Old Jan 11, 2013, 03:53 PM
ozanozkok is offline
Find More Posts by ozanozkok
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Originally Posted by marcin.gala View Post
Is it possible 3axis setup ?
Hi Marcin,
3 axis modul is ready,I will put it webshop after weekend.
ozanozkok is offline Find More Posts by ozanozkok
Old Jan 11, 2013, 05:45 PM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
Nice you are force me to save some money for whole gimbal.
marcin.gala is offline Find More Posts by marcin.gala
Old Jan 12, 2013, 05:43 AM
fernand_naudin is online now
Find More Posts by fernand_naudin
Y6 950 CarbonCore DJI WKM
fernand_naudin's Avatar
France
Joined Jan 2007
Originally Posted by ozanozkok View Post
hi fernand,
i m not familiar this legs.maybe our adapters fits it.what is the mounting booms distance and diameter?
Description:
I thought a support boom could insert between the two pieces (2mm) but I think that will not be perfect in the fight against vibration.
fernand_naudin is online now Find More Posts by fernand_naudin
Old Jan 12, 2013, 07:23 AM
France
Joined Jan 2007
a bit like a piece of this draft
Name: support nacelleY6.jpg
Description:
Old Jan 12, 2013, 12:35 PM
teramax is offline
Find More Posts by teramax
sorry, my english is bad
teramax's Avatar
Austria, Wien, Vienna
Joined Apr 2011
Originally Posted by SeismicCWave View Post
Sorry for jumping in to help. Pot value is 5K Ohm 1 turn.
Measured mine is 0 -> 1k in every direction.
It can be every number from 0,5k up, the elektronik is measuring the difference between the two outer pins in relation to center pin so you have a very wide range of pots you can use.
teramax is offline Find More Posts by teramax
Old Jan 12, 2013, 08:32 PM
LFLoTiTo is offline
Find More Posts by LFLoTiTo
Just want to fly...
LFLoTiTo's Avatar
Brazil
Joined Mar 2009
Fy680
Nice to see mounts for FY680, but will it fit ?
I just measured mine and from rails to ground is around 19cm.
GO is 195mm high. I could not find the height of EVO, but seems even higher.
Has anyone mounted one of those on the FY680?
Cheers,
LFLoTiTo is offline Find More Posts by LFLoTiTo
Old Jan 12, 2013, 08:35 PM
Joined Jun 2010
Just extend legs on FY680 ..I did that with my FY680 frame.Now waiting for 3axis gimbal
Old Jan 13, 2013, 12:04 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Cheers,
it looks fits,but maybe you need ~1cm extension under the legs..
Old Jan 14, 2013, 08:02 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Oz, is the 20% discount still available?
Sid3ways is offline Find More Posts by Sid3ways
Old Jan 14, 2013, 08:10 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Yes,20% discount is available for old TwoDee v1 and v2 users.This discount will be available continuous.
Old Jan 14, 2013, 03:40 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
ThreeDee 3.axis module and TwoDee EVO set ready,please check the product page:
Old Jan 15, 2013, 03:15 AM
France
Joined Jan 2007
ThreeDee 3 Axis
Hi Ozan,
What is the weight of the package?
You have not planned for fixing system to the chassis with anti-vibration system ?
A+
Old Jan 15, 2013, 04:02 AM
teramax is offline
teramax's Avatar
Joined Apr 2011
OZ, Evo arrived and you know what.......
i am verv happy that you found gears that realy fit to the belt. Zero slope, thats how it should be
Start building now and will post pictures in time.
Greetings
Teramax
Old Jan 15, 2013, 04:13 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Greetings
Teramax
Thanks Teramax,
Waiting for your opinions.
Originally Posted by fernand_naudin View Post
Hi Ozan,
A+
We have fixing system to our frames and I will put an aditional mounting part( with vibration dampening) in a couple days.
Old Jan 15, 2013, 05:25 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Assembly guide of TwoDee EVO is online:
Discussion A new professional camera gimbal (tongue in cheek) SeismicCWave Multirotor Talk 23 Nov 13, 2011 12:48 AM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
