Old Jul 10, 2012, 10:59 PM
whitedg is online now
Find More Posts by whitedg
Australia, NSW, Rydalmere
Joined Feb 2010
Originally Posted by Dusey52 View Post
Use caution when disabling the fan. There's a post here on RC Groups (possibly this thread) by someone that ran a data center. He said he experienced a number of failures with early versions of the power supply that turned the fan off when not needed. Long story short, they racked up a bunch of these and plugged them in but left them OFF for a couple of weeks. When it came time to power up the servers a number of them had dead power supplies. The replacement power supplies all had fans that slowed down but didn't shut completely off. Will this affect our application? Who knows, but there is risk.
Yep, that was me. 15-20 servers powered off in a rack (ie. no air flow through the server) and 2 x PSU's in each server generating 35-50w (the 5v 7A standby = 35w) each, a lot of them overheated and failed.
The PSU's were then modified to slowly turn the fan to keep at least some air flow going through them - that is why the fan slowly turns when connected to AC power.
Keep a close eye on temps if you plan to run with no fans turning. If you have seen inside these PSU's, there are a lot of components in a very small package - they rely on the airflow to survive.
Cheers
whitedg
whitedg is online now Find More Posts by whitedg
Old Jul 11, 2012, 08:33 AM
jocanon is offline
Find More Posts by jocanon
jocanon's Avatar
United States, AZ, Phoenix
Joined Jul 2010
Duly noted. I remember reading that post as well. I wonder though if the PSUs were heating up and the heat is what caused the failure. Since my circuit is heat driven it seems like that should not be a problem because if it starts to heat up, the fan will kick in immediately and ramp up rpm in direct relation to heat increase.
The only thing I see as an issue (other than the tach problem which I still need to fix) is making sure I get the tempurature sensor in the "right" place, if there is one "right" place. Any thoughts on this question are welcom. I am thinking the right place might be the heat sink...but if so which one, there are a couple in there? I can run it and just see what part heats up first. Maybe the only way to know if it will work is just to build it and test it out.
jocanon is offline Find More Posts by jocanon
Site Sponsor
Old Jul 11, 2012, 08:35 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Originally Posted by xandrios View Post
Thanks, I'll check it out.
Site Sponsor
Old Jul 11, 2012, 08:38 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
I substituted some low speed fans, that are near-silent-the measured exhaust temperature never gets above 100 degrees F.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Cheers
whitedg
It might be a good idea to just set the fan to minimal speed instead of shutting it completly off then. Even if I do that, I think I still like the temperature controlled circuit because it is more responsive than simply connecting pins 4 & 8. I can adjust the pot in my circuit to make the fan slow down but never go off. I'll play around with it and see. It might still be possible to shut it all the way down as long as the fan kicks in at some point as it heats up with out any load.
Site Sponsor
Old Jul 11, 2012, 08:41 AM
Greenland
Joined Mar 2012
Did FMA send you a new charger?
Old Jul 11, 2012, 08:45 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
He tried, but they are out of stock until July 20 or 23, I can't remember. Oh well, I have enough to keep me busy till then
Site Sponsor
Old Jul 11, 2012, 08:47 AM
Greenland
Joined Mar 2012
Well, that was certainly a snake-bitten transaction.
The PL 8 is constantly on backorder, so I suppose it is a very popular charger: I have two of them!
Old Jul 11, 2012, 08:53 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
I am taking your word for it, it looks like it will be a great charger. I guess good things come to those who wait, right?
Site Sponsor
Old Jul 11, 2012, 05:35 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
JohanathanSwift - Where do you live? (City,State)
While testing power supplies for my business, I was at my flying field and set up a pair powered up fans running and no load then another pair charging two 6S 5,000 at 20A each. I was measuring temps and found no difference in case temp. Both were running 114degF. It was a hot day near 100 degF but I could not figure out how the unloaded power supplies were running so hot. I pointed my IR thermometer upward to the roof of the 'shed' we use for shade. It read 142degF! I was standing in a giant easy bake oven.
The point is that before you contemplate slowing down the fans, remember how you intend to use the power supplies. I would hate to burn one up just because I thought the fan was noisy.
feathermerchant is offline Find More Posts by feathermerchant
Old Jul 12, 2012, 02:15 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey whitedg,
were these early versions of the DPS-600PB that fried?
xandrios is offline Find More Posts by xandrios
Old Jul 12, 2012, 06:58 AM
Greenland
Joined Mar 2012
Feather is right: I only use mine indoors, where it is always 72 degrees F!
Old Jul 12, 2012, 08:17 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Wouldn't a temperature sensing fan solve that problem? I mean, with a temperature sensing circuit if it was a hot day and the PSU was running hot, the fan would simply rev up to full power and stay there until the PSU was no longer hot. I think where you would have an issue is if you just short pin 4 to 8 because that is NOT temperature controlled.
Site Sponsor
Old Jul 12, 2012, 08:48 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
It worked! Thanks for the link xandrios. I successfully created a temperature controlled fan circuit and a 555 timer to trick the DPS-600PB into thinking the fan is always running. I found out that I could wire the circuit directly through the regular fan plug (about 9.5 volts DC), but then the fan makes a faint high pitch squeal when it is slowing down, I think because you can hear the buzz from the PWM frequency. I connected the fan to 12 volts DC instead and the sound went away, complete silence at every speed other than the faint noise of the fan blades cutting through the wind, nice .
Interesting to note, the 555 timer is not needed if the fan never completely stops. I decreased the resistance in the pot and made the fan come on at room temperature, once I did that, the PSU worked fine, because it was getting a tach pulse, and the fan was still temperature controlled. I may end up tuning it so that the fan never stops, depending on results of testing, but I think I will still include the 555 timer just in case. I mean, if the PSU is being run on a very cold day, like say outside on a cold winter day with a generator, and it is running very cold so no need for the fan when it is first powered up you would not even be able to get the PSU to turn on without the 555 timer circuit installed.
Here is the tempurature controlled fan in action. Right now the temperature sensitivity is very sensitive, all I have to do is touch the thermistor and it revs up. I need to add another resistor to the circuit at R1 (per schematic in second link) to get a wider temperature range. So, there is still some fine tuning left to do, but the general idea works!
DPS-600PB temperature controlled fan (1 min 59 sec)
This is where I got the information to build the temperature controlled circuit if anyone is interested:
http://www.electro-tech-online.com/c...an-driver.html
and (duplicate info of above):
http://www.heatsink-guide.com/tempcontrol.htm
see link above in xandrios post for 555 timer.
Site Sponsor
Old Jul 12, 2012, 06:51 PM
Joined Feb 2010
Hey whitedg,
Yep, it was from our first batch of G4's. I think the issues was very quickly rectified, and HP swapped out all the PSU's from these servers.
Cheers
whitedg
Discussion Flydumini Frame Thread and Build Hints/Help nasgul Multirotor Talk 216 Sep 28, 2013 04:58 PM
Discussion DPS-600PB Power Supply Shuts Down wcsd106 Batteries and Chargers 3 Jun 23, 2013 06:11 PM
Mini-HowTo Tips, Tricks, Hints, Secrets & How To's to help make a build/rebuild easier... ABADGTP The Builders Workshop 37 Dec 24, 2011 11:48 AM
Discussion Sokol build tips and hints Dan the man High Performance 9 Aug 21, 2008 03:26 AM
Discussion GWS Piper Cub Build Tips & Hints? Royster Australia 111 Feb 07, 2007 03:11 PM
