Old Feb 18, 2012, 08:35 PM
labrown is offline
Find More Posts by labrown
SSP ASP#88
labrown's Avatar
United States, PA, Hatfield
Joined Apr 2009
Thermal:
Lance Brown (labrown)
Glider name: Radian
Thermal or Slope: Thermal
Date and Time of flight: February 18th 2012, start of flight 3:25PM Eastern
Duration of flight: 18:32 (30 sec / 200M CAM limiter)
Weather: partly cloudy, 0-3mph breeze at ground, faster above
Slight wind at ground level, but good breeze at height, enough to let me pretty much just surf the wind most of time. Radian barely penetrated. Today was my first experience catching a thermal as well! I had two shorter flights (14:21 and 12:18) where I launched, did my best to stretch the flight, and then hit a thermal coming off the center of the field when I was about tree top height. Turned into it and the Radian went up like an elevator both times. Ugliest thermal turns I've even seen! :-) Watching my plane going up like that was a real rush.
labrown is offline Find More Posts by labrown
Old Feb 19, 2012, 08:37 AM
JumpySticks is offline
Find More Posts by JumpySticks
Drifting off the reservation..
JumpySticks's Avatar
USA, LA, Broussard
Joined Jan 2011
Originally Posted by labrown View Post
Thermal:
Glider name: Radian
Welcome to the contest Lance.
Careful, it's habit forming!
JumpySticks is offline Find More Posts by JumpySticks
Old Feb 20, 2012, 08:10 PM
USA, LA, Broussard
Joined Jan 2011
JumpySticks
Plane: Radian pro
Date: 2/20/12
Time: 11:00 am
Duration of flight: 11:21
Still a little windy for steady thermal action today.
Old Feb 20, 2012, 11:33 PM
RTF Thumper is offline
Find More Posts by RTF Thumper
Big Jim
RTF Thumper's Avatar
United States, ID, Mountain Home
Joined Jun 2011
Way cool love the googel earth view hope to do the same this week
RTF Thumper is offline Find More Posts by RTF Thumper
Old Feb 21, 2012, 03:25 PM
USA, LA, Broussard
Joined Jan 2011
Much less wind today. Thermals were moving about.
JumpySticks
Plane: Radian pro
Date: 2/21/12
Time: 1:30 pm
Duration of flight: 21:48
Old Feb 22, 2012, 12:02 PM
USA, LA, Broussard
Joined Jan 2011
NOTICE: For the March contest, the motor run will be shortened to 30 seconds max, to fall more in line with standard ALES limitations.
That will put me at a distinct disadvantage with my stock Radian Pro, but it's best for those who may want to eventually move up to ALES competition.
Maybe it's time I repowered???
Old Feb 22, 2012, 02:59 PM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
Do I remember correctly that you are using the stock prop/spinner JS? I use a 50mm BB Aluminum spinner and 11x6 Graupner blades on my RP and it makes 200m in 30 seconds no problem; 25 seconds if I don't range upwind after launch. I'm using all the other stock power components.
I can't catch a break wind-wise, the daily average is 15-20mph with no relief in sight. I have had the chance to fly an ALES comp inland, but with assigned tasks of 6-8 min there's no use posting those flights here, as I didn't get the chance to go for maximum duration. I just can't get away from the wind long enough to actually do a dedicated duration flight! Maybe March will be better?
I'm going to travel to one of the only "drive up" slope sites in the area tomorrow, maybe I can get a slope time posted, but I'm told the wind has been running the wrong direction at that slope lately, so I'll just have to show up and see what the conditions are. I'm taking every flyable sailplane, powered & non-powered both, that I have with me; maybe I'll get lucky?
Sonny
sonny1 is offline Find More Posts by sonny1
Old Feb 22, 2012, 05:47 PM
USA, LA, Broussard
Joined Jan 2011
Sonny
Good luck on the slope Sonny!
With the March winds coming, I sure wish I had a slope around here.
Old Feb 22, 2012, 06:10 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Here's a Google Earth link to the site. Where the cultivated fields end, there is a 500' sheer bluff going straight up to the dirt road at the top next to the edge. Absolutely beautiful view out over those fields to the sand dunes and ocean beyond, but it's south facing and the wind is normally from north/west, sometimes even blowing straight away from the mesa. In the fall/early winter though it rocks, as storms usually come straight in from the south. Never had so much fun crashing planes in my life, (it develops a wicked rotor 20' back from the lip; a real plane killer in 30+ winds), but when flying a dedicated slope plane it's a blast. I might try the RP there no matter where the wind is because I can motor back if needed, but for a non-powered sailplane that can become an issue because if you loose lift and end up at the bottom, you have to drive back around and down the mesa through the fields below to retrieve your plane, (you'd need climbing ropes to go down the bluff). I'll report back, I gotta go there anyway, so I may as well try.
Sonny
Old Feb 22, 2012, 07:50 PM
USA, LA, Broussard
Joined Jan 2011
Sonny
Your winds look North-Northeast for tomorrow. If you had our wind forecast you'd be in great shape, southerly 15-20.
Neat flying location for sure.
Old Feb 22, 2012, 08:41 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
That would be perfect there. The wind comes up that sheer cliff like few other places I've seen when the wind is right. When the south winds blow you have to fight for space, the ridge will usually be lined with pilots from all over, and the word spreads quickly when it's working. However, since the wind will be opposite tomorrow I'll take the RP out anyway and see if the flat farmlands below are warming up enough to throw up some lift, or if not there's plenty of room behind the bluff to fly TD, (I hope, maybe if the wind isn't howling too much...which is always possible here).
Sonny
Old Feb 23, 2012, 07:27 AM
chickenwing is online now
Find More Posts by chickenwing
More Altitude, Less Attitude!
chickenwing's Avatar
United States, SC, Ninety Six
Joined Mar 2008
sonny1,
Here is a site that I use for wind forecast. I find it pretty accurate for the most part. It is set for San Luis Obispo, CA, which I think is close to the location on your avatar. You can change the location if you can find one closer.
Aviation Weather Forecast at San Luis Obispo, California
chickenwing is online now Find More Posts by chickenwing
Old Feb 23, 2012, 11:33 AM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Originally Posted by chickenwing View Post
sonny1,
Thank you! I bookmarked that link, but the site is closer to Santa Maria so I changed it to that location. SLO is near my home, but the site is 40 miles south and right off the ocean, so I sometimes use Wind Guru: http://www.windguru.cz/int/index.php?sc=194424, which is similar to the link you posted, and is often used by hang gliding enthusiasts. It's nice to have several sources of weather data, so thank you again. Nice thing about Wind Guru is you can plug in the GPS coordinates and it will tailor the forecast to that spot.
I'm heading out the door, so I'll report back later. Good air everyone!
Sonny
Old Feb 24, 2012, 09:07 PM
mulgaman is offline
Find More Posts by mulgaman
mulgaman's Avatar
Australia, QLD, Charleville
Joined Aug 2011
PB, self disqualified attempt
Weather has been poor this month so far, still windy today though did get a PB for time and altitude. Disqualified due motor overun. Have to learn to count faster
Nine Eagles Skyclimber running a 11 x 6 Graupner Cam folder
2200 mah PA 3S
19:40
Charleville
Australia
mulgaman is offline Find More Posts by mulgaman
Old Feb 24, 2012, 10:23 PM
USA, LA, Broussard
Joined Jan 2011
2200 mah PA 3S
19:40
Charleville
Australia
Looks like a good time was had, in spite of the DQ.
2400'....man that's way up there.
Thanks for the plot.
What logger do you use?
Swap Meet February 17-18, 2012-Garden Ridge, Texas-Tri-City Flyers R/C Swap Meet Richard N Fuel Power Events 6 Feb 16, 2012 11:55 AM
Swap Meet February 17-18, 2012-Garden Ridge, Texas-Tri-City Flyers R/C Swap Meet Richard N Electric Flight Events 14 Feb 16, 2012 11:54 AM
Cool Central Florida FPV Meet February, 25-26 2012 realtvnow FPV FPV Talk 13 Feb 12, 2012 06:51 AM
Discussion Denver International = 2012 ? realtimerecon Chit Chat 5 Jan 16, 2010 09:28 PM
