Old Jan 25, 2012, 02:32 PM
PRINCEY is offline
Find More Posts by PRINCEY
Joined Jan 2012
ninja 400 elevator servo not working for rearward flight
New to this game so excuse lack of knowledge.
I have a ninja 400 which i crashed when the aileron servo broke up inside. Replaced it and that now works o.k. but for the some reason the servo for elevator rearward flight not working. All other modes o.k. Have reset default settings for ninja 400 left hand throttle. and checked that servo arms are at 90degrees parellel at 50% throttle.
Any ideas?
Not to techy though I am not that bright!!
PRINCEY is offline Find More Posts by PRINCEY
Old Jan 25, 2012, 06:01 PM
Parkflying is online now
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
Any ideas?
Make sure it is plugged into the receiver in correct orientation; try removing it and plugging it into another channel on the receiver to confirm the servo itself is not broken. when you crashed you could have broken this servo also
Hope this helps
Max
www.parkrcmodels.com
www.skyartec-usa.com
Parkflying is online now Find More Posts by Parkflying
Site Sponsor
Old Jan 26, 2012, 01:35 PM
PRINCEY is offline
Joined Jan 2012
Thanks Max I will check that.
Old Feb 01, 2012, 12:55 PM
PRINCEY is offline
Joined Jan 2012
Hope this helps
Max
Hi Max
Did as you suggested but still no go. Servo operates o.k. when plugged in another point. Tried another servo in the elevator point but same problem. Only ok for forward flight movement no reverse movement.
Might it be the Receiver or Transmitter?
Strange one.
Old Feb 02, 2012, 12:26 AM
Joined Dec 2008
Hi Max
Strange one.
Looking at the original message, I am thinking you might have the servo arms out of position. are you flying in normal - low to high throttle stick mode or in "idle up" mode, where throttle is centered and pulling down inverts blades for inverted flying and pushing forward of center changes the pitch for normal lift?
I will check a correctly configured one on the bench tomorrow for precise positions.
Are you using a Skyartec Radio system? if so which model? Sky 701, 703, 705 or 706 ?
Site Sponsor
Old Feb 02, 2012, 03:54 AM
PRINCEY is offline
Joined Jan 2012
sky705
Old Feb 03, 2012, 12:06 AM
Joined Dec 2008
sky705
And ??? please re-read my question as there are still more information I need to try to resolve your problem without having the system on my bench
Max
Site Sponsor
Old Feb 03, 2012, 08:34 AM
PRINCEY is offline
Joined Jan 2012
I have Flight Mode N (Normal) selected on the Sky705
Old Feb 04, 2012, 12:19 AM
Joined Dec 2008
While it is rare I have had a few transmitters that one or more directions of either the stick or the trim would stop working or didn't work. Yes it is possible it is either the transmitter or the receiver. Since you are testing a good servo direct into Channel 2 and servo only operates in one direction; and no other changes except the crash; it does sound more and more like a receiver (or maybe Tx ) issue
Max
Site Sponsor
Old Feb 06, 2012, 12:45 PM
PRINCEY is offline
Joined Jan 2012
Thanks for all your help Max.
Did try one last thing. Swopped throttle from left to right. Elevator Servo works o.k. like this. So I don't think it is the receiver do you?.
I am wondering whether it is the mechanical side of the stick operation in the transmitter or the electronic side and whether it is possible to download the complete programme for the Sky705.
Anyway I won't give up.
Thanks again.
Old Feb 08, 2012, 02:19 AM
Joined Dec 2008
Thanks again.
It sounds like it might be the mechanical aspect that is a problem. You can download all of the factory default software in the download section at
www.skyartec.com
Max
Site Sponsor
Yippee! Several queries for the Ninja 400 Irish Steve Skyartec 2 Nov 08, 2011 03:56 AM
Discussion UMX Beast Elevator Quit Working Mid-flight joefear7 Micro Ready-to-Fly 21 Oct 07, 2011 06:09 PM
Discussion servo not working properly therepairman Car Talk 2 Mar 12, 2011 04:47 PM
Question TX 2403 not working with flight sim????? rldeveer Electric Heli Talk 0 Mar 05, 2011 09:31 PM
Elevator Trim On My Optic 6 Not Working? STaNgXs Hitec/Multiplex USA 4 Dec 16, 2004 07:21 PM
