Old Mar 25, 2012, 03:52 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Yes & No - When charging the lipo pack for the DX8 the charging system will terminate the charge when the pack reaches full. But then follow Lipo Charging Safety Recommendations you should never charge unattended so your comment of Charge and forget it deal really isn't good practice.
freechip is offline Find More Posts by freechip
Old Mar 25, 2012, 06:18 PM
bjaffee is offline
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
Point taken...though you'd hope that the charging was at least as safe as any other consumer electronic device (cell phone, lap top, etc) that used LiPos, as opposed to charging a flight pack with a battery charger.
bjaffee is offline Find More Posts by bjaffee
Old Mar 25, 2012, 10:37 PM
Michael Heer is offline
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
TO KINGSFLYER
I checked this out and then got sidetracked and never posted.
If you are using the throttle up 25% or more to start your timer it stops timing when you lower the throttle back below 25%. There is a click sound to let you know this has happened. When you bring the throttle back up the timer resumes where it last stopped. I hope that answers your question. Mike Heer
Old Mar 25, 2012, 11:01 PM
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
Originally Posted by Michael Heer View Post
TO KINGSFLYER
you can set it so its starts the first time only and stays running even if lowered under 25% again or for e power models have it stop when it is lowered under 25%
Elios000 is offline Find More Posts by Elios000
Old Mar 26, 2012, 12:00 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
I would love to know if Spektrum were going to revamp the old DX6I also ???
Kris... is offline Find More Posts by Kris...
Old Mar 26, 2012, 12:38 AM
grumpy42 is offline
Find More Posts by grumpy42
grumpy42's Avatar
Canada
Joined Aug 2004
Since the charge rate is only 200mah it is highly unlikely that the LIPOs would suffer a catastrophic failure (barring anything extraordinary). Besides, it is rather unreasonable to expect one not to leave the radio unattended for 20 hours (the time required to fully charge the LIPO). Much of the warning verbiage is just to mitigate any potential liability. It does seem odd that these new radios do not support any form of fast charging (all my other consumer electronic devices do). A moderate 1A charge rate would have yielded at 4hour charge time when using the LIPO (two hours for the NiMH).
If you want charge and forget simplicity, the LIPO is really your only option. The NiMH requires "special" attention.
grumpy42 is offline Find More Posts by grumpy42
Old Mar 26, 2012, 04:56 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Smart charging systems have been around since the late 90s. They were specifically designed to allow different types of battery to be charged correctly from the same charger, why is it that Spektrum chooses not to use this technique.
A.
AndyOne is offline Find More Posts by AndyOne
Old Mar 26, 2012, 07:33 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I like to land with a little power on to make the prop act like an airbrake. With the throttle timer beeper, I know exactly when the motor starts for this purpose, without guessing.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Mar 29, 2012, 12:56 PM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
If you are using the throttle up 25% or more to start your timer it stops timing when you lower the throttle back below 25%. There is a click sound to let you know this has happened. Mike Heer
Thanks Mike. That's exactly what I was hoping would happen. That makes this TX a great choice for electric powered planes.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Mar 31, 2012, 09:33 AM
Dave Bee is offline
Find More Posts by Dave Bee
Dont be a gashole fly electric
Dave Bee's Avatar
Chaplin,Ct.
Joined Nov 2005
I really like my DX7S alot....My next step is to get the lip battery.
Dave Bee is offline Find More Posts by Dave Bee
Old Apr 01, 2012, 02:33 PM
Mattacks is offline
Find More Posts by Mattacks
Mattacks's Avatar
Joined Aug 2011
The lipo battery could be better because of the higher capacity for its size but I haven't seen enough benefits in using lipo batts in Tx's to switch over to them. For now I'll be sticking with NiMh packs in my Tx. As long as you have a decent computer charger, using NiMh should not be a problem. I don't waste any time using the included trickle chargers that come with the Tx's.
Mattacks is offline Find More Posts by Mattacks
Old Apr 06, 2012, 01:12 PM
RM_Sparks is offline
Find More Posts by RM_Sparks
We Do It With FRQZ
RM_Sparks's Avatar
United States, CA, San Diego
Joined Aug 2009
noted
RM_Sparks is offline Find More Posts by RM_Sparks
Old Apr 06, 2012, 09:40 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
A.
Cut, strip, solder, shrink ....... solved.
phoenixheli is offline Find More Posts by phoenixheli
Old Apr 06, 2012, 10:23 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
On the timer, the default setting for start and stop is 25% but you can set it wherever you want. I like mine to come in a little lower, so have it set at 17 %.
Gord.
Old Apr 09, 2012, 03:53 AM
moroz is offline
Find More Posts by moroz
Russian Federation, Sverdlovsk Oblast, Yekaterinburg
Joined Apr 2012
good
moroz is offline Find More Posts by moroz
Question Speculation on new Dx7s? spython Radios 1 Oct 01, 2008 08:34 AM
Discussion How are the DX7s working with the Trex? apt.1 Mini Helis 40 Jun 18, 2007 01:15 AM
Question Are Spektrum DX7s the same around the world... Bosk Radios 6 Feb 16, 2007 09:37 AM
Discussion DX7s backordered from Horizon until 4/22? AndrewsJr Radios 18 Feb 13, 2007 06:44 PM
