Old Aug 16, 2012, 04:30 AM
cianokol is online now
Find More Posts by cianokol
Joined Mar 2007
another view angle from this Wilow wing joiner test slope.
You can see big landing area
"ready" for F3F competitions slope:-)
behind you can see acc houses
cianokol is online now Find More Posts by cianokol
Old Aug 17, 2012, 01:37 AM
Pisaneli is offline
Find More Posts by Pisaneli
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
As promised, here you can find more pictures of Velika Planina. Enjoy.
Pisaneli is offline Find More Posts by Pisaneli
Old Aug 17, 2012, 01:58 AM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Sloping Mecca | Velika Planina
Simply amazing site! Thanks for sharing.
DrFragnasty is offline Find More Posts by DrFragnasty
Old Aug 17, 2012, 03:15 PM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
While waiting for my new joiners to arrive I took the time to do some DIY stickers. Of course I couldn't done it without the help of my two little princesses.
Old Aug 22, 2012, 01:42 AM
RCRod is offline
Find More Posts by RCRod
Acacia II Lunar Lander
RCRod's Avatar
United States, CA, LADERA RANCH
Joined Feb 2011
Great decals, Pisaneli!
I came across something very odd during my build session tonight... The two pushrods supplied with the kit are of differing materials. One is very stiff carbon rod, and the other appears to be Teflon covered with some slippery black coating. The latter is much more flexible, and slightly smaller in diameter.
I'm curious what everyone else has gotten for pushrods... I'm thinking I'll just go to the hobby shop and get another carbon rod, and toss the more flexible one.
RCRod is offline Find More Posts by RCRod
Old Aug 22, 2012, 01:56 AM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
Speaking of the build, here are some shots...
Description: Name: ImageUploadedByTapatalk1345618070.941399.jpg
Description: Name: ImageUploadedByTapatalk1345618195.741152.jpg
Description: Name: ImageUploadedByTapatalk1345618214.236847.jpg
Description: Name: ImageUploadedByTapatalk1345618230.653628.jpg
Description:
I'm planning to have a "shotgun" loading style on the ballast, like on my old Acacia II. I prefer that to risking the ballast spilling out and whacking the servos. Haven't decided if I want it top or bottom loading yet.
The receiver will fit under the deck between the servos and the big honking LiFe battery. No switch; just a big, reliable battery plug to keep it simple. Should be nice and clean.
Old Aug 22, 2012, 03:33 AM
dolphin56 is offline
Find More Posts by dolphin56
United Kingdom, England, Topsham
Joined Jun 2006
Nice build shots!
Some time ago I did send some of the same push rod types that are used in freestylers and the like to the manufacturer. We've now reverted to the more usual carbon ones- that you have one of.
Ian
dolphin56 is offline Find More Posts by dolphin56
Old Aug 22, 2012, 04:57 AM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Hi RCRod
Unfortunately I broke my carbon rod while installing horns. I decided to do the old fashion way and used steel rods. I feel safer soldering.
Anyway, in both cases I found it hard to buy a proper rod lenght. Almost every rod is 1m.
Old Aug 22, 2012, 01:40 PM
Joined Jun 2006
Had a similar problem getting rods for the first willows, hyperflight in the uk stock 1.5m lengths. I now have 200 rods- just incase:-)
Ian
Old Aug 23, 2012, 05:34 PM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Russia, Tomsk Oblast, Kargasoksky District
Joined Sep 2008
I just got lost in that picture for 20 min !!! WOWZA
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Aug 26, 2012, 01:49 AM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
Finished a bit more on the build today...
Description: Name: ImageUploadedByTapatalk1345963055.052743.jpg
Description:
Also started the bottom-access shotgun loading on the ballast tube, but forgot to take photos. Looking good so far. Should have that part finished up tomorrow.
I'm really liking how all the wiring and Rx are fitting below the tray. Did a test fit:
Description:
The Rx can be pulled out through the battery slot, if needed.
I ended up ordering a couple of replacement pushrods, since I have a mis-matched pair. Should be in sometime next week, so I can get started on the tails.
Old Aug 26, 2012, 04:52 PM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
Here are the shots of the ballast port that I forgot to take last night... I'll probably wait to finish this part until I have my ballast slugs made. I plan to tie the ballast tube and inner nose cone together in this area for strength, and all-around awesomeness.
Description: Name: ImageUploadedByTapatalk1346017862.976527.jpg
Description:
Old Aug 26, 2012, 09:26 PM
seaspb is online now
Find More Posts by seaspb
building season is here.
seaspb's Avatar
United States, OR, Silverton
Joined Nov 2008
Looking good Rod! Can't wait for you to put it in the air
seaspb is online now Find More Posts by seaspb
Old Aug 26, 2012, 09:36 PM
RCRod is offline
RCRod's Avatar
Joined Feb 2011
Thanks, Sam... You and me, both!
Oh, and I forgot to mention, that yellow in the sub-nose is Kevlar. My nose got mixed up with Philip's down in SD, and by the time I got down to retrieve it, he'd given it da bidness! It really stiffens it up. Thanks, Philip!
Old Aug 27, 2012, 11:43 PM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Description:
After finally getting the wings/joiner/fuse combo to fit, my incidence pine fell out. Two of the 4 fell out before and I just re-glued them, but this one is only 1/16" in the root rib. I think it is time to buy some material, re-do the all and be done with it.
Faster suggestions?
fcbflyer is offline Find More Posts by fcbflyer
Contest Combat 3rd Annual Blue Mesa(willow Creek) snakecrew Slope 67 Jun 21, 2012 08:38 PM
Yippee! New Spot Discovered "Willow"!!! Warning, Lots of Pics! Drew360 Slope 62 Mar 09, 2006 03:41 PM
Discussion Possible NW site in Willow Springs dmh Chicagoland Slope Flyers 9 Jan 10, 2006 09:23 AM
Indoor Fly-in March 13th in Willow Park Texas ! ronin8451 Electric Flight Events 7 Mar 15, 2004 09:09 AM
Willow River State Park Karl B≤ Aerial Photography 13 Feb 16, 2004 06:41 AM
