This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old May 31, 2012, 07:34 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Herb, the HK version is now in stock and shipping. It's unlikely to have the wing strengthened at all. In your opinion, can the retract rails be strengthened from under the wing by adding ply blocks and webbing? Or is going through the top of the wing the only way???
jayb1rdz is offline Find More Posts by jayb1rdz
Old May 31, 2012, 09:05 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
I decided to table the 12 blade for now and replaced it again with the 5 blade. I must have done a better job of making sure the ducts were sealed because now I can loop better and it really feels faster with the 6S 5000mAh batteries.
urrl is offline Find More Posts by urrl
Old Jun 01, 2012, 02:50 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi Jay,
Yes I think the HK one has most likely exactly the same wing, and therefore the same problem ...
Yes the retract mounts can be strengthened, I did some of that initially but then had to do some more later.
I also believe all of it can be done from the bottom, without ruining the appearance on the top wing.
If it is done right (ply doublers on ribs and spars, reinforced shear webbing, epoxy & glass or fiber on the joints, laminating epoxy on the top sheeting close to the retracts etc.) then very little weight is added.
The crucial point is to SPREAD the load and make everything nice and rigid.
The BVM F-86 wing below is a good example of how it's done.
Herb is offline Find More Posts by Herb
Old Jun 01, 2012, 05:28 PM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Herb, thank you for being so generous with your experience. It would be a shame to let an attractive model get hangared due to fear of landing or worse wrecking through poor design.
Old Jun 02, 2012, 09:31 AM
urrl is offline
urrl's Avatar
Joined Aug 2010
Flew seven packs this morning. Loops, inverted circling, barrel rolls, touch and go landings. She seems faster now even though only 6S 5blade. I think reinstalling the ducting made a difference. Love this jet. I'm thinking of buying another CMP jet.
http://www.scaleflying.com/BAE-HAWK-...F-_p_2506.html
Old Jun 03, 2012, 07:17 PM
1moparman1 is offline
Find More Posts by 1moparman1
chillax! It's only a Hobby
1moparman1's Avatar
United States, CA, Millbrae
Joined Apr 2011
I have one of these too
still in the box, might get to it in a few
the paint and color looks great!!
1moparman1 is offline Find More Posts by 1moparman1
Latest blog entry: Hk cri cri
Old Jun 04, 2012, 10:13 PM
morgusmax is offline
Find More Posts by morgusmax
United States, NY, Putnam
Joined Jul 2007
So guys I have the 10s 90mm HK fan - is there any reason not to put it in the L-39?
morgusmax is offline Find More Posts by morgusmax
Old Jun 05, 2012, 06:56 AM
Joined Jul 2007
Also... anyone checked out the gear that comes with the pnp version offered by Aerodyne/Scaleflying?
Old Jun 05, 2012, 12:38 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
A few things happened during my five flights for the day. First I caught a defective rechargeable Tx AA battery which can disconnect intermittantly. A $6 battery could have destroyed a $600 jet. Though it was brand new it was defective. Then during or after my third flight I lost a flap servo. Then one of my elevator servos became unglued. Not sure whether it was during flight or not. Hopefully what does not destroy the L-39 will make it stronger.
Old Jun 05, 2012, 05:12 PM
SlayerNZ is offline
Find More Posts by SlayerNZ
Spektrum Fan Club
SlayerNZ's Avatar
New Zealand, Southland, Gore
Joined Jan 2011
Same here, I ordered the 10cell version as well
SlayerNZ is offline Find More Posts by SlayerNZ
Old Jun 07, 2012, 09:21 AM
urrl is offline
urrl's Avatar
Joined Aug 2010
Check the flap hinges now and then. One conecction on each flap was loose; one actually came out, that's how i discovered it and used some epoxy on both. I need to slow down, been running thru 5 packs on this jet daily for about two weeks.
Old Jun 07, 2012, 11:11 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Whatever you put in there make sure you watch your WEIGHT as the wing can't take much stress
I use a very lightweight fan combination (WeMoTec Midifan).
Yes, http://www.rcgroups.com/forums/showp...67&postcount=3
Old Jun 08, 2012, 02:53 PM
Joined Jul 2007
The weight issue is a tough one. 10s and the alloy fan will add quite a bit. Decisions decisions!
Old Jun 08, 2012, 03:38 PM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
I suppose, if you are going to open the wing to strengthen the retract rails and attachment points, you might as well add straight spam wise as well.
The wing surface area looks as though it could handle the loading.
Herb, is the problem the engineering or the surface area? I was planning 7s 3800s Mega 1400 kv in the Mach all alloy.
Old Jun 08, 2012, 06:01 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
Does anyone know what scale our models out? I'm looking for some Breitling decals and want to be sure of the scale.
http://www.hobbyshop.cz/shop/1-72-de...-72-decal.html
Discussion L-39 90mm EDF rctoday Electric Ducted Fan Jet Talk 6 Dec 09, 2011 05:25 PM
Wanted WANTED A NICE 90MM EDF KIT like the red/wht HET L-39 I have a TJ100 PNP I'll trade. mechengineer03 Aircraft - Electric - Jets (FS/W) 0 Jul 23, 2011 06:44 PM
For Sale K&A L-39 Albatros EDF kit richardc951 Aircraft - Electric - Jets (FS/W) 0 Jun 01, 2011 07:16 PM
Wanted L-39 Savex Albatros 90mm EDF carl rich Aircraft - Electric - Jets (FS/W) 1 Oct 17, 2007 08:23 PM
