Old Aug 15, 2012, 02:41 PM
Michael64 is offline
Find More Posts by Michael64
United States, TX, Thrall
Joined Feb 2010
No deshaker used in post it was shot with the GH2 and 14mm prime lens.
This mount does not work well for me with the 14-42 with the IS on have to turn it off. The V1 mount it worked real well with the IS on but not the G.O. mount. I think the mount relies on proper belt tenison to work well and in that case a little wider belt would have been a better choice for the roll and pitch axis. You may consider changing to a wider belt and I think we all will have better results
Hey Michael,
great deshaker usage.I want to play some with this deshaker.I hope I can use as good as you..[/QUOTE]
Michael64 is offline Find More Posts by Michael64
Old Aug 15, 2012, 03:10 PM
ozanozkok is offline
Find More Posts by ozanozkok
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Hey Michael,
[/QUOTE]
I have wrote it to Mike (va3mw) Michael, I think I did misunderstand
ozanozkok is offline Find More Posts by ozanozkok
Old Aug 15, 2012, 03:32 PM
va3mw is offline
Find More Posts by va3mw
va3mw's Avatar
Joined Sep 2008
It is a Mikrokopter on your first NEX3/5 mount.
va3mw is offline Find More Posts by va3mw
Old Aug 15, 2012, 07:08 PM
mattchase is offline
Find More Posts by mattchase
United States, TX, Seguin
Joined Mar 2005
Hi Ozan,
I am using an OpenPilot CC board, probably not the best for gimbal control but I know there are others who have used it as both a FC and gimbal control successfully. If we can't get it working well in the next few days I'm going to try putting my Quadrino board on the copter as a gimbal only board. I ordered some more plates for my frame so I think I can make room for it...
mattchase is offline Find More Posts by mattchase
Old Aug 15, 2012, 09:47 PM
Joined Mar 2005
Good news, I think I've found / solved the problem! After trying a few different things that didn't work I tried putting the roll servo on a different channel on my FC and the twitching appears to be gone. I got home late tonight so was only able to test it inside just now with a mostly dead battery, but during about a 20 second flight it didn't twitch at all, before it was twitching every 2 - 3 seconds. Hopefully I will get home early enough tomorrow to take it outside for a real flight.
Yay.
Here is a before and after video.
gimbal 15aug12 (0 min 36 sec)
Old Aug 15, 2012, 10:22 PM
va3mw is offline
va3mw's Avatar
Joined Sep 2008
I have wrote it to Mike (va3mw) Michael, I think I did misunderstand [/QUOTE]
Ozan
I meant to ask: Did you ever come up with a bracket to hold a servo to trigger the camera shutter on the NEX3?
Old Aug 16, 2012, 02:40 AM
teramax is offline
Find More Posts by teramax
sorry, my english is bad
teramax's Avatar
Austria, Wien, Vienna
Joined Apr 2011
Originally Posted by va3mw View Post
Here is the video after running it through deshaker: http://www.guthspot.se/video/deshaker.htm
https://vimeo.com/47597183
now i know how the make all the z15 footage.
Smartdrones X8 & Sony HD730 (2 min 20 sec)
teramax is offline Find More Posts by teramax
Old Aug 16, 2012, 03:14 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Yay.
http://www.youtube.com/watch?v=9YHzY6nGmf4
Congratulations Matt,I think it is softpwm problem.
Ozan
Mike[/QUOTE]
I now Mike,I have promise it to you.I will design it this week.
Old Aug 16, 2012, 06:34 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
http://youtu.be/QNfhsgWaJ_s
Nice video Terramax..
Old Aug 16, 2012, 02:00 PM
gondoflier is offline
Find More Posts by gondoflier
Joined Jun 2012
teramax that looks really good..can we see the raw footage?
gondoflier is offline Find More Posts by gondoflier
Old Aug 17, 2012, 09:55 AM
teramax is offline
teramax's Avatar
Joined Apr 2011
This is raw, still cut out the scenes where i yaw´ed around like crazy.
Old Aug 17, 2012, 03:44 PM
eagle_01 is offline
Find More Posts by eagle_01
Joined Jul 2012
Ozan,
Could you explain the difference between the TwoDee v2 and G.O Gimbal. If I only plan on using GoPro Hero2 and Sony Nex-5N, which gimbal is best?
eagle_01 is offline Find More Posts by eagle_01
Old Aug 17, 2012, 06:33 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Originally Posted by eagle_01 View Post
Ozan,
hi eagle,
TwoDee is a circular design gimbal,roll turns on center of the lens.G.O. is a classic gimbal,it is working like a pendulum.
My personal choice is G.O. I think that,it has smoother movements than others cause of bearings and 2:1 belt reduction.G.O. tuning is simpler than Twodee for me.
If I must choose one of them for gopro or nex5,I would choose G.O. I like it
Old Aug 17, 2012, 07:26 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
you find that 2:1 reduction gets rid of all the stepping on a servo and is smooth enough?
Adidas4275 is offline Find More Posts by Adidas4275
Old Aug 18, 2012, 12:16 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Depending to the servo, yes.I m using hs645mg in my setup and I m happy with it. Of course you can use faster servos but I dont need.
Discussion A new professional camera gimbal (tongue in cheek) SeismicCWave Multirotor Talk 23 Nov 13, 2011 12:48 AM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
