Joined Aug 2002
as in post #2, V1.08 does not permit two channels to be assigned with same function name to two different switches. Setup of channel and switches must be made during initial setup Aurora 9 - Programming Problem? - Parameters must be set in correct order e.g. V_tail, see chart and attachment. Suggest delete that model from memory and start over. Aurora 9 - Model Number Reset or Delete. Recommend "Reset" (format) a new model name to clear any extraneous data, which might reside there for any reason, before loading in any details of the new model. Alan T. |
Joined Aug 2002
Higher powered digital servo are commonly used for that purpose with downside being if the gear leg bends and wheel jams, then a digital servo burns out rapidly. Whilst all switches are assignable, use of two switches for one servo is doubtful as in preceding posts, A9 does not permit same "function" on more than one switch. A three position switch, if one remains spare will provide a "position". Adjusting throws of one switch with another may also cause problems with the two switches being in "wrong positions" and overdriving the servo. Will have a twiddle for a two switch workaround and respond later today, Alan T. Alan's Hobby, Model & RC FAQ Web Links |
Joined Aug 2002
A. Three position switch "C", provides 1. Top = Gear up with door closed. 2. Middle = 50% movement = Gear down 3. Bottom = Brakes on. Use EPA to adjust end points if needed. B. Example with separate three position switch: Channel select: ch5:GEAR:C ch7: AUX1:G . P.Mix 1. AUX1>GEAR - Select > AUX1>GEAR Normal [C] Rate +: +50%, -: +50% provides additional rate adjustable movement in each of the three positions. . Example with separate two position switch: Channel select: ch5:GEAR:f ch7: AUX1:G . P.Mix 1. AUX1>GEAR - Select > AUX1>GEAR Normal [C] Rate +: +50%, -: +50% provides additional rate adjustable moverment in each of the two positions. Alan T. Alan's Hobby, Model & RC FAQ Web Links |
| Thread Tools | |
| Discussion A9 with Futaba GYA-352 gyro, fixed wing | 444bm | Hitec/Multiplex USA | 0 | Nov 25, 2011 01:00 PM |
| Sold hitec A9 with 3 rx's | cje0114 | Aircraft - General - Radio Equipment (FS/W) | 2 | Sep 26, 2011 11:51 AM |
| Question No throttle control with A9 as student | NefariousRC | Hitec/Multiplex USA | 3 | Sep 21, 2011 06:22 PM |
| Alert Little bug on A9 | Jambock | Hitec/Multiplex USA | 2 | Jun 24, 2011 07:05 PM |
| Discussion A9 bug | DIG2fly | Hitec/Multiplex USA | 0 | Dec 03, 2010 03:17 AM |
