Old Sep 25, 2012, 03:24 PM
d3sbo is offline
Find More Posts by d3sbo
Joined Jun 2010
bump thanks for the info
d3sbo is offline Find More Posts by d3sbo
Old Sep 28, 2012, 06:55 AM
zeke_ is offline
Find More Posts by zeke_
Joined Sep 2012
Thanx everyone for all the info here. It was a big help determining how to mod these supplies. In the end all that is required is a bit of solder bridging out five terminals and a short chunk of 30 gauge to ground - sweet.
zeke_ is offline Find More Posts by zeke_
Old Sep 28, 2012, 03:32 PM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
The DPS-600PB zeke mod. I like it.
xandrios is offline Find More Posts by xandrios
Old Oct 02, 2012, 09:03 AM
jocanon is offline
Find More Posts by jocanon
jocanon's Avatar
United States, AZ, Phoenix
Joined Jul 2010
OK, so I got the temperature control circuit working...almost, I still need to do the final tweaking and waiting on parts from Mouser...but I am pretty stoked about it. I have to give credit where credit is due to ronv at electro-tech-online for designing the circuit, I had the idea, but he made it work with just one op-amp, 4 resistors and a thermistor. We decided to simply use the PSUs built in fan control pin, pin #4 and control the speed of the fan based on temperature by changing the voltage on this pin. 4.6v to Vcc (Vcc=about 12v) is the range on pin 4 that will adjust the fan speed. The fan reaches a minimum speed at 4.6v and even if the voltage from the op-amp output drops below 4.6v (i.e. when the PSU first starts and it's cold) the fan will still not go below the minimum speed. We decided not to let the fan stall. The circuit ronv designed is excellent in my opinion because it doesn't generate any heat (the original design with a MOSFET would have wasted a lot of energy in the form of heat and required heat sinking the FET to the case with non-conductive thermal epoxy) and it doesn’t require any mods to the PSU's internal fan wiring...no 555 timer and no splicing of the fan wires! So the built in protection is still intact where the PSU will shut down if the fan dies, meaning if it stops getting a tach reading from the fan, the PSU will still shut down to protect itself. My original design had to trick the PSU into thinking it had a tach pulse with a 555 timer because we disconnected the fan and allowed it to stall, but we dumped that idea. Thanks ronv! Once I get all the parts and get the circuit dialed in, I will post some pictures/youtube video showing it in action with the 1500+ watt water cooled (thanks to ()blivion!) dummy load we made as well.
If anyone is interested, you can find the schematic for the temperature controlled circuit, dummy load and all information about how we made the circuits in this thread:
http://www.electro-tech-online.com/e...ircuit-62.html
jocanon is offline Find More Posts by jocanon
Site Sponsor
Old Oct 02, 2012, 09:14 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Yes, but when can those of us with no skill buy a "kit?"
Keep up the great work!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Oct 02, 2012, 09:28 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
In due time my friend
Site Sponsor
Old Oct 02, 2012, 09:39 AM
Greenland
Joined Mar 2012
Money waiting: two systems to refit, each with ribbon cable modifications-let "us" know!
Old Oct 02, 2012, 09:40 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Thats good that you are using the ribbon cable, because the mod will be easiest to do that way. It's an easy mod with either the pin method or the ribbon cable method but just a little easier with the ribbon cable.
Site Sponsor
Old Oct 02, 2012, 10:07 AM
Greenland
Joined Mar 2012
Money waiting!
Old Oct 02, 2012, 12:16 PM
RobT01 is offline
Find More Posts by RobT01
United States, NY, Syosset
Joined Jun 2012
RobT01 is offline Find More Posts by RobT01
Old Oct 03, 2012, 08:13 AM
SCOREMAN is offline
Find More Posts by SCOREMAN
Joined Oct 2007
Originally Posted by jocanon View Post
OK, Once I get all the parts and get the circuit dialed in, I will post some pictures/youtube video showing it in action with the 1500+ watt water cooled (thanks to ()blivion!) dummy load we made as well.
Does this mean you have successfully pulled 1500 watts steady from these units? (i assume a 24v set-up)
SCOREMAN is offline Find More Posts by SCOREMAN
Old Oct 03, 2012, 12:47 PM
SCOREMAN is offline
Joined Oct 2007
Just finished 6 days of charging at eWeek. One 25V on a super duo and one 12.5V on 250 watt 720i. Both have only the "pin 4" mod hard wired. (no switch)
Stayed on all day every day charging mostly 5 and 6 cell 5000mah packs at near capacity a lot of the time.
Highest ambient temp was 88 degrees... never skipped a beat.
Old Oct 03, 2012, 03:07 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
No, the dummy load is capable of more than I can get from the PSUs. I did push them to the limit just to see what would happen. At about 55 amps the over current protection kicked in, the PSU just shut down, and my house lights got a little bit brighter . Once I shut power off to the PSU and then powered it back up, the PSU worked like normal without a hiccup. So at 55 amps X 24 volts the most you can get would be about 1,320 watts, but this is not reccomended. I wouldn't go above the rated current of 47amps.
Site Sponsor
Old Oct 03, 2012, 07:29 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Nevermind
Site Sponsor
Old Oct 10, 2012, 04:08 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
For anyone that's interested, here is a link to a video of the dummy load I made to test these PSUs..
Dummy Load (13 min 31 sec)
I have been blowing TVS's on my dummy load, my latest theory is that it's a faulty PSU. I am going to go home tonight and test out that theory by using a different PSU on my dummy load (I have always been using the same PSU everytime the TVS blew). One thing that makes me think it is a faulty PSU is that the isolated PSU's volatage gets unstable as current increases above about 30 or 40 amps. Has anyone else experienced this?
Update:
Tried it with a different isolate DPS-600PB. The voltage is 25v at no current and only drops .2 volts to 24.8 at 47amps but it is a solid 24.8 amps, not fluctuating around like the other one, so I think the problem was a faulty PSU after all, it was spiking up to 170v!, according to one $5 volt meter, but according to another $5 volt meter it was bouncing all around but mostly staying below 21v (which one to believe, hmm probably the high one since it was blowing the TVS diode). This is a good reason that shows why I built this dummy load in the first place, so I can test each PSU to make sure it's not faulty.
Site Sponsor
Discussion Flydumini Frame Thread and Build Hints/Help nasgul Multirotor Talk 216 Sep 28, 2013 04:58 PM
Discussion DPS-600PB Power Supply Shuts Down wcsd106 Batteries and Chargers 3 Jun 23, 2013 06:11 PM
Mini-HowTo Tips, Tricks, Hints, Secrets & How To's to help make a build/rebuild easier... ABADGTP The Builders Workshop 37 Dec 24, 2011 11:48 AM
Discussion Sokol build tips and hints Dan the man High Performance 9 Aug 21, 2008 03:26 AM
Discussion GWS Piper Cub Build Tips & Hints? Royster Australia 111 Feb 07, 2007 03:11 PM
