Old Jan 31, 2012, 10:51 AM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
I'm trying to calculate wind loading, but the specs on wing area is somewhat confusing:
Spec.
Material: Pre-covered Balsa/Ply
Wing Span: 1600mm
Length: 1200mm
Flying Weight: 1900g~2000g
Wing area: 44~47g dm/2
Wing Area: 42.8g dm/2
4 Channel (throttle, aileron, elevator, rudder)
what is correct for the wing area?
rcalldaylong is offline Find More Posts by rcalldaylong
Old Jan 31, 2012, 11:27 AM
flyinwalenda is offline
Find More Posts by flyinwalenda
EIEIEIO Classic is dway ta go!
flyinwalenda's Avatar
Northeast Pa. .Heyna or No?
Joined Aug 2009
Not having to wing to measure and calculate the area I can only offer a guess. I would say based on other cubs of similar size, the area listed at 42.8 is close but will probably be more like 43.(something).
flyinwalenda is offline Find More Posts by flyinwalenda
Old Jan 31, 2012, 02:13 PM
pilot815 is offline
Find More Posts by pilot815
United States, TX, Pharr
Joined Dec 2011
Got my cub in the mail today. Look forward to building it, but need to take care of some other projects in the shop before I start this one.
pilot815 is offline Find More Posts by pilot815
Old Jan 31, 2012, 08:11 PM
Joined Dec 2007
Spec.
Wing Span: 1600mm
Length: 1200mm
Ok. I kinda answered my own question, but I looked at the box, and wing area is 42.8 dm/2, and the wing loadijng is 44-47g dm2. Obviously HK's site just has a misprint.
I don't really see how they can build this plane up and be have an AUW of 1900g-2000g though
Old Jan 31, 2012, 08:15 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Got mine, but one of them has a cracked cowl, not sure how I'm going to deal with hobbyking on this, I sent an email, but no responce
3drcparts is offline Find More Posts by 3drcparts
Old Jan 31, 2012, 08:32 PM
Joined Aug 2009
If they are blowing these out of inventory chances are they don't have parts for them.................if they ever had parts for them. Just glue it then get some lightweight glass cloth and epoxy and lay it on the inside. Sand,fill in the crack, sand prime and paint it.
Old Jan 31, 2012, 09:12 PM
UCPILOT110 is online now
Find More Posts by UCPILOT110
UCPILOT110's Avatar
United States, TX, Universal City
Joined Jun 2011
My cub
hey guys I beat you getting this bird but at highger cost , I ordered mine before the price drop but very happy with the product I decided to get another one for $50 to my suprise I got the 180 pro heli for free so not a bad thing, My set up Hk 15138 standar servos, a G15 810kv with a 13x6 wood turnigy prop,70A. Detrum ESC(very good ESC for the money have it on all my planes no issues) and I'm using 3300mAh 3s sky lipo batts,I maiden last weekend (sorry no video)my set up its ok but it lacks on power (if you want to do more aerobats.) you can do loops ok but the 35-48 size is too small for this bird I did try to run the same set up with a 2650 mAh 4s but the motor gets hot(not burning hot but more hot than the 3s set up) whats your advise as runing the g15 with my 4s set up. here are some pics btw I did replace the landing gear with the 25e super cub it make look this plane a lot better and you can land on grass with no issues.
UCPILOT110 is online now Find More Posts by UCPILOT110
Old Jan 31, 2012, 09:17 PM
Joined Dec 2007
what's your AUW?
Old Jan 31, 2012, 09:18 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Looks great, nice job on the build, I do think I have to get those landing gears, what tires are you using?
Old Jan 31, 2012, 09:19 PM
killercando is online now
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
Hobbyking don't care, your on your own on this one. Actually that's what I here about all there stuff. If anybody has had good experience with there customer service it would be interesting to hear.
Here is your new cowl. http://parkflyerplastics.com/cart/in...739c74c75832a4
i would tape the broken one for now and make sure you like it before spending money on it.
Here is my beefed up landing gear and progress as of Sunday. Also it balances perfect at 70mm behind leading edge with 4s 5000 battery and .46 motor. I have heard it is best to balance these a bit on the nose heavy side. And from flying the 1.8 meter version I believe it.
Good luck and have fun. I will try to maiden and video tomorrow afternoon.
killercando is online now Find More Posts by killercando
Old Jan 31, 2012, 09:27 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Nice job on the landing gear, I don't have a tig welder, so I thought I'd wrapped the joints with thin wire and epoxy them. I like them painted white
I think your right, no point spending more money until I know I like the way it flys
Old Jan 31, 2012, 09:30 PM
Joined Aug 2009
Well of course it won't have power to do much of anything but barely fly straight. You have a "15" size motor on a "25" size plane. If you are running a 13" prop on the 15 using 4 cells it will burn up....that's too much prop for that voltage. An 11" on the 15 with 4 cells is about the max....maybe a low pitch 12" . Even then the thrust will be slightly more than the planes weight but you will be loosing some low end torque. You are going to need a little bigger motor.
Old Jan 31, 2012, 09:33 PM
UCPILOT110's Avatar
Joined Jun 2011
Im using the stock tires I just paint them silver color, the landing makes a big difference is more strong if you do the mod I recomend to beef up the inside with plywood strips right where the screws attach I did not use blind nuts as the wood is very thin.
Old Jan 31, 2012, 09:35 PM
UCPILOT110's Avatar
Joined Jun 2011
Im thinking of using the eflite 46 but for the money Im leaning to the g32 or 46 maybe?
Old Jan 31, 2012, 09:37 PM
UCPILOT110's Avatar
Joined Jun 2011
what's your AUW?
with all the gear Im close to 5~6 pounds
For Sale SIG Clipped-wing Cub Kit ronrange Aircraft - Fuel - Airplanes (FS/W) 4 Jul 04, 2013 12:27 AM
For Sale Sig Manufacturing Clipped Wing J3 Cub 40 ARF $100 + ship seprice40 Aircraft - Fuel - Airplanes (FS/W) 0 Dec 28, 2011 11:11 PM
Discussion SureFlite clipped wing cub with custom paint DeaninMilwaukee Parkflyers 2 Dec 17, 2011 08:52 PM
Discussion Covering CMP Clipped Wing Cub Willie Everlearn Scale Sailplanes 6 Oct 15, 2011 06:21 PM
Discussion RE: World Models Clipped Wing Cub 1:5 scale StoneGod Scale Kit/Scratch Built 0 Sep 14, 2011 02:42 PM
