Old Jan 26, 2012, 05:25 AM
MarkChinery is offline
Find More Posts by MarkChinery
Speed King
MarkChinery's Avatar
London Heathrow, Great Britain (UK)
Joined Feb 2003
What CNC machines
Hi All,
my work are looking at getting a CNC Router milling machine. What are the machines to have that are good for milling moulds?
Also what machines are best for CNC laser cutting? wood templates etc for built up models
cheers
MarkChinery is offline Find More Posts by MarkChinery
Old Jan 27, 2012, 09:41 AM
heli_bee is offline
Find More Posts by heli_bee
Joined Mar 2005
Hello Mark,
I bought my CNC Machine from Germany. Here is the link:
http://www.team-haase.de/maschinen/uebersicht
Regards,
Martin.
heli_bee is offline Find More Posts by heli_bee
Old Feb 07, 2012, 06:24 AM
kajakmannen is offline
Find More Posts by kajakmannen
kajakmannen's Avatar
Gavle, Sweden
Joined Jul 2003
Depending on what your company are going to do different machines can be best suited.
This is what I use
ABB IRB 6400 5 axis robot with milling spindle.
The robot solution has a very nice feature and that is flexibility.
The downside is that the investment is rather high.
So it depends on what you company are ging to do. please give some typical examples and we can give you more info.
Best regards / Kajakmannen
kajakmannen is offline Find More Posts by kajakmannen
Old Feb 07, 2012, 02:23 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Here is a list of machines I am considering to mill foam and possibly molds out of corian: Machines I'm considering:
1) BlueChick v4.2, 12"x36": bit small for fuselage molds but $1800 for the complete kit w/ electronics is hard to beat. Would be limited to cutting foam and pulling molds off of foam directly. Concerned with the overall accuracy and dimensional stability of wood (have a wooden hotwire CNC already).
2) FLA-200, 24"x48": ($1800+cutting table+electronics) Need to do some more research on what else I need besides the base kit.
3) CNC Router Parts 48"x48" ($2600+cutting table+legs+electronics)-too big for my needs but CRP has a very good reputation in the cnc community (better than FLA it seems)
4) XZero ViperXZ 30"x48" ($2200+cutting table+support table+electronics)-potentially a better machine than FLA, at a higher cost of course
5) IronMan XE12 36"X12" or 48"x12". Not sure what the total is.
4) Haase, 580mmx1000mmx110mm (22"x39"): Kit w/ electronics for $3400 USD (after subtracting VAT and converting from Euros).
I will say there are advantages to pulling a fiberglass mold off of a foam plug (milled) that must be considered; for 1 material cost is lower, 2 accuracy may be higher if using a cheaper machine and 3, fiberglass molds are very stable.
samc99us is offline Find More Posts by samc99us
Old Feb 08, 2012, 08:44 AM
fnev is offline
Find More Posts by fnev
Joined Jan 2009
We'll...
You have to factor in the hours... This might change a bit your view on the subject (especially if you look at my comment on the third point).
Yes BUT: it is very easy to introduce errors and discrepancies.
IF they are build properly, handled/stored properly and used within the "designed" requirement... like ANY molds...
So, personally, I will go for composite molds (when the job requires to go this way) even if I have the luxury of having a CNC milling unit capable of handling metal machining. But this is not necessary the cheapest route.
Each application/use as its own requirements, therefore it needs a specific tooling. Your reasoning is correct for you and you needs. Just make sure that you tick all the blocks before committing for one way or an other.
fnev is offline Find More Posts by fnev
Old Feb 08, 2012, 08:51 AM
samc99us is offline
Aurora Builder
Joined Nov 2003
I've been both ways. Factoring in the hours it IS NOT less time to cut a set of DLG wing molds on a CNC machine that costs less than $10K. It is very easy to introduce errors and discrepancies in the polishing process on Corian or Aluminum molds cut from such machines. When you factor in the CAD time required to generate the toolpaths for the machine (40+ hours in CAD for an 8 panel wing with variable twist), it makes a lot of sense to skip this and use a foam plug IF you have the capability to cut such a plug to a high degree of accuracy. I have the equipment to do the latter and not the former, hence the reason for suggesting this as a possible option.
Old Feb 08, 2012, 09:06 PM
fnev is offline
Joined Jan 2009
Sorry if I was not clear enough: when going composite mold, if accuracy is required, my pattern will be CNC machined. So, you still have to transfer the 3D design into the tool path (for the plug/pattern machining) plus all the added details you want to be in your mold (channels, centering, etc.). So, for some applications, I will still favor a composite mold over a metal one. Even if I have the luxury of machining metal.
As I have said in other posts to achieve an accuracy of 1/10th of a millimeter on a wing is,to me, the best one can do without a CNC machined pattern. 1/10th error on the leading edge is BIG by today's standard with the new high performances wing sections.
Old Feb 08, 2012, 09:17 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
CNC cut masters have their own issues with two piece molds. Getting the corner between the cut parting plane and the profile is difficult to do accurately. If you have cut the master with a square corner then any paint applied to master rounds out the corner. I prefer to have them cut with a small trough around the perimeter. This makes a positive in the mold that then gets blocked off so the corner is square. I personally would rather have a CNC cut full shape (which is difficult to do well) and then part it myself.
1/10 of mm (.003) can be challenging with any plug. That is the thickness of most people flashing which is a theoretical error. Also, pulled parts out of perfect molds don't hold a perfect shape. Many people don't do a balanced skins on both sides of the core which will cause variations (larger than .003") over time.
wyowindworks is offline Find More Posts by wyowindworks
Old Feb 09, 2012, 02:03 AM
fnev is offline
Joined Jan 2009
Wyowindwork, we all have our "tricks" to get around all the mold making, and pulling products from them, issues. It is often more than one way to skin a cat. I agree with you that the parting plane(s) is one of the major issues with all mold making.
My comments were more in response to the OP to point out the fact that CNC aluminum molds are not necessary the answer, and at the same time composite molds have issues as well. One of them being their stability and resilience.
Your analyze of the 1/10th of millimeter accuracy is spot on. I was more referring only on the induced errors linked to the manufacturing of the molds (i.e. by using a "hand made" wing pattern). Of course, you have to consider ALL the other issues linked to the manufacturing process. And people have to understand that this issues (errors) will compound with the one already existing in the tooling... This is a very good example of tolerances issues when trying to get manufacturing discrepancies under control.
Old Feb 11, 2012, 12:27 AM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
A few years ago my work installed a poseidon five axis router in the shop. This machine was Mfg in Italy. You can drive a full size car onto the bed. We have cut foam race car plugs and other cool aircraft parts on it. It took eighteen truck loads of concrete eight feet deep just to pour the base for the foot print.
Cool Aerospace stuff!
Merrill
Mr B.... is offline Find More Posts by Mr B....
foamlinx cnc machines? jstevens The Builders Workshop 1 Mar 26, 2004 12:16 AM
Question CNC router machines topforce The Builders Workshop 25 Jan 05, 2004 06:14 PM
CNC foam cutting machines and software Intrex The Builders Workshop 2 Dec 01, 2003 05:21 AM
CNC Foam Cutting Machines Depdog Foamies (Kits) 2 Jul 06, 2003 08:12 AM
cnc machines? i-fly Electric Plane Talk 11 Jun 26, 2001 05:40 AM
