Old Feb 08, 2012, 12:30 PM
Mud Duck Bill is offline
Find More Posts by Mud Duck Bill
Mud Duck Bill's Avatar
Up State New York , USA
Joined Mar 2009
Joe How deep is you shroud I have a 11.5 prop and I want it to be proportional to that. I am thinking about 4 1/2 to 5 inches deep.
Mud Duck Bill is offline Find More Posts by Mud Duck Bill
Old Feb 08, 2012, 01:05 PM
Jockadopolus is offline
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Bill
3 1/2 inches
Joe
Jockadopolus is offline Find More Posts by Jockadopolus
Old Feb 08, 2012, 03:39 PM
Joined Mar 2009
Thanks Joe that's about what I thought so I cut the shade down to 4-1/2" added a wire on the inside and I will sheet this with 1/16 Bass, make up some stand-offs to mount it and I'll be back to shaping the the front fuselage.With this design I was able to lower the motor almost 4" Wow that puts the thrust line close to the center of the fuselage.Hope it's not too low but what I have been able to gather is the lower the better, will see.
Bill
Old Feb 09, 2012, 02:04 AM
Scotland
Joined Jan 2010
Looking good Bill how are you fitting the rudder?
Yours looks nice and light I am having to add a lot of material behind the mast to support my shroud I'm concerned it will be tail heavy as you say will see
Joe
Old Feb 09, 2012, 02:52 AM
Gyrocopter is offline
Find More Posts by Gyrocopter
What could possibly go wrong!!
In Bedfordshire, UK.
Joined Oct 2008
Bill
Hi Bill,
I hope you have had permission to use the best lamp shade in the house, has it been missed yet ?.
Just my experience but on my RPG SE I lowered the motor to get the thrust line as low as possible and it ended up half an inch below the C of G. I found it unflyable as it would pitch its nose very high on the take off run and when I fed in down the rotors slowed and the nose was back on the ground, a vicious circle. I guess you might call it pitch sensitive. I then moved the motor thrust line up which ended at 3/8 inch above the C/G and it transformed it..it now takes off without any problem.
My two cents pence for what its worth. Good luck with the build and Joes. Watching with interest.
Chas
Gyrocopter is offline Find More Posts by Gyrocopter
Old Feb 09, 2012, 08:15 AM
Scotland
Joined Jan 2010
Glued balsa onto the foam edges to give me a cut line
Made the engine covers and pulled a test piece from thin plastic and found I need to add more balsa to the bottom to give me more plastic to cut to shape
Going to experiment on small pieces to get window frame outlines
Joe
Old Feb 09, 2012, 08:26 AM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
That's pretty slick man! That will be nice and light!
jodini is offline Find More Posts by jodini
Old Feb 09, 2012, 01:11 PM
Joined Mar 2009
Chas: I am concerned about that very fact and the mounting of the shroud is in direct relationship to the motor placement. I will have to finish the rest of the fuselage add the battery and radio and see if I can determine where in blue blazes the C/G will end up. And I thought this was going to be easy
Thanks for telling me about your experience. Better now than after it's all done
Joe: I found an old old servo arm with a square mounting hole not spline like most and some square hollow carbon rod that a 4-40 pushrod fits oh so nice inside of and I thought I would sandwich some thin balsa either side of that for a rudder. and mount it like you and Dave.
P.S. She was mad that I spent money on the shade only to cut it up,would have looked nice in the living room.
Bill There I go hi- jacking some one else Thread again
Old Feb 09, 2012, 11:25 PM
Scotland
Joined Jan 2010
Bill
Looking good I hope you get a good thrust and cg test result
Joe
Old Feb 11, 2012, 10:00 AM
Scotland
Joined Jan 2010
Daves Avian Update
Dave sent me the latest info and photos of his Avian and it looks great
Weight Auw ( without rotor blades fitted )
2200mah batt installed = 3lb 4oz
4000mah batt installed = 3lb 11oz
all the gear to install final position...... all the little jobs that add up !
Read the concerns about Cof G / Thrust line checked it this morning , used Richards RPG method ( hang from mast.hang front UC leg ...two lines cross etc )
motor is about 2" BELOW that point ?? hmmmmmn
however with 4000mah int nose , hanged model from mast with string an powered her up -
fuz remained level , but with 2200mah batt int fuz pitched slightly nose up
so ?? what do yer think to do ? angle the motor/ shroud or fit clear acetate horizontal vane int duct angled down ...
or wait till eventually try a test hop first ( wonder how full size flies sooo well ?)
For now , not going to make all the ducts for the model till successfully flown
Dave
Old Feb 11, 2012, 11:22 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
There are so many!..looking great everyone.
Bill,
If it were me I wouldn't worry about your motor position, just make provision so that the whole lot can be moved up and down. Really no point guessing at this stage, you need to virtually complete it so that it is almost flight ready. This will give you a far more accurate CG position with everything fitted (rotors electrics and batteries etc) Once this has been found it will all depend on whether you are going with a tailplane or not (and its area and length behind the prop).
Joe,
What's the length of David's blades (there's a reason), with a thrust line that low it will just balloon up and probably crash, I certainly wouldn't try a hop like that. It is going to have to be a really accurate set up with such a short moment arm.
I have tried thrust offset in a duct on a para motor and it just didn't work well. With a vertical fin in the prop wash it was better but still a little unpredictable. I then added some trim to the vertical fin and this worked through the whole power range. Maybe making the fin a clarke Y section may work?, but I have never tried it.
RC ParaMotor, Motor offset test (1 min 5 sec)
Regards
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Feb 11, 2012, 11:41 AM
Scotland
Joined Jan 2010
Rich
Asked Dave what blades and length he has will let you know ASAP
Joe
Old Feb 11, 2012, 12:32 PM
Joined Mar 2009
What about adding some washers under the bottom motor mount screws to aim the thrust up a little and maybe push the nose down a little
Bill
Old Feb 11, 2012, 03:12 PM
Scotland
Joined Jan 2010
Joe,
Regards
Rich[/QUOTE]
Dave got back to me with this info
Rotor blade options :-
A. aerobalsa 23 1/2" x 2 1/4" 49g ( ,lots of lift, an drag)
B. homemade 24" x 2 1/2" 61g ( moderate lift ,lots posi head angle req,d , high head spd.)
C. homemade 25 1/4" x 3" 78g ( lots of lift, slow head speed )
i had C . blades fitted when doing the C o G hang test !
Old Feb 11, 2012, 11:33 PM
jodini is offline
jodini's Avatar
Joined Sep 2004
Rich...that is a cool video! Amazing what that center fin does!
Bill, I think your idea would possibly help, but I think you would want to put the washers on the top of the mount to make the motor point upwards, to keep the nose down. Correct?
I remember reading that the longer the mast, you get more stability and even though this thing is 80 percent fuse, it doesn't have that long of a mast. Quite the dilemma you have there Joe!
Well, I watch with interest!
Joe
Discussion Avro Avian G-AAYW Pat Lynch Scale Kit/Scratch Built 61 Jun 14, 2016 11:23 PM
Discussion Avian Flew Welder13 Coaxial Helicopters 8 May 31, 2007 09:24 PM
Latest on Avian bird flu.. rumme Life, The Universe, and Politics 22 Nov 12, 2005 02:15 PM
Avro Avian foxflyer Scale Fuel Planes 0 Mar 01, 2004 01:07 PM
Avro Avian Monoplane -- History ? --- EZ-Bee Scale Kit/Scratch Built 4 Mar 13, 2002 07:25 AM
