Old Sep 09, 2012, 03:53 AM
lukeydukey10 is offline
Find More Posts by lukeydukey10
voodoo magic maaan
lukeydukey10's Avatar
United Kingdom, England, Merton
Joined Jan 2011
Question re "tail pegs"
do you glue them in or are you able to break the tail down for transport?
my willow has the old vtail which is a semi permanent fixture, would be nice if it came off easily
lukeydukey10 is offline Find More Posts by lukeydukey10
Old Sep 09, 2012, 07:17 AM
RCRod is offline
Find More Posts by RCRod
Acacia II Lunar Lander
RCRod's Avatar
United States, CA, LADERA RANCH
Joined Feb 2011
Originally Posted by Bobbyr View Post
Looking Good Rod ,
I see what your saying about tweaking 1 of them , maybe whip the tail off , heat the solder and get the ball to move , then snip off the excess.
TBH do you think it will affect it when each servos travel is set on the TX ?
I would leave it myself
Bob
Thanks, Bob. I could probably wait and work it out in the Tx programming, but I'm going to have the tail back apart to get the linkages bonded to the pushrods, anyway. A minute with the soldering iron, and I should have it nice and clean.
Cheers,
Rod
RCRod is offline Find More Posts by RCRod
Old Sep 09, 2012, 07:26 AM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
I'll be glueing mine in, with the tail feathers held to the fuse with transparent tape. If I want to be able to break it down for transport or repair, I will remove the tape, pop the ball links loose, and slide the tail feathers off the pegs. It will leave the tail with a "spiked club" appearance, but it's much more compact and pack-able than the full tail.
I would imagine glueing the pegs in is the intended build, as it will greatly strengthen that tail area.
Old Sep 09, 2012, 08:28 AM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
I maidened mine at Grass Mt. Yesterday. Love it!
Found one more problem with it. The spluge they use is very brittle. I already had my second servo horn breake off. No big deal but I would recommend to bring epoxy to the slope as this happened to two of the Willows yesterday.
fcbflyer is offline Find More Posts by fcbflyer
Old Sep 10, 2012, 05:23 AM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
I've been thinking that the epoxy seems a bit on the "crispy" side. Hope the wing and tails can take sudden shocks on tough landings...
Old Sep 10, 2012, 07:01 AM
dolphin56 is offline
Find More Posts by dolphin56
United Kingdom, England, Topsham
Joined Jun 2006
Thanks for the feedback on the horns, I've only ever had 1 break off but I'll ask for the fixing to be improved. As someone who's bounced Willows around more than 1 hill- they are tough!
ian
dolphin56 is offline Find More Posts by dolphin56
Old Sep 10, 2012, 07:51 AM
concreteman is offline
Find More Posts by concreteman
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
Fast time of the day at yesterdays contest, 38.xx by my friend Bob M. flying my Willow. WD
concreteman is offline Find More Posts by concreteman
Old Sep 10, 2012, 09:22 AM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Wings and tails were no issue at all, just bring 5min epoxy for the horns and you won't miss a round.
Old Sep 10, 2012, 10:04 AM
Dan.Cummins is online now
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
RE: Low Time of the Day
Warren,
I think that it is significant to mention that the above mentioned fast time of the day was achieved UNBALLESTED against a field of 9 others that were loading up everything they had. Granted the Willows base weight is pretty stout, but that planes AUW racing weight was way under everything else in the field......very impressive!
DC
Dan.Cummins is online now Find More Posts by Dan.Cummins
Old Sep 12, 2012, 07:23 AM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
I am loving my Willow more and more - I've had it for about 7 months now. From the start it has had impeccable manners, and beautiful frontside aerobatic performance, better roll rate than any plane I've flown, of its size. As time goes on I am more impressed. I've moved the CG back and it snaps turns hard now. I have also flown it at our ridiculously small local coastal cliff which is generally considered "foamies only". The Willow is in its element, making great use of the small zone, unlike other big planes I've flown there which have stayed up, but not with any style. The Willow can strut its stuff in a tight spot. But I'm a DS nut, so the first time I flew the Willow I had it DSing in minutes and I have to say that I, and others I've given the sticks to, agree that it's the best tracking F3F moldie we've DS'ed, easy.
I did this video of a fun day out last weekend ... it's very long (sorry) but it's a fun watch and has several sessions of the Willow flying and DSing in there.
Four Aussie slopenuts having DS and frontside fun at Larrikin Ridge 8 Sep 2012 (23 min 8 sec)
AvB is offline Find More Posts by AvB
Old Sep 12, 2012, 07:30 AM
voodoo magic maaan
Joined Jan 2011
http://vimeo.com/49125406
Nice slope! And you can drive right up there - so lucky!
Old Sep 12, 2012, 07:57 AM
Bobbyr is offline
Find More Posts by Bobbyr
Good Times
Portland . Dorset . England
Joined Jun 2009
Great video again Andy ,
I totally agree with you about the willows roll rate , and aerobatic performance for an f3f model . Ive said that its a great sport plane , you can race it , Aero it and DS to a reasonable speed , You may want to contact Ian and get yourself a 3 degree Willow wing joiner ,to see if it tracks any different on the DS circuit , it makes inverted far more stable also it makes a totally different sound when its ripping along , personally for me it has improved the roll rate as well ,
i use the 5 degree for floating on low lift days , and the 3 degree when the wind picks up .
Well done on a nice Vid
Bob
Bobbyr is offline Find More Posts by Bobbyr
Old Sep 12, 2012, 04:32 PM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
Bob, I'm not sure if mine is 3 or 5 deg (it's one of the version 2 planes with one piece V-tail) but I wouldn't change it ... I don't have any other light-air DS plane that is so stable in the circuit. And apart from the Vector there's no other plane that's as happy inverted. The other guys were really surprised that when it was only going 130ish upright, it was doing 100 inverted.
Old Oct 01, 2012, 11:49 AM
FXmodel is offline
Find More Posts by FXmodel
Joined Oct 2012
Nice!
FXmodel is offline Find More Posts by FXmodel
Old Oct 05, 2012, 09:41 AM
bluffman is offline
Find More Posts by bluffman
bluffman's Avatar
Joined Sep 2003
That was a fun video to watch, great commentary, and a great selection of planes, I liked the inverted laps. Ian
bluffman is offline Find More Posts by bluffman
Contest Combat 3rd Annual Blue Mesa(willow Creek) snakecrew Slope 67 Jun 21, 2012 08:38 PM
Yippee! New Spot Discovered "Willow"!!! Warning, Lots of Pics! Drew360 Slope 62 Mar 09, 2006 03:41 PM
Discussion Possible NW site in Willow Springs dmh Chicagoland Slope Flyers 9 Jan 10, 2006 09:23 AM
Indoor Fly-in March 13th in Willow Park Texas ! ronin8451 Electric Flight Events 7 Mar 15, 2004 09:09 AM
Willow River State Park Karl B≤ Aerial Photography 13 Feb 16, 2004 06:41 AM
