Joined Aug 2011
Build: Birdofplay 31" Flyguy
History: Flyguy came to being after a visit to my local hobby shop where one of the workers showed me a 30 second clip of an RC flying man. I decided I wanted to design and build a flying person while keeping it inexpensive, simple to build and easy to fly. The design has 11 Depron parts and on the larger versions some plywood bracing and 4 carbon fiber stiffeners. Flyguy can easily be built in less than 10 hours and I have built one in as little as 5 hours, with precut parts.
This Build Log is a “how to” step by step process of building a 31” Flyguy using the Birdofplay 3mm Depron cutouts available from Northwest Cutout Service. His website is balsabuddies.com. The plans are also available on the Flyguy discussion thread and are posted here. This build is a first trial of the cutouts. Modifications I mention in the build log should be incorporated in the actual cutouts and plans. With the tabs/slots, it is easy to trial fit every step and is recommended. I will be using only hobby store available parts to complete Flyguy. Recommended power is 50 to 75w. 50w provides good, advanced trainer performance, while 75w provides unlimited vertical capability. I will be bracing Flyguy31 for up to 75w of power. The Flyguy62 Build Log covers how to personalize the head graphics and is good recommended reading as is the Flyguy46 Build Log. If you follow this process, you will have a durable Flyguy that will fly well. Flyguy Discussion Thread: http://www.rcgroups.com/forums/showthread.php?t=1505753 Happy flying.
Flyguy31 as Superman.
Flyguy31 as Superman with Cape
Flyguy Flash Mob in HD (may take some time to load but worth a look). http://www.youtube.com/watch?feature...&v=Bfhp01NWQeM Step 1 Flyguy is not a slow-fly plane like most Depron foamies; he is more like a balsa shoulder wing trainer. Make sure you do not reduce the prop pitch for slow-fly; he needs to move through the air for effective control. What you will need. Feel free to substitute with equivalent: Electronics A Transmitter that can mix Elevator and Ailerons, Pitch and Roll, for elevons (most have this feature) Hobby King AX 1806N 2500kv motor 10 amp ESC 50w: 2s 450mah 25c battery and GWS 5x4.3 prop 75w: 3s 450mah 25c battery and GWS 4.5x3 prop 2- HXT 500 servos Spectrum clone parkflyer receiver Airframe balsabuddies.com 31” Flyguy or hand cut one from plans Dubro hinge tape for electric planes Music wire 1mm Foam Safe CA with accelerator 5 minute epoxy Foam mounting tape Tools Sharp knife Razor saw Sanding block with 150 grit paper Flat table/work bench Small Philips head screwdriver Pliers and wire cutters T-pins or equivalent Small file or nail file (to bevel identified slots) Here are a full sized PDF set of plans, not a tiled version. Tiling can be accomplished with either Adobe X or Bill Segraves' ScaleAndTile3 software. |
| Thread Tools | |
| Build Log Build: Birdofplay 62" Flyguy | Otto Dieffenbach | Foamies (Scratchbuilt) | 408 | Apr 22, 2013 01:14 PM |
| Help! 31" prather hull build | jose77 | Racing Boats - Electric | 3 | Oct 16, 2011 04:24 PM |
