Old Jan 25, 2012, 05:13 PM
MrBadNewS is offline
Find More Posts by MrBadNewS
Romania, Bucuresti, IF
Joined Mar 2011
DIY 27Mhz RX/TX
Hi there,
Because is winter and cold outside i started to build a homemade TX/RX.
I had 2 old walkie-talkies with some missing components but with some nice Xtals on 27Mhz. So, after more than 7 years since i did not burn my fingers, and because 12 years ago i loved playing with RF and now i have some free time, i decided to reverse engineering thouse.
I know i am reinventing the weel, but i am having fun.
Also, Ivan (http://translate.google.com/translat...n%2Findex.html) inspired me and i will like to thank him.
Right now i moved the TX part (FM modulated) to a test board, with success (i can reach third harmonic on my cheap radio - around 81Mhz).
Check the pictures attached.
MrBadNewS is offline Find More Posts by MrBadNewS
Old Jan 26, 2012, 08:36 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
i am very interested in 27mhz. it is my favorite band because of low cost and further range than 72mhz or 2.4ghz. i have dozens of toy plane and car radios in addition to old walkie-talkies. but i think you are just using the parts to build 81mhz for fm radio?
dave1993 is offline Find More Posts by dave1993
Old Feb 04, 2012, 05:06 AM
Joined Mar 2011
Hi,
I am building a 27Mhz RX / TX by modifying an old walkie-talkie (single conversion).
Is true MC3361 can be used at higher frequency, but this design / or at least the old walkie talkie design is on 27Mhz, but using frequency modulation (FM) - which i believe is more reliable than AM.
Because first i buit the TX (and have no 27Mhz receiver yet) to test it i used a conventional multiband FM receiver (which can receive both FM bands 64-108Mhz ), tuned on the third harmonic 27Mhzx3 (81Mhz) and removing the TX final PI filter (which remove harmonics).
So far i finished the TX, i had a problem with modulating this high Q oscillator, but i modified a little bit the original circuit by inserting a coil in series with the crystal and lowering it's Q factor so i can obtain a nice modulation. Is true i lost some power by doing this.
Is working fine, next step is to rebuild it to a dual side copper board.
Sold 27mhz and 75mhz TX and RX - combos mohillbilly Cars - Accessories (FS/W) 1 Oct 07, 2011 09:54 PM
Found 27mhz am rx or 2.4ghz tx/rx kennyhoc3 Aircraft - General - Radio Equipment (FS/W) 0 Nov 27, 2010 04:20 AM
Wanted AM 27mhz Rx...or trade for 75mhz FM Rx or need FM Tx RC Sumo Cars - Trucks and Parts (FS/W) 0 Jan 03, 2010 10:45 AM
DIY TX for DIY Micro AM RX vaughan@world.s DIY Electronics 3 Jun 09, 2004 11:10 PM
WTB Cheap 4ch Tx & Rx on 27Mhz or 35Mhz Chasvo Aircraft - Electric - Airplanes (FS/W) 0 Jul 27, 2003 08:02 PM
