Old Jun 08, 2012, 07:06 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Channel assignment is something found on the higher end spektrum radio like the DX18 & DX10t. Not found on the DX7s and DX8
freechip is offline Find More Posts by freechip
Old Jun 10, 2012, 06:23 PM
skymaxy is offline
Find More Posts by skymaxy
Gentlemen, start your engines.
skymaxy's Avatar
Australia
Joined Jun 2011
Thanks for a good review but you did cause me some confusion when in your photo caption on the SD Card use you said.
"From this screen I can import a saved model program to the card and from there to my computer or another transmitter."
The Manual says "Export" to the SD Card which is the normal term used when copying data from the original device to another device.
BTW you need to create a folder ("mymodels" or something), on the SD Card first so you can select the destination file when prompted.
skymaxy is offline Find More Posts by skymaxy
Old Jun 10, 2012, 06:55 PM
skymaxy is offline
skymaxy's Avatar
Australia
Joined Jun 2011
internal timer
The "internal timer"at the bottom of the Timer screen is clocking up "Flight Time" whenever I have that model selected even though the Throttle is set to activate the Timer only at 25%.
How can I reset this and make it only add flight time when I am flying?
There's nothing about this in the manual on Timer section.
Old Jun 10, 2012, 08:43 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
You CAN'T, it's function is to count the over all On time you were on that model. You can reset the internal timer but you can't set it that it only adds total flight time.
Old Jun 10, 2012, 10:32 PM
skymaxy is offline
skymaxy's Avatar
Australia
Joined Jun 2011
Thanks, I've got a feeling this is a stupid question but what use is knowing how long you have that model Selected?
Since you spend more time programming/adjusting than flying.
Old Jun 11, 2012, 05:39 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Shows how much time you had the radio on that model.
Once programmed, my flying the model eventually surpasses the programming time. So I don't spend more time programming/adjusting than flying BUT understand what you are saying and don't know the answer to that one.
Old Jun 11, 2012, 05:56 AM
skymaxy is offline
skymaxy's Avatar
Australia
Joined Jun 2011
Shows how much time you had the radio on that model. Once programmed, my flying the model eventually surpasses the programming time. So I don't spend more time programming/adjusting than flying BUT understand what you are saying and don't know the answer to that one.
The programming takes almost no time, It's because I have made significant Undercarriage and other mods which have required the plane to be on the Bench with everything switched on for longish periods.
Now I'm done I guess I will re-set it and estimate the previous actual Airtime.
Old Sep 19, 2012, 07:07 AM
Desert flier is offline
Find More Posts by Desert flier
Desert flier's Avatar
Australia, SA, Morphett Vale
How hard is it to change from mode 2 to 1 on a dx7s thinking of buying one but wrong mode for me
Desert flier is offline Find More Posts by Desert flier
Old Sep 19, 2012, 07:26 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Programming is very easy to change modes. Hardware is also fairly easy if you can follow instructions from the manual.
Have a look at the manual online and go from there.
What maybe easy for some could be hard for others.
Old Feb 05, 2013, 05:10 AM
Ec130b4 is offline
Find More Posts by Ec130b4
ec130
Ec130b4's Avatar
So.Cali usa
Joined Mar 2009
Hi I got my new Dx7s & AR8000 an I did my first long fpv flying up to 3,360ft away check out my video ec130rhine...what the max range it can go anyone ?? I flying a quadcopter with naza & GPS so if I go out of range it will rth!
Ec130b4 is offline Find More Posts by Ec130b4
Old Feb 05, 2013, 07:42 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Nobody publishes a "range" because it depends so much on installation, environment, terrain, etc. but in SoCal you're probably in about as ideal a place as you can find for long range. Sounds like fun!
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Feb 05, 2013, 07:55 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by Ec130b4 View Post
<snip> I flying a quadcopter with naza & GPS so if I go out of range it will rth!
you set the receiver in preset Failsafe and did the extra step during binding?
Old Feb 07, 2013, 06:13 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
New DX7s user here. I agree the manual is not very good. The hardware is pretty good except for two things.
1. No backlight on the display. I knew that before I bought it but didn't realize how important it is. Would it be possible to retrofit a backlit display?
2. My fingers are very smooth and I have trouble with the roller. I did find a technique that helps some. That is to roll only on the bottom half so that I can put on more pressure without triggering the switch. But it is still a pain. Has anyone tried applying some contact cement, or something similar, to the surface or the grooves to make it easier to grip?
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Feb 07, 2013, 07:33 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
LCD backlight kits are available from various sources and varying prices from 10$ to 60$.
I tried PlastiDip my roller on the DX8 once and didn't like the finished look but this could of been the results of my first time using the product and how picky I am with my things.
Old Feb 07, 2013, 07:51 AM
USA, GA, Marietta
Joined Aug 2005
Did you remove the roller to apply the PlastiDip? Any problems other than the look?
Do you have any links to the backlight kits?
Glen
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 08:34 AM
Discussion How are the DX7s working with the Trex? apt.1 Mini Helis 40 Jun 18, 2007 01:15 AM
Question Are Spektrum DX7s the same around the world... Bosk Radios 6 Feb 16, 2007 09:37 AM
Discussion DX7s backordered from Horizon until 4/22? AndrewsJr Radios 18 Feb 13, 2007 06:44 PM
