I'm heading on vacation end of week for about 12 days so no posts for awhile.. I have the tank rails in and started the throttle servo so will post pics of all that when i get back. Should start covering soon.
Here's a couple pics from my second build of a "funder and lightning" E project i had going on and off for a couple days. Very popular flier on the E threads. Just need to mount battery and ESC for correct CG. Hitec HS55 servos and pull pull on the elev. Don't think I'll ever be a big electric guy but they are fun to throw together and fly around the school yard when time is tight. |
I couildnt help myself.. i wanted to get some more done!! Building is more fun than packing.
I mounted the throttle servo, ran the pushrod and set it up manually pretty close so throttle setup via the xmittlerwill dial it in. I like to have the arm provide the most movement in the bottom half of the throttle curve so you can get more precise adjustment and have bettter control over rpm at the low end. |
Vacation was great and had a nice day flying the electrics today. The funder above flew well.. just a little sensitive so some setup is still needed. My only glow is a trainer type and well that's like kissing your sister so I want to get this baby done.
Finished the landing gear which needed hardwood addded and final sanded the lower wing. Going to start covereing there as it's the simplest part being constance cord, no alierons, etc. I have the red ultra and silver solartex so I'll be getting started this evening if all goes well... |
Coming out ok.. I thought I had Solartex which I used before but it's 21st centtury which is in my a bit lesser look and a bit more difficult to applyh... but I'm ok with the results so far..... Bottom center wing is silver and will try the colored red tip later on today. My only green is Mono and I'm not going near that. I need to get some green ultrcote.
The bottom wing is coming along.. center silver with red tip on bottom. After working the 21st century prodcut.. it's easier now as I have the hang of it. I thought about the green monokote and it being heavier than ultra I held off and will pick up some green ultracote. With the bottom of both wings getting color I didn't want to have a heavy right side of the aircraft with the color being at the ends of the wing. I plan to pick that up tomorrow.. and will then do the rudder as it disconnects from the fuselage and will be easy to cover being one piece as well.
I didnt want to paint the rudder so I needed to add verticals for the covering to adhere to since there are 3 vertical bars. I'll sand it all up tonight. Forgot the LHS was closed so will pick up green tomorrow and start covering then. Need the green to start as it's in the rear of the rudder with white in the middle and red up front. Starting at the rear allows the seam from the wite to face rearward,, followed by red up front.
"Attempted" to cover the rudder tonight and it came out like crap! I shouldn't have ventrued out to the garage as I got a late start but that's my fault. Going to pull most of it off and add a block behind the main vertical spar aft of the horn to give more landing area for the green and give it another go tomorrow. I didi learn a few things tonight I won't do going forward so there's always a silver lining.
| Thread Tools | |
| Discussion All steel 1/6 scale R/C tank build. Help! | LavaRed | RC Tanks | 19 | Aug 17, 2012 09:25 PM |
| Question BUSA 1/6 Nieuport 17 Plans / Instructions Question | Thermalin | The Builders Workshop | 15 | Jan 08, 2012 10:03 AM |
| Discussion 4-Stroke Saito 50 Powered 1/6 Semi-scale Nitro-Trike Scratch Build Log | CONDOR2 | RC Kites | 0 | Jun 11, 2011 11:34 PM |
| For Sale 1/4 scale busa fokker dr-1 | meihls | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 05, 2011 08:56 PM |
| Discussion busa 1/6 scale pup bottom an top wings incidence | avionette | Electric Plane Talk | 5 | Dec 07, 2007 03:11 PM |
