! i intend to use this as a starting point and later moving to a better setup when i have the extra budget.
I would appreciate your feedback as i am close to pulling the trigger on one from nitroplanes or hobby king..
Thanks a bunch
Torchy is offline Find More Posts by Torchy
Old Nov 03, 2012, 06:48 AM
loopsy is offline
Find More Posts by loopsy
Joined Oct 2006
I received my CMP L-39 today, well packed and undamaged
I noticed that my kit does not include the two pilots as displayed on
the box. Is that normal for this kit ?? Or am I simply missing them ?
Will add Herbīs gear-reinforcement first....
loopsy is offline Find More Posts by loopsy
Old Nov 04, 2012, 05:59 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi all, nice video
Loopsy, the CMP kits do not come with pilots. But the parkzone t-28 pilots work quite well and are rather inexpensive.
Nevertheless you need all the space you can get under the cockpit for batteries etc., so my pilots are removed before a flight.
Old Nov 04, 2012, 06:47 AM
loopsy is offline
Joined Oct 2006
Hi Herb
I will probably remove the whole battery tray, my 6S-5000s barely go below the horizontal bar once velcro is fitted to the tray....removing them is a hassle especially.
Instead I will epoxy a velcro directly to the bottom of the fuselage and win 2 cm....pilots is a "must have" in an airplane, isn't it ?
Ripped off the original plywood in the nose wheel bay, was hardly glued in at all.
Will install an eFlite 25-46 and make a scratch-build plywood plate for the retracts and the steering servo which I then epoxy into the wheelwell.
First thing however is the modification/reinforcement of the main landing gear area.....will exactly copy your approach. Donīt have "hysol" though here in Europe so I guess I will have
to go with normal 30min epoxy....or something else you would recommend ??
Oli
Old Nov 11, 2012, 02:05 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi Oli,
Yes you can remove the whole battery tray to set the battery lower ...
Nevertheless I think the whole plywood structure makes the nose more rigid, and prevents the chinese gelcoat from cracking.
I had no problem with the nosegear mount, it held up well. You are supposed to land on the mains. I did have a problem with my nosegear steering servo, it was too nice and small and I stripped the gears. Replaced with a bigger metal gear one.
Instead of hysol epoxy you can use other slow cure epoxy (endfest?) and even a 30 min one.
Discussion L-39 90mm EDF rctoday Electric Ducted Fan Jet Talk 6 Dec 09, 2011 05:25 PM
Wanted WANTED A NICE 90MM EDF KIT like the red/wht HET L-39 I have a TJ100 PNP I'll trade. mechengineer03 Aircraft - Electric - Jets (FS/W) 0 Jul 23, 2011 06:44 PM
For Sale K&A L-39 Albatros EDF kit richardc951 Aircraft - Electric - Jets (FS/W) 0 Jun 01, 2011 07:16 PM
Wanted L-39 Savex Albatros 90mm EDF carl rich Aircraft - Electric - Jets (FS/W) 1 Oct 17, 2007 08:23 PM
