This thread is privately moderated by nerdc0re79, who may elect to delete unwanted replies.
Old Jan 24, 2012, 10:10 PM
nerdc0re79 is offline
Find More Posts by nerdc0re79
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
TowerPro 9g w12A Brushless esc throttle issue
Help..... Throttle doesn't start until I hit the half throttle line.i tried to reprogram. Still no luck. I set it to default. Still no luck......help!!!
nerdc0re79 is offline Find More Posts by nerdc0re79
Old Jan 24, 2012, 10:33 PM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Try this:
Remove the prop.
Turn on the Tx and move the throttle to full.
Plug in the flight battery.
When the first lot of beeping finishes, return the throttle to off.
Unplug the bat, switch off the TX, replace the prop.
Do a normal start up and see if you are lucky or not.
Whiskers is online now Find More Posts by Whiskers
Old Jan 26, 2012, 09:12 PM
3Disaster
nerdc0re79's Avatar
Las vegas nevada
Joined Apr 2007
tried that . still didnt work.. i set everything at default setting. still having the same issue
Old Jan 26, 2012, 10:06 PM
Whiskers's Avatar
Joined Feb 2010
I've had a few TowerPro ESCs, and I'm not fond of them.
I buy other brands now.
Question TowerPro 9g w12A Brushless Speed Controller werlec Power Systems 8 Jan 27, 2012 06:34 AM
Sold NIP TowerPro W12A 9g ESC, $10.75 Shipped ek123 Aircraft - Electric - Power Systems (FS/W) 0 Feb 14, 2011 08:03 PM
Sold Two NIP TowerPro 9g w12A Brushless Speed Controllers -- Both $24 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 3 Aug 30, 2008 10:43 PM
Discussion Anyone tried using TowerPro 9g w12A ESC with Turnigy 2204-14T 19g motor? groovejet Power Systems 2 Aug 28, 2008 03:51 PM
Sold TowerPro 9g w12A Brushless Controller punkindrublik Aircraft - Electric - Power Systems (FS/W) 1 Aug 04, 2008 08:23 PM
