Old Feb 10, 2012, 02:29 PM
lrplin is offline
Find More Posts by lrplin
lrplin's Avatar
Stockton CA.
Joined May 2007
Thank you.
lrplin is offline Find More Posts by lrplin
Old Feb 10, 2012, 06:12 PM
732002 is offline
Find More Posts by 732002
732002's Avatar
United States, OR, Lake Oswego
Joined Dec 2003
Originally Posted by gravityking View Post
I
Or does anybody have direct experience with the Hangar 9 HAN4005?
http://www.rcgroups.com/forums/showthread.php?t=1344648
search this, I think this is the same plane clipped/L4/J3
Yes the H9 gear works well.
732002 is offline Find More Posts by 732002
Old Feb 10, 2012, 08:43 PM
gravityking is offline
Find More Posts by gravityking
Demonstrations on Saturdays!
gravityking's Avatar
United States, TX, Arlington
Joined Jan 2012
Thanks digits or BMW fan!
Good enough info to try it, cheap too.
gravityking is offline Find More Posts by gravityking
Old Feb 10, 2012, 08:51 PM
lrplin is offline
lrplin's Avatar
Stockton CA.
Joined May 2007
maiden mine this evening, terrible result. I am an experienced pilot, and I can't believe that I fail on a cub! Once the cub climbed up 2 meters above ground, then it starting to has some nasty un-controllble stall to the right. I try took off twice, both happen the same. The second try end up some damages on the right wing tip and a broken motor mount.
My setup is 4s 2200mah, HobbyKing Donkey ST4010-820kv, 12x4, AUW is 2245g. With this setup, the donkey motor barely supplied enough power. I will change to 13' prop or try the heads-up hobby motor 3542-11 next time.
I need to rebuilt the motor mount tonight, and try to find out what cost the un-controllble right tendence stall.
Old Feb 10, 2012, 08:59 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
are you tail heavy? where is your CG? I thought you weren't going to maiden till monday...I was going to come and maiden mine with you.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Feb 10, 2012, 09:03 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
where was your CG?, sound like it would be underpowered, I'm going to run a 4260-06 with 13x6.5 and 5000mah 4s, 112 oz thrust @ 54 amps (820 watts) Cg is perfect at 70mm back of LG
3drcparts is offline Find More Posts by 3drcparts
Old Feb 10, 2012, 09:05 PM
Joined Dec 2007
That's starting to worry me...I'm only at 63 ounce thrust! But my cub is barely hitting 70 ounces AUW though...
Old Feb 10, 2012, 09:12 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
I always look at watts per pound and like it in the 130-150 range for this type of aircraft, I over power everything, nothing worse than not being able to power out of my thumbs
Plus it is easier to prop down, cell down that change a motor
UCPILOT110 is offline
Find More Posts by UCPILOT110
UCPILOT110's Avatar
United States, TX, Universal City
Joined Jun 2011
Maybe under power set up, batt ok, prop and motor?, the recomended set up calls in for a 13X4 prop, I did run mine with a G15 and a 13X6 with a 3300mAh 3's it lifted the plane fine but I felt it still under powered, Upgrade the motor with a power 32(E-flite) and a will test tomorrow with same prop but a 2650 mAh 4s this time.
UCPILOT110 is offline Find More Posts by UCPILOT110
Old Feb 10, 2012, 09:26 PM
oldfish is offline
Find More Posts by oldfish
FLYING Better Than Drugs
oldfish's Avatar
Thonotosassa, FL
Joined May 2007
MHO I was always told that you should have a least 100 watts per pound. My self I like to go a little beyond that, you don't have to fly at WOT but it sure is nice to have the power when you realy need it.
Bob
oldfish is offline Find More Posts by oldfish
Old Feb 10, 2012, 09:30 PM
flyinwalenda is offline
Find More Posts by flyinwalenda
EIEIEIO Classic is dway ta go!
flyinwalenda's Avatar
Northeast Pa. .Heyna or No?
Joined Aug 2009
A 12x4 prop? That's not enough prop,not enough torque to pull the plane along. It's stalling on you. You don't want top end speed you want low end grunt for a cub.
flyinwalenda is offline Find More Posts by flyinwalenda
Old Feb 10, 2012, 09:40 PM
lrplin is offline
lrplin's Avatar
Stockton CA.
Joined May 2007
Thank you all for these feedbacks. It should be underpower with my setup and cost the stall. I can't cheap on the motors anymore. Need to look for a motor has more "horse power"
Old Feb 10, 2012, 09:41 PM
lrplin is offline
lrplin's Avatar
Stockton CA.
Joined May 2007
My CG is correct. If you are coming on Monday, then it should be fine, cause I have many other planes . but I wont get off from work untill 3:30.
Old Feb 10, 2012, 11:19 PM
lrplin is offline
lrplin's Avatar
Stockton CA.
Joined May 2007
I am going for this motor combo:
http://www.ebay.com/itm/220947042904...84.m1438.l2649
Is that over rated?
Old Feb 10, 2012, 11:35 PM
Joined Dec 2007
Is that over rated?
That motor is smaller than your donkey one. Look at the HK sk3 series around 190grs or so....should be plenty. The donkey should be fine too, just needs bigger prop
For Sale SIG Clipped-wing Cub Kit ronrange Aircraft - Fuel - Airplanes (FS/W) 4 Jul 03, 2013 11:27 PM
For Sale Sig Manufacturing Clipped Wing J3 Cub 40 ARF $100 + ship seprice40 Aircraft - Fuel - Airplanes (FS/W) 0 Dec 28, 2011 10:11 PM
Discussion SureFlite clipped wing cub with custom paint DeaninMilwaukee Parkflyers 2 Dec 17, 2011 07:52 PM
Discussion Covering CMP Clipped Wing Cub Willie Everlearn Scale Sailplanes 6 Oct 15, 2011 05:21 PM
Discussion RE: World Models Clipped Wing Cub 1:5 scale StoneGod Scale Kit/Scratch Built 0 Sep 14, 2011 01:42 PM
