Old Sep 19, 2012, 08:20 PM
T-28 Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
I haven't painted them yet, but the conversion is done! Oh, and for landings... this gear is awesome! You can see it articulating on landing and over grass! This was the best $20 spent for this plane.
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Sep 19, 2012, 08:33 PM
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
A set is on its way for my kit.
loNslo is offline Find More Posts by loNslo
Old Sep 19, 2012, 09:27 PM
T-28 Fanatic
Joined Jul 2008
Cool, spread the word!
Old Sep 20, 2012, 01:16 AM
North Carolina
Joined Sep 2003
I bought 2 sets last year for my 71 inch Sig 1/6 scale stick built kits. They were almost perfect for that kit in every dimension. Can't beat the price either. Stripped and covered in fabric, they look pretty darn convincing.
sj3cub is offline Find More Posts by sj3cub
Old Sep 20, 2012, 10:35 AM
Aerobatic Fanatic
HugoCraft's Avatar
Joined Sep 2007
the gear would look good covered in solartex. The full scale ones have that triangle covered.
HugoCraft is offline Find More Posts by HugoCraft
Old Sep 20, 2012, 10:44 AM
wood is good
loNslo's Avatar
Joined Jun 2012
I'm planning to simply spay paint mine.
Old Sep 20, 2012, 11:43 AM
T-28 Fanatic
Joined Jul 2008
I'm going to spray all the metal parts and cover the triangle part with solartex.
Old Sep 20, 2012, 12:10 PM
North Carolina
Joined Sep 2003
May I suggest stripping, covering and then painting? I promise you that you will be more satisfied with the finished product if you paint last. The solartex will be a whole lot more opaque as well, and your color match will look a whole lot better. Just a friendly suggestion.
Old Sep 20, 2012, 03:03 PM
T-28 Fanatic
Joined Jul 2008
Thank you scott. I will follow your suggestion! Thats a great idea.
Old Sep 21, 2012, 06:49 PM
wood is good
loNslo's Avatar
Joined Jun 2012
They appear to be just the right size.
What material are they made from and what do they weigh?
Mine just arrived.
Some of the parts are made of steel (magnetic). The brackets appear to be aluminum. And some of the tubes are only very slightly magnetic, so perhaps stainless steel? All the fasteners seem to be steel and heavily magnetic.
Total weight, as delivered, without axles, measured 7.6 oz.
The design of some of the tubes is very weak due to the large holes drilled through them (nearly wiping out the entire wall thickness). There have been failures reported at these weak points so I'll want to consider how they might be ruggedized prior to refinishing. Also some of the mounting brackets bind against the main gear, so I'll want to do a little re-shaping also prior to refinishing.
Old Sep 21, 2012, 08:48 PM
T-28 Fanatic
Joined Jul 2008
I haven't heard of ANY failures on it. And mine is holding up great. Throught one day that is!
Old Sep 21, 2012, 08:59 PM
wood is good
loNslo's Avatar
Joined Jun 2012
I haven't heard of ANY failures...
Now you have.
Old Sep 21, 2012, 10:07 PM
T-28 Fanatic
Joined Jul 2008
Now you have.
Yeah, but is it just hearsay?
Old Sep 21, 2012, 10:08 PM
Aerobatic Fanatic
HugoCraft's Avatar
Joined Sep 2007
somebody has made every landing gear fail one way or another
Old Sep 21, 2012, 10:10 PM
T-28 Fanatic
Joined Jul 2008
True!
For Sale Great Planes Piper Cub .60 size (electric) & More bmontini Aircraft - Electric - Airplanes (FS/W) 0 Sep 26, 2011 10:44 PM
Sold 40 Size Great Planes J-3 Cub Ultracoat Covered KIT flyinwalenda Aircraft - Fuel - Airplanes (FS/W) 1 Sep 16, 2011 11:11 AM
Sold Great Planes Piper J-3 Cub .60 Size KIT Keven_C Aircraft - Fuel - Airplanes (FS/W) 2 Jan 25, 2008 03:27 PM
Discussion Great Planes 40 size Piper Cub Kit Cub4P02 twier Beginner Training Area (Fuel) 1 Dec 18, 2006 06:04 AM
