Old Feb 22, 2012, 04:43 PM
rshep is offline
Find More Posts by rshep
crashology student
Ontario, Canada
Joined May 2008
Otto, that was worth the 1000 words.
rshep is offline Find More Posts by rshep
Old Mar 04, 2012, 03:58 PM
gaz9697 is offline
Find More Posts by gaz9697
West Midalnds UK
Joined Dec 2009
got a 1600kv motor 10 amp esc and 3cell 25lipo gives 67 watts.6 amps 5x5prop
My dude weighs 250g AUW will this be okay or should i get a higher kv motor to and small er prop on 2cell to reduce the weight???
Thanks guys great plan and looks great will load phot when finished
gaz9697 is offline Find More Posts by gaz9697
Old Mar 04, 2012, 04:30 PM
danford1 is offline
Find More Posts by danford1
Innovator
danford1's Avatar
United States, MI, White Lake
Joined May 2011
I built a 31" birdofplay kit and decorated him like a prisoner/convict so the superheros would have someone to chase. I'll call him a Jail Bird.
Here is a video of the 3rd flight. I'm still making trim changes to him but in the video you can here I give him full power to launch then pull back power and he flies fine at part throttle - indoors. The last part of the video is zoomed in on him which is nice.
Flying outside would probably require me to push the throttle up higher.
jailbird (3 min 9 sec)
I'm running a Turnigy Park 250 2200 kv motor on 2 cells with a GWS 5x4.3 prop. About 41 watts.
It has plenty of power. I was worried it wouldn't be enough but gladly I worried for no reason.
Is your motor and prop already mounted? If so, hold him straight up and give it full power. If it feels like it wants to fly out of your hand or is even neutral like it would hover, then it has enough power to fly.
I find that he is pretty easy to fly/control just takes a bit of concentration to fly as it isn't shaped like an airplane. Flying in close is fine but once he is flying further away, it is harder to orientate. My observations, yours may be different.
Do you have any way to measure the thrust output of the motor, prop, battery combo you have? If you have as much thrust as he weighs, he will fly. If you have more thrust than he weighs, he will have some vertical performance :-).
My jail bird weighs 5.4 ounces (AUW) and has 7 ounces thrust. Flies fine at part throttle.
250 grams is equal to 8.8 ounces. If your combo produces 8.8 ounces or more thrust, you will be fine.
Danford1
danford1 is offline Find More Posts by danford1
Old Mar 04, 2012, 07:34 PM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
I think you'll be ok. Just get the CG and control throws right.
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Mar 05, 2012, 01:03 PM
gaz9697 is offline
West Midalnds UK
Joined Dec 2009
Danford i calculate yours is equal to 120 watts per pound. which is about the same as me on the lower KV but 3 cell. I should be fine. Will update you when i get to fly
Old Mar 05, 2012, 01:09 PM
danford1 is offline
Innovator
danford1's Avatar
Joined May 2011
Yes, please do up date us. If possible take a video :-)
Danford1
Old Mar 12, 2012, 02:31 AM
gaz9697 is offline
West Midalnds UK
Joined Dec 2009
Fly guy maiden flight (2 min 14 sec)
Produced 130 watts for 220g in the new motor . That's 260 per lb !!!! Yikes I forgot to stick the servi I and it worked loose hence the interesting flight . But none the less it was great .
Old Mar 12, 2012, 09:02 AM
Joined Aug 2011
http://www.youtube.com/watch?v=E4VT9n6A_Ho&sns=em
He looks great in the air. Great video. Will add you to the flying list.
Old Mar 12, 2012, 09:56 AM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
So is he Mr. Incredible too? Can't tell from the video.
Pete
Petefoss is online now Find More Posts by Petefoss
Old Mar 12, 2012, 03:04 PM
gaz9697 is offline
West Midalnds UK
Joined Dec 2009
No. I have created a superhero . He is called baconboy!! He can make 15 rolls in a minute( bacon rolls ) we are a small group of 4 guys who meet upand before flying get the mini camping stove out and have breakfast together hence baconboy came to the build. He is our hero . I have a buddy who was impressed with the design he has built superman.
Old Mar 12, 2012, 04:02 PM
Joined Aug 2011
Baconboy will be added to the list. Is you friend's flying yet. If so, need his name to add him to the list. An RC Breakfast Club...... with a Flyguy flashmob, cool.
Old Mar 14, 2012, 11:13 AM
glue hand brian is online now
Find More Posts by glue hand brian
glue hand brian's Avatar
United Kingdom, England, Uxbridge
Joined Jan 2012
cool a fellow brit in the air, looking good, what did you use to paint baconboy?
glue hand brian is online now Find More Posts by glue hand brian
Old Mar 15, 2012, 02:46 AM
gaz9697 is offline
West Midalnds UK
Joined Dec 2009
I used some acrilyic paint in tubes widely available. Although it costs 7 for 12 tubes of 12g from tesco, I found that Home bargains sell 12 x 18g for .99 or a large tube about 100ml for 2. It does a good job and i just used a sponge to apply. ( Cut one of the new dish washing sponges up. made feathering ing the face a bit easier.
Would probably like to build the 61 inch next. looking at the figures on the video I could use the same power plant as it gives 200watt and 385 watts. Is that total or per pound???
Old Mar 15, 2012, 03:27 AM
Joined Aug 2011
That is input watts. >300 watts really makes the 61" fun.
Old Mar 15, 2012, 05:13 AM
Joined Jan 2012
cheers mate, i was hoping there was a cheaper solution than buying them tiny spray cans..
Build Log Build: Birdofplay 62" Flyguy Otto Dieffenbach Foamies (Scratchbuilt) 432 Dec 23, 2015 09:03 PM
Help! 31" prather hull build jose77 Racing Boats - Electric 3 Oct 16, 2011 04:24 PM
