Old Jan 26, 2012, 07:53 AM
Joined Dec 2007
V911 servo fix
Myself and a friend of mine had problems with servos sticking, so i'm sure that many others are/will have this problem.
My aileron servo was malfunctioning, while my friend had issues with the elev' servo.
The only way to restore normal servo movement was to either tap the servo casing or move the servo arm.
Within minutes, the servo would malfunction again, however.
The problem, like many cheap servos, boils down to the VR (variable resistor) slider not touching the carbon track within the servo at various points.
You cannot get to this VR unless you remove and desolder the 3 pins that are connected to the RX pcb. You also need to remove the 2 diagonal screws which hold the relevant servo to the pcb.
Once you have carefully desoldered the 3 pins you can then remove the servo gaining access to the VR.
Don't go using a huge automotive soldering iron for this job otherwise you're asking for trouble. The board is double sided too so be careful.
I know this heli' is inferior junk, but before binning it I thought I would try this and it worked.
My friend reports that His v911 servo is still working around 50 flights hence since the repair.
Servo retracted from pcb
Remove silver plate to gain access to VR
Press down on the springy part of the slider where I point the driver, and place a drop of Deoxit on the local area. Work the VR with the servo arm.
The opposite servo needed repair on my friends as can be seen.. The elev' servo removed from pcb.
The final image is the servo re-assembled.
I used the Deoxit faderlube since faders (as in mixer sliders, etc..) use carbon tracks like these VR's.
Cheap switch cleaner (Servisol) might be OK for this task, but I prefer Deoxit.
Deoxit can be found for around £20 ($30) for 4 x 2mL tubes. Although it's quite expensive, a little goes a long way.
Sent from my E10i using Tapatalk
Username> is offline Find More Posts by Username>
Reply With Quote  (Disabled)
Old May 14, 2012, 12:38 AM
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Excellent servo repair tips.
I have the same problem with a V911 Rx after dozen flights. The aileron servo sticks and works again for a few minutes after I torque the servo arm. I'm debating to order replacement servos, new Rx or find switch cleaner source to attempt a repair.
Is it easy to remove the silver plate to gain access to VR?
Brosol is offline Find More Posts by Brosol
Old May 14, 2012, 12:57 AM
Joined Dec 2007
I completely forgot about this tutorial.
Is it easy to remove the Silver plate to gain access to the VR?
I can't remember a great deal to be honest, but I managed it with minimal effort, and also put it all back together.
I don't fly my v911 anymore, but my friend does, and He reports that His servo has worked great ever since.
Mine had a good few flights after this fix and also showed no sign of imminent failure.
He announced that the fixed servo has done in excess of 200 flights, so it's worth trying even if you make an Henry Halls of it.
Discussion Droopy gear leg fix for servo driven retracts... 4stripes Foamy EDFs 1 Jan 02, 2012 01:39 PM
Anybody know how to fix servo wires pulled out of connector? Justin Jackson Parkflyers 11 Nov 19, 2002 11:24 PM
jammed pico BB servo, how to fix Thomas Manson Parkflyers 5 Sep 04, 2002 07:45 PM
Fix for aileron servo pushrod flex? hmhoshi Hand Launch 7 Apr 09, 2002 04:41 PM
fix servo connectors? JoeR Power Systems 3 May 10, 2001 04:51 AM
