This thread is privately moderated by brn2fly, who may elect to delete unwanted replies.
Old Jan 23, 2012, 02:51 PM
brn2fly is offline
Find More Posts by brn2fly
Trader Rating: 23
United States, FL, Hobe Sound
Joined Jan 2006
Trader Rating: 23
Sold
HPI Baja 5T and many extras
I have a 5T which I built in 2009; only run a few times. Here is what comes with the truck:
Orange Painted Body
Futaba digital S5050 steering servo with alum arm
Turtle Racing Clutch assembly and housing
RD Logic Tuned pipe
Header for Tuned pipe
Pico Safety/Kill switch
DDM 4200mah receiver pack
DDM Air Filter and Engine covers
Upgraded Aluminum X brace and Shock tower mount (both on the front end)
Desperado Wheels with stock fronts and RC4WD Ruff Riders
Aluminum Steering Bell Cranks
1 extra Futaba S5050 Servo
1 Futaba S5050 Gear set NIP
1x Dog bone
Lots of plastic pieces, screws, bolts, and nuts that are not listed but will be included with the truck.
All above for $900
Extra Parts for sale:
CY 27 It has two bolts holding the cylinder on. $115
1 new sets of stock tires/wheels/foams $100
1 Clear Body $125
1 set new un-mounted front tires $25
2x HPI 85402 Rear Arm Set (one open one NIP) $15ea
2x HPI 85400 Front Arm Set (one open one NIP) $17ea
2x HPI 85462 Throttle Linkage (one open one NIP) $12ea
HPI 87193 Bevel Gear Differential Conversion Set NIP $12
HPI 15481 Exhaust Gasket NIP $6
HPI 15464 Carburetor Gasket Set NIP $7
HPI 86469 Wheel Hex Hub (Purple) NIP $28
HPI 86465 24mm Front Hex Hub (Purple) NIP $34
HPI 87493 24mm Front Hex Hub (Orange) (packaged opened to verify that they are the right size) $34
HPI 87495 Wheel Hex Hub (Orange) (packaged opened to verify that they are the right size) $28
HPI 15449 Clutch Spring 8000prm/Red NIP $8
HPI Z106 E Clip E-7HD NIP $6
HPI 86630 Driver Gear Shaft $12
HPI 86488 Drive Axle 22x68 $35
HPI 86479 Axle Boot 22x47 $6
1x Complete rear end overhauled like new $130
1x Clutch bell $20
1x stock pinion $6
11x Bearings for wheel hubs $5ea
2x new clutch shoes with red spring $40ea
1x Spare rear purple shock $12
Coil for engine $10
1 set of rear hex hub and 2 sets or front hubs that where milled wrong from HPI $35
1x used Pull Start $15
1x Bell Housing $20
1x flywheel to mount clutches on $10
All prices except the 5T truck include shipping. The truck shipping will be paid by the buyer. Please ask any questions. Thanks for looking. Will sell all for $1500 shipped
brn2fly is offline Find More Posts by brn2fly
Old Jan 24, 2012, 10:43 AM
Hoban Washburne is offline
Find More Posts by Hoban Washburne
Trader Rating: 8
Leaf On The Wind
Hoban Washburne's Avatar
United States, WI, Green Bay
Joined Dec 2011
Trader Rating: 8
Is the clear body a spare, stock 5t body or is it something different like a proline body? Is the ignition coil, new or used?
Also, if the spare engine is the stock engine then it would be 26cc, but there's also a way that you can check to make sure. If you look just below the coil on the skirt of the cylinder head, you'll see two numbers stamped into the metal separated by a dash. The first number is the stroke (probably 28mm). The next number tells you displacement in mm. 34mm is 26cc, 35mm is 27cc. Just in case you didn't know.
Hoban Washburne is offline Find More Posts by Hoban Washburne
Old Jan 24, 2012, 06:26 PM
cummins1 is offline
Find More Posts by cummins1
Trader Rating: 0
United States, MN, Prior Lake
Joined Oct 2011
Trader Rating: 0
Hpi
Would you be interested in trading?
cummins1 is offline Find More Posts by cummins1
Old Jan 28, 2012, 06:12 AM
GP racer is offline
Find More Posts by GP racer
Trader Rating: 0
Joined Oct 2011
Trader Rating: 0
It looks like it doesn't have a serial number I'm the battery box top,that usually indicates that its a clone of knockoff not a true hpi baja its probably a king motor rovan.
GP racer is offline Find More Posts by GP racer
Old Jan 28, 2012, 10:28 AM
Trader Rating: 8
Leaf On The Wind
Joined Dec 2011
Trader Rating: 8
I was looking at maybe getting some of the parts, but I haven't heard anything from the OP. If this is what communication is going to be like, I'm not sure I want to deal.
Old Jan 28, 2012, 01:02 PM
brn2fly is offline
Trader Rating: 23
Joined Jan 2006
Trader Rating: 23
The body is an aftermarket one not a HPI or Proline. Not sure who makes anymore.
The coil is used.
Thanks for the info on the engine. Its a 35 so I guess the engine is a 27cc.
Andy
Old Jan 28, 2012, 01:05 PM
brn2fly is offline
Trader Rating: 23
Joined Jan 2006
Trader Rating: 23
It is not a clone as I built this from a extra parts and added all the upgrade parts. The battery is HPI 85404 which does not come with a serial number on it.
Andy
Old Jan 28, 2012, 01:10 PM
brn2fly is offline
Trader Rating: 23
Joined Jan 2006
Trader Rating: 23
I have added instant notification so I will know when someone leaves a post here. Sorry for not answering the previous post quickly buy i did not have the email notification on.
Andy
Old Jan 28, 2012, 01:31 PM
Trader Rating: 8
Leaf On The Wind
Joined Dec 2011
Trader Rating: 8
Is the "1x flywheel to mount clutches on $10" a flywheel or a clutch carrier? I ask because I'm not seeing either one in your pictures.
Also, is the CY 27 new or used?
Old Jan 29, 2012, 11:15 AM
brn2fly is offline
Trader Rating: 23
Joined Jan 2006
Trader Rating: 23
The "flywheel" is what the clutch shoes that mount on. It is mounted to the engine loosely. The CY27 is a fresh overhaul.
Andy
Sold HPI Baja 5t Body, Pro-Line VW Baja Bug Body ronzer Cars - Trucks and Parts (FS/W) 0 Jan 21, 2012 08:14 PM
Sold hpi baja 5t with extras $850 shipped for all come see. fgbasher Cars - Trucks and Parts (FS/W) 6 Oct 23, 2011 08:32 PM
For Sale HPI Baja 5B, 5T, 5SC Electric Conversion Lipo's Raydee Aircraft - Electric - Batteries & Chargers (FS/W) 8 Jul 23, 2011 09:49 AM
Sold Jetpto Gargantuan Pipe for HPI Baja 5T Steph280 Cars - Trucks and Parts (FS/W) 1 Mar 20, 2011 11:12 PM
Discussion ***Win a $10,000 HPI Baja 5T at RCX*** LOST IN MN Car Talk 8 Mar 11, 2011 05:04 PM
