Old Nov 01, 2012, 05:13 PM
Dan.Cummins is offline
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
Thanks, that will give the San Diego crew a good starting poiint (probably finishing point) for the CG.
Dan.Cummins is offline Find More Posts by Dan.Cummins
Old Nov 01, 2012, 06:26 PM
Doc Holiday48 is offline
Find More Posts by Doc Holiday48
I'm your huckleberry
Doc Holiday48's Avatar
USA, CA, Gardena
Joined Jun 2004
Maiden my Willow yesterday. Flew great, with just a click of down in each flight mode. Gave the controls to Warren and we both had it moving quite well for the light conditions at Pt Fermin. Before the flight I checked the throws against Warrens plane and it was pretty close, so off the cliff it went. It will be a great backup plane for next year racing season.
Bob
Doc Holiday48 is offline Find More Posts by Doc Holiday48
Old Nov 01, 2012, 08:35 PM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Bob
After seeing you fly the Willow, you might be makeing the wrong choice.....
fcbflyer is offline Find More Posts by fcbflyer
Old Nov 01, 2012, 09:27 PM
concreteman is offline
Find More Posts by concreteman
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
Swiss tool may be right! Bobs best performances to date have been flying a Willow....just saying....
concreteman is offline Find More Posts by concreteman
Old Nov 01, 2012, 09:45 PM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Thanks for stating the obvious, I am always right
Old Nov 02, 2012, 10:48 AM
USA, CA, Gardena
Joined Jun 2004
Yeah, I agree to a point. The plane is fast and easy to fly, and yes Warren is right I have flown his Willow better then any of my Cyrils. We will see after the 1st of the year when I decide what my next racing plane will be.
Bob
Old Nov 03, 2012, 02:36 AM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
I have to also commend my Willow for its durability. It's a full carbon version, with the one piece V-tail (now about 9 months old). I've had enough rough landings to conclude that it's holding together better than other big hollow mouldies I've owned/ seen. I just flew it at Woody Point, our very small dodgy local beachfront spot and had a great time. Landing was behind the beachfront row of trees on hard ground, so there's a danger of rotors etc. Approach was perfect, had to push down hard under flaps to bring it onto the grass before running out of room, and when I lifted flaps it did a bit of a belly smack and made quite a loud bang, and I cringed. But all was OK ... I was impressed ...
AvB is offline Find More Posts by AvB
Old Nov 08, 2012, 10:36 AM
lukeydukey10 is offline
Find More Posts by lukeydukey10
voodoo magic maaan
lukeydukey10's Avatar
United Kingdom, England, Merton
Joined Jan 2011
I am sad to report that my slope willow had a big impact with a big hill yesterday
It came in inverted and landed on the nose
The battery went flat on me, what a plonker forgetting to charge it fully
BUT the damage is minimal: broken joiner and nosecone, a couple of cracks in fuz, ailerons need re-epoxying...
Fingers crossed, I should be airborne again soon
Lucky escape / strong plane!
lukeydukey10 is offline Find More Posts by lukeydukey10
Old Nov 08, 2012, 07:06 PM
psanitra is offline
Find More Posts by psanitra
Joined May 2012
Hey guys, any of you using snap flap more than 3-4 mm across the wing?(
recommended default settings) Because i`m flying about 100-102mm COG and it looks like with 6-7mm snap flap i can do much shorter/faster turns. So what i`m using now is 3mm mixed into elevator, and then on the throttle stick i have another 4mm that i can gradually add if i feel like it. Is somebody using similar setup, or just mixing?
psanitra is offline Find More Posts by psanitra
Old Nov 08, 2012, 07:23 PM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
I think the snap flap optimum will vary depending on personal elevator rates, since the snap is linear to elevator stick movement. If you tend to keep rates down and fly such that you're pulling near full elevator, and have 3mm snap, then you'll be getting 3mm actual snap in hard turns. But if you use hot rates and are gentle with the sticks, you might only be reaching half stick. So in reality you'd only be actuating half of the "6mm snap".
Old Nov 09, 2012, 03:52 AM
psanitra is offline
Joined May 2012
not my case, i`m actually doing 6mm snap , I think it might depend more on the COG, with cog more to the back the plane is more responsive to the wing profile change. So with COG at 103 or more to the back, one might be fine with less snap. My COG is a bit more forward, so that why i probably need a bit more snap.
Old Nov 09, 2012, 05:55 AM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
OK gotcha. Agreed.
Old Nov 09, 2012, 12:15 PM
Bobbyr is offline
Find More Posts by Bobbyr
Good Times
Portland . Dorset . England
Joined Jun 2009
It Depends where you are flying , 6mm snap flap is an extreme amount IMO , and although you might think your coming out faster ,
I honestly doubt it , it will be quick , but the drag you create will slow it down, more than it gains .
On the Other hand, if its not flicking on you . Go with the flow.
Oh mine is 3mm Down to Full elevator , 2 mm up .
Have you got Ailerons coupled to snap flap as well ?
Bob
Bobbyr is offline Find More Posts by Bobbyr
Old Nov 09, 2012, 12:37 PM
Joined Aug 2004
Just back from an epic morning flight at Pt. Fermin. We have clearing winds from a weather system that went thru. Winds at 25+ straight in. Maindeing Willow II, which is my original Willow, with the newer 2 piece vtail fuse. Full ballast was in order for the day. My flight was stellar, and I flew til I had had enough, and the landing was perfectly smooth. Cant ask for much more.
Let me give my 2 cents on the snapflap topic. I have continued to work towards balance of "speed thru the corners" and "shortening the radius of the turn", and each plane and each pilot will feel their way to finding a spot to their liking. I do feel, however that having too much snapflap is more deterrent than not enough. CG is relative as well...Also, what works for me may not work for you. I put the sticks full pull while flying. Some guys barely move past half throw. AvB is exactly correct about this. If you are lucky enough to have a site where you can fly and experiment, experiment is your friend...
Bob, I am around 4mm down with full elevator... Ailerons coupled.
WD
Old Nov 11, 2012, 03:33 PM
dolphin56 is online now
Find More Posts by dolphin56
United Kingdom, England, Topsham
Joined Jun 2006
7 out of 16 pilots at the UK southern winter league today were flying willows and we ended up with, first, second, 5th and 6th. COnditions were light so being easy to fly really helped!
dolphin56 is online now Find More Posts by dolphin56
Contest Combat 3rd Annual Blue Mesa(willow Creek) snakecrew Slope 67 Jun 21, 2012 08:38 PM
Yippee! New Spot Discovered "Willow"!!! Warning, Lots of Pics! Drew360 Slope 62 Mar 09, 2006 03:41 PM
Discussion Possible NW site in Willow Springs dmh Chicagoland Slope Flyers 9 Jan 10, 2006 09:23 AM
Indoor Fly-in March 13th in Willow Park Texas ! ronin8451 Electric Flight Events 7 Mar 15, 2004 09:09 AM
Willow River State Park Karl B≤ Aerial Photography 13 Feb 16, 2004 06:41 AM
