This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Aug 07, 2012, 02:33 PM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
ARamos, sure don't wanna be rude, but reading thru the thread first will give you (almost) all the answers
Some can be found here:
http://www.rcgroups.com/forums/showp...4&postcount=77
and here:
http://www.rcgroups.com/forums/showp...2&postcount=76
There are videos, links to all the equipment used, instructions for construction and mods, all pre-chewed for us...
Thanks for this thread Herb!
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Aug 07, 2012, 04:47 PM
ARamos is offline
Find More Posts by ARamos
Joined Aug 2012
No problem DeeCee 57, thanks for pointing me that.
I do have read all the thread and take my notes. But I also remember read that this was equipement that Herb already have lying around (maybe I misunderstood).
When I ask for Fan, Motor or Batteries opinion, I just want to know if is there any modification Herb will do on the Power System to improve the model performance.
Since I need to buy everything maybe I can buy something a little better or not so expensive. Just guessing.
ARamos is offline Find More Posts by ARamos
Old Aug 08, 2012, 02:35 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by DeeCee 57 View Post
... Thanks for this thread Herb!
Gruezi DC
Originally Posted by ARamos View Post
When I ask for Fan, Motor or Batteries opinion, I just want to know if is there any modification Herb will do on the Power System to improve the model performance. Since I need to buy everything maybe I can buy something a little better or not so expensive.
ARamos if you read through the thread you will find a list of the equipment I used. Improve the performance? Did you look at the video? You want a supersonic missile from a $200 china arf with a $19 disintegrating fan that you can wreck on the maiden flight ??
My suggestion is to use something similar to what I use ... keep it LIGHT. Did I say LIGHT ?? Look at the WEIGHT of your components.
Wemotec Midifan, DS-51, Aeronaut 90mm fan or HK (CS) 5-bl clone, maybe het fan (poorly balanced) etc. Quality ESC (Hobbywing / K-force or YPE etc.), not the $30 dangerous cheap junk variety. Inrunner 300-350g quality inrunner (Neu 15115 , Het 650 , Leopard) on 8S 3000-4000 or so. Motor kv in the 1500--1600kv range.
No, if you read the thread you will see that there is NO way you can get the CG right with a 10S 5000
This excellent calculator will help you in choosing an appropriate motor:
http://www.ecalc.ch/fancalc_e.htm?ecalc
Herb is offline Find More Posts by Herb
Old Aug 08, 2012, 05:49 PM
ARamos is offline
Joined Aug 2012
Hi Herb,
Thanks again for your time replying to my questions. All the information you have shared here as been very helpfull for me.
I won't bother you again with my silly questions
Best regards
ARamos
PS
Thanks for the eCalc tool
Old Aug 09, 2012, 09:30 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
You are welcome Let me know if you have any further questions ...
Old Aug 09, 2012, 10:16 PM
1moparman1 is offline
Find More Posts by 1moparman1
chillax! It's only a Hobby
1moparman1's Avatar
United States, CA, Millbrae
Joined Apr 2011
I have a question
How do i put a hole in my L39's wing
Never mine, I just remember i did it to my own plane
anyone wants to buy my L39 with a new wing???
I dont think i am going to get to it
1moparman1 is offline Find More Posts by 1moparman1
Latest blog entry: Hk cri cri
Old Aug 11, 2012, 01:28 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Tell me about it ...
Old Aug 15, 2012, 01:05 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Earlier somebody was asking about the CMP L-39 vs. the HET L-39, and I thought the proportions were a bit odd on the HET one...
Recently I found this side view of the HET L-39 on the german edf forum.
The fuse looks really short and fat from the side, seems like they wanted to make sure there was enough room for batts
Old Aug 29, 2012, 02:10 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It seems Nitroplanes has finally dropped the price on the CMP L-39/L-59 from $259 to $168, which makes it cheaper than some foam edfs
http://www.nitroplanes.com/cmp-cp09-090-kit.html
Old Sep 05, 2012, 01:53 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It is possible that CMP finally did some changes on the L-39/59 wing construction as this one held up pretty well on one of the hardest landings I've seen It's hard to see how deep the crack in the wing is ...
Old Sep 06, 2012, 11:45 AM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
yeap, wings are still on, all of this in spite of a perfectly pitch stabilized approach
Direct link
2012-09-01 HobbyKing L-59 90mm Composite - Maiden Flight (2 min 50 sec)
Gern gschee
Old Sep 06, 2012, 09:58 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Amazing he did not destroy it ... he must have dented the runway
Old Sep 10, 2012, 02:42 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
I would consider buying another but the packaging is too risky.
urrl is offline Find More Posts by urrl
Old Sep 10, 2012, 03:46 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes there'a risk but I bought two Nitroplanes T-45's (one was a black Friday sale so I bought a spare) and both were perfect.
The packaging problem is a CMP propblem, not a Nitroplanes one. CMP originally did a miserable job packing their planes for overseas shipping (see Hobbyking damages).
Old Sep 14, 2012, 09:50 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by 1moparman1 View Post
http://www.youtube.com/watch?v=eWclF6tcGHw
Here is my fan on 8s CS fan, you will love the way it sounds!
Watch for high amp!
Ihave the exact same setup...
same numbers in the plane.
using 4400mah 65c nanos
but the fan failed..
so I'm got two replacements from hobbyking and a set of blades from x-flight
soon to fly again when my RClander metal shroud arrives.. already assembled the new fan with the stiffer blades using epoxy between the blades.
the previous fan was also balanced.. did 2 flights but eventually failed on the 3rd just before take off.
the fan was perfectly balanced too.. the sound great until 4 seconds before it blew..
L-59 misshap (6 min 6 sec)
pavcon is offline Find More Posts by pavcon
Discussion L-39 90mm EDF rctoday Electric Ducted Fan Jet Talk 6 Dec 09, 2011 06:25 PM
Wanted WANTED A NICE 90MM EDF KIT like the red/wht HET L-39 I have a TJ100 PNP I'll trade. mechengineer03 Aircraft - Electric - Jets (FS/W) 0 Jul 23, 2011 07:44 PM
For Sale K&A L-39 Albatros EDF kit richardc951 Aircraft - Electric - Jets (FS/W) 0 Jun 01, 2011 08:16 PM
Wanted L-39 Savex Albatros 90mm EDF carl rich Aircraft - Electric - Jets (FS/W) 1 Oct 17, 2007 09:23 PM
