Old Jan 10, 2013, 03:09 PM
ozanozkok is offline
Find More Posts by ozanozkok
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Originally Posted by fernand_naudin View Post
any pictures ?
Pictures will be available, tomorrow.check the product page, please.
ozanozkok is offline Find More Posts by ozanozkok
Old Jan 11, 2013, 07:53 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
any pictures ?
Hi,
You can check the product page for mounting adapters.
Old Jan 11, 2013, 08:01 AM
Kilby is offline
Find More Posts by Kilby
Joined Nov 2010
Ozan, seriously. I've been PMing you with no reply about the faulty electronics I got in my kit. At first you danced around my questions for several weeks, now you just don't answer at all even though you are obviously on this board. I even went as far as to make a video to show you exactly what is wrong. Are you just going to 100% ignore me now? I need to know how to get this working.
Hi-Tec 665 Servo troubles (1 min 0 sec)
Kilby is offline Find More Posts by Kilby
Old Jan 11, 2013, 08:05 AM
Kilby is offline
Joined Nov 2010
That one tiny pot is preventing the entire system from working. You made me a promise early on that you would help me figure out what was wrong, but I had to do that myself. The only thing I ask of you know is to help me get this fixed. I paid you for a servo kit and one was DOA and the other had a bad pot. It's not the stock pot that is pulled from the servo, but an after market one that you installed and I have no idea where to get one.
PLEASE HELP YOUR EXISTING CUSTOMERS!
Old Jan 11, 2013, 08:16 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Ozan please help me this man. I'm interested in ordering an Evo but this isn't looking promising.
Sid3ways is offline Find More Posts by Sid3ways
Old Jan 11, 2013, 08:17 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
http://www.youtube.com/watch?v=XM8uGK5pwJg
Hi Terry,
Servo is not dead.it is a potentiometer cable problem.I see that in your video,you modified the cable.
Other hand,I did not ignored you but I send a pm about the replacement of the servos,ask you for a video about your problem.You did not reply my pm and you shared a prejudiced post at this thread.I did not underestand this tension and confused.
Of course I will help you again,choose your option please.first way,I can refund your order,second way,you can re-assembly your gimbal with assembly guide and ask me for dead electronics.I m not owner of the Hitec corporation but,I can refund the servos or re-send a new servo set.
For information,we are testing servos before send.
Best regards
Ozan
Old Jan 11, 2013, 08:22 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Hi Sid3ways,
I think that,everyone knows we have good customer service.We cant assembly gimbals in your house but work for help to you.
Sometimes we cant work 24 hours in a day,but I think this is understandable.
Old Jan 11, 2013, 09:24 AM
Kilby is offline
Joined Nov 2010
Ozan, I never got a PM of that sort and this is the first time you have mentioned anything about replacing or refunding anything, ever. I've been sending you PM's for several weeks and every time it's one way or another that you dance around my problem or just don't respond at all, always dismissing it as one simple thing or another that I had already tested for. I've installed this using your "install guide" and there is nothing wrong with the install or the wires going to the pot. Yes, there is tape on there that you can see, but that is just temp on the work bench and the connection is soldiered underneath... very solid. The problem has also been there long before I cut those wires.
The pot is the problem with this set up. If you can tell me the the value of that pot I might be able to get one locally and see if that fixes the problem. If I can do that, I'll just get you to refund me the cost of the servos. If I can't get that to work, then I'll get you to send me a new pitch servo only and then refund the cost of the roll servo since I've already replaced it locally.
Originally Posted by ozanozkok View Post
Hi Terry,
Best regards
Ozan
Old Jan 11, 2013, 09:50 AM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Hi Sid3ways,
Ozan,
Just an acknowledgement of his post was all you needed to do. Glad to see you help out.
Anyways, are your gimbals available assembled with the HV servos? I thought that was mentioned at some point?
Old Jan 11, 2013, 10:43 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Ozan,
Yes,EVO and GO available assembled with hv servos,of course they needs tuning before use with your controller.
Old Jan 11, 2013, 12:44 PM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
Hi,
Is it possible 3axis setup ?
marcin.gala is offline Find More Posts by marcin.gala
Old Jan 11, 2013, 12:57 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
>>The pot is the problem with this set up. If you can tell me the the value of that pot I might be able to get one locally and see if that fixes the problem. If I can do that, I'll just get you to refund me the cost of the servos. If I can't get that to work, then I'll get you to send me a new pitch servo only and then refund the cost of the roll servo since I've already replaced it locally.<<
Sorry for jumping in to help. Pot value is 5K Ohm 1 turn.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Jan 11, 2013, 01:11 PM
fernand_naudin is offline
Find More Posts by fernand_naudin
Y6 950 CarbonCore DJI WKM
fernand_naudin's Avatar
France
Joined Jan 2007
Hi,
Ozan, do you think it would be possible to create an adapter for this type of legs?
Description:
BR
fernand_naudin is offline Find More Posts by fernand_naudin
Old Jan 11, 2013, 03:50 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Thank you SeismicCWave
Old Jan 11, 2013, 03:52 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Hi,
Attachment 5439693
BR
Hi fernand,
I m not familiar this legs.Maybe our adapters fits it.what is the mounting booms distance and diameter?
Discussion A new professional camera gimbal (tongue in cheek) SeismicCWave Multirotor Talk 23 Nov 13, 2011 12:48 AM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
