Old Oct 23, 2012, 04:36 PM
jocanon is offline
Find More Posts by jocanon
jocanon's Avatar
United States, AZ, Phoenix
Joined Jul 2010
Cool, I am going to go look at it now.
jocanon is offline Find More Posts by jocanon
Site Sponsor
Old Oct 23, 2012, 05:17 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Are you talking about these, if so I think those are capacitors.
Site Sponsor
Old Oct 23, 2012, 08:22 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
OK, here is the results of my tests tonight...I think we are well within spec with just shorting pin 4 to ground and doing no other mod than that to the fan. I took apart a broken DPD-600PB and looked up the part numbers connected to the heat sink that gets the hottest and each one of them are able to operate up to 150C. To quote ronv on elctro-tech..."If we get 50 amps at 12 volts the bridge needs to be able to provide 5 amps at 120 volts plus say 15% for losses - 6 amps. If you go down the derating curve it can be 130C and provide 6 amps. This is absolute max." Here are the data sheets on the 3 different parts connected to the main heat sink:
one of the FETs: http://www.infineon.com/dgdl/SPP_I_A...19090054e32a20
another FET: http://www.infineon.com/dgdl/SPP_A_I...1536a41121152a
bridge rectifier: http://www.datasheetarchive.com/GPJ15M-datasheet.html
Now, I ran the PSU for about 15 to 20 minutes until it reached its peak temperature under a constant load of 50 amps with nothing more than the PSU's own thermal protection working with pin 4 shorted to ground...no additional mod to speed up fan more than it already does. I had the PSU case completely assembled so the flow of air would be as it should. Then I unscrewed the cover and carefully and quickly measured the temperature of the heat sink and it was only 45C. Far under 130C, granted right at the FETs they may be a little higher, but I wouldn't imagine by much, and certainly not over 130C!
Actually, the 470 Ufd. capacitors would probably be the first to fail, but they are rated at 105C, so we are below that too.
Site Sponsor
Old Oct 23, 2012, 10:06 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
That's good stuff to know. It's nice to see some old fashioned facts instead of the surplus of armchair speculation that we seem to get so often on the forums on anything to do with electrical or aerodynamic topics.
Jocanon, thanks for all that work. It is much appreciated I bet by many of us on this thread.
John
jj604 is online now Find More Posts by jj604
Old Oct 24, 2012, 02:10 AM
Andrew_ZA is offline
Find More Posts by Andrew_ZA
Joined May 2011
No lol. See where the ribbon cable connects? That is the daughter board i am talking about. On the outside you will see the pots
Andrew_ZA is offline Find More Posts by Andrew_ZA
Old Oct 24, 2012, 08:01 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Ah, you mean the board that I am not showing in the picture, right?
Site Sponsor
Old Oct 24, 2012, 08:03 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
John
Thanks John. Yeah, I always like hard cold facts whenever possible, can't argue with facts.
Jeremy
Site Sponsor
Old Oct 24, 2012, 08:56 AM
Joined May 2011
Its the board that is touching the paper/that the PSU is resting on in the picture, where the ribbon cable connects, it is that board Flip the PSU 180 degrees and you will see them
Old Oct 24, 2012, 09:05 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
OK, I will look tonight. I am not at home right now. That being said, I do still believe now based on above data that the fan doesn't need to be sped up at all, even when used in hot weather (within reason of course - obviously if used in an oven no matter how fast the fan is blowing it's not going to keep things cool ) as it has its own built in thermal protection and when I ran it at full load it would speed up more than enough to keep things under spec. But just for curiosity's sake I will check that out when I get home tonight. Thanks Andrew.
Site Sponsor
Old Oct 24, 2012, 11:03 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
If you REEEEEELY want to test, it should shutdown when it gets too hot to protect itself. That's what I call thermal protection.
feathermerchant is offline Find More Posts by feathermerchant
Old Oct 24, 2012, 11:15 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Geez, where were you guys when I needed you?
About a year ago, I gave up on this since the fans were too loud and spent way too much on purpose-built power supplies!
Seriously, great work, guys.
Now, just how loud are those stock fans with pin 4 shorted an "no load?"
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Oct 24, 2012, 01:32 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
It's very quite with no load. Sorry, not very technical answer. I don't have a way to measure actual noise level, but I would say it's about as quiet as cat purring
Also, in a real world setting, with pin 4 shorted to pin 8 you will probably never really hear the fans from the PSU over the fan noise already generated by the charger (at least with the PL8, I don't know about other chargers because I have the PL8).
Site Sponsor
Old Oct 24, 2012, 10:39 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Hey guys, I made an on/off switch Y-cable power cord that I am offering for sale here in the classified section at the link below. I have a bunch of them in stock ready to ship. I plan on making more as supply runs out so they will always be in stock even if you are reading this post at a later time:
http://www.rcgroups.com/forums/showt...8#post23093635
Site Sponsor
Old Nov 02, 2012, 02:56 AM
hawkeye70 is offline
Find More Posts by hawkeye70
Canada, BC, Vancouver
Joined Apr 2012
Thanks everybody
Originally Posted by hawkeye70 View Post
Anybody??
Thanks for all the help guys!!
I guess now I see why so many people say other forums are superior
hawkeye70 is offline Find More Posts by hawkeye70
Old Nov 02, 2012, 04:18 AM
rchelijc is offline
Find More Posts by rchelijc
Pro beginner
rchelijc's Avatar
Joined Aug 2010
It's been a long while since post 1, 2 and 3. Now with the new icharger coming out, I'm glad that I built mine with these PSU's.
I will reconfigure my 4 PSU's for 48V, which should take 5 mins.
That's the great advantage of these PSU's... small and light.
Many who have combined those massive 1200W 12V beasts for 2400W 24V, will need to purchase another 2 more, to produce a combined power of 4800W at 48V, but the weight of this would be prohibitive.
Of course if the new icharger is not your thing, then it doesn't matter
rchelijc is offline Find More Posts by rchelijc
Discussion Flydumini Frame Thread and Build Hints/Help nasgul Multirotor Talk 216 Sep 28, 2013 04:58 PM
Discussion DPS-600PB Power Supply Shuts Down wcsd106 Batteries and Chargers 3 Jun 23, 2013 06:11 PM
Mini-HowTo Tips, Tricks, Hints, Secrets & How To's to help make a build/rebuild easier... ABADGTP The Builders Workshop 37 Dec 24, 2011 11:48 AM
Discussion Sokol build tips and hints Dan the man High Performance 9 Aug 21, 2008 03:26 AM
Discussion GWS Piper Cub Build Tips & Hints? Royster Australia 111 Feb 07, 2007 03:11 PM
