Old Jan 24, 2012, 01:59 PM
Spamman127 is offline
Find More Posts by Spamman127
United States, OH, Troy
Foam ribs covered with Econokote or similar?
Anyone ever build a plane the "regular way" except for using balsa ribs they used foam? Just curious for an alternative technique to covering the whole structure in foam.
Spamman127 is offline Find More Posts by Spamman127
Old Jan 26, 2012, 09:44 AM
No one? I guess I have some experimenting to do!
Old Jan 26, 2012, 10:04 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Ghost bipe comes to mind
leadfeather is offline Find More Posts by leadfeather
Old Jan 26, 2012, 10:16 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
It wasn't that uncommon a building method years ago. We built a few competition fun fly planes with them. Particularly easy with a hot wire, just cut a small wing and slice off the ribs. With the advent of ARFs and foamies, most people aren't into actual building anymore.
Azarr
Azarr is offline Find More Posts by Azarr
Old Jan 26, 2012, 11:28 AM
pmullen503 is offline
Find More Posts by pmullen503
United States, WI, Fond du Lac
Joined Sep 2008
The problem with substituting foam for balsa in a film covered open wing is that foam lacks the compressive strength of balsa. It can be done but you'll need design a proper spar and support the LE and TE so they don't warp when you shrink the covering.
The advantage, besides cost it that you can hotwire your ribs all at once. Very useful for tapered wings.
See this post: http://www.rcgroups.com/forums/showp...2&postcount=75 for the "laser method" using foam ribs.
You can also just sheet from the spar forward and add balsa cap ribs and TE to use this method with heat shrink films.
pmullen503 is offline Find More Posts by pmullen503
Old Jan 26, 2012, 11:34 AM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
you can, all tho it can lead to extremely floppy models more prone to damage than just building with balsa & sheeting that.
more popular is to not cover, but use only a minimum amount of foam ribs, spars & bulkheads and sheet it with foam.
also, cheaper than wasting good covering or copious amounts of tape on foam is to take paper & use watered down PVA/AR (white glue or wood glue) and paint that on. it's lighter than tape & adds a huge amount of strength & rigidity to the foam. i have a 3 channel balsa trainer with a styrofoam wing constructed in that method. it's 18 years old, still flies & has taught no telling how many people to fly.
plus, then you can use regular old spray paint without fear of the harsh cleaners & accelerators eating foam
there is no right or wrong way to build something.
Toysrme is offline Find More Posts by Toysrme
Old Jan 26, 2012, 04:59 PM
mysticranger is offline
Find More Posts by mysticranger
Germany, BW, Neuffen
Joined Sep 2011
I know this build: http://www.wherzog.de/eflug/sukhoibau1.htm
All in german but you can see by the pics that they used foam ribs on thae wing.
At the bottom of the page you can click further through the build.
What they used for building is a foam called "Styrodur". This is quite dense an "hard" foam.
mysticranger is offline Find More Posts by mysticranger
Old Jan 26, 2012, 11:59 PM
AsSoulsDream is offline
Find More Posts by AsSoulsDream
AsSoulsDream's Avatar
United States, FL, Ocala
Joined Sep 2011
I've seen it done with the plastic heat shrink that they put around fruit gift baskets, and you can get it at the Dollar Store just spray the foam with 3m 77 or I prefer 3m 90. That will get it to stick to the foam then just use a hot hair dryer or low temp heat gun, you can use a heat gun if its too hot just pull it away from the plane a little farther
AsSoulsDream is offline Find More Posts by AsSoulsDream
Old Jan 27, 2012, 12:29 AM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
The covering you choose is also VERY important I find Ultracote & Towercote to be best direct to foam, just be shure if you use a Heat-gun to stetch out any loose covering not to melt the internal foam structure, I use Monocote & ultracote on all my airliner & Bomber builds, Good luck Spamman!
demondriver is offline Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Jan 27, 2012, 12:31 AM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
Do you have a brand name or product name to identify the right plastic?
larryross is offline Find More Posts by larryross
Old Jan 27, 2012, 12:53 AM
Lafayette is offline
Find More Posts by Lafayette
'scuse me while I kiss the sky
Lafayette's Avatar
Joined Nov 2009
http://www.rcgroups.com/forums/showthread.php?t=1243116
Lafayette is offline Find More Posts by Lafayette
Old Jan 29, 2012, 11:15 PM
Thanks for the replies guys! I think I will incorporate this style of construction in my next build. Another question. What would you guys use to glue the balsa to foam? I'm thinking white glue, any other suggestions?
Old Jan 29, 2012, 11:31 PM
Lafayette's Avatar
Joined Nov 2009
BEST BET:FOAM SAFE CA
3M77
Gorilla glue(need to clamp tight as it will expand 3x)
OR:
My ex mother in law's turkey gravy!
Discussion Econokote over foam? WVrailfan Foamies (Kits) 1 Sep 24, 2011 02:51 PM
Build Log Quickee (or a foam wing with ribs!) Gere Sport Foamies (Scratchbuilt) 19 Oct 16, 2010 11:24 AM
wonderful Unicorn Electric wing full size - Brushless setup - econokote covered F.Uhlemann Aircraft - Electric - Airplanes (FS/W) 3 Jun 23, 2004 03:40 AM
