Old Dec 16, 2012, 07:16 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Originally Posted by Thermalin View Post
...I'm pretty confident i found the issue.
You are pretty confident you found "the issue". Rather than check everything, you assume the job is done. Just cautioning you against assumptions. I'd check all the setup dimensions.
loNslo is offline Find More Posts by loNslo
Old Dec 17, 2012, 05:47 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Resoldered the front left bracket farther down the strut and all is well. All measurements are nearly identical.
Thermalin is offline Find More Posts by Thermalin
Old Dec 29, 2012, 09:21 PM
Thermalin's Avatar
Joined Jan 2005
I had a lightbulb go off on the spreader bar after thinking about it for some time. I didnt care for the wooden spreader with rubber bands on each end at the wheels. I could see it vibrating away in flight. I wanted some thing shock absorbing as far as spreading so what I came up with was a brass outer tube cut in the middle and angled on each end to match the gear. The angle on each end is bolted to the gear down by the wheels. An inner brass tube allows the outer to ride on it and spread and close up again. I added small hooks with thin wire wrap and solder on the outer tube approx 2 inches each side of center. These are connected with the elastic that is used for bracelets and such. This is great stuff....doubled up its much better than rubber bands and without as much give. I have shrink tube over the whole mess and now the gear spreads approx 3/4" with a good tug and comes together nicely again. The elastic is replaceable as well which is nice.
We're off to the Sugar Bowl tomorrow for a few days so when I get back it soldering the plugs on the aileron wires, and finding some type of pilot bust and thats it. After all this I'm almost afraid to fly it but will when the planets are in aligment and the time and weather is right.
Old Jan 09, 2013, 04:21 AM
MerlinV is offline
Find More Posts by MerlinV
Melbourne, Australia
Joined Mar 2009
One thing that has not been mentioned yet (so far as I can find) is the topic of the Center of Gravity.
Have you checked this yet?
Has any extra been needed adding to the nose in order to balance?
Cheers,
Hugh
MerlinV is offline Find More Posts by MerlinV
Old Jan 09, 2013, 07:11 PM
Thermalin's Avatar
Joined Jan 2005
I had it all loaded up except for the pilot and it was smidge tail heavy.... i figured out I need about 2.5 ounces in the nose... and am looking into a weighted hub from harry higley. My last bit of business is a pilot and I originally was thinking of justs chopping a GI Joe type doll at the shoulders but I think that would put me more behing the 8-ball for CG... So I'm looking for a "foam" alternative or similar. To me this plane needs a pilot. Soooo... once i have the pilot bust on board.. I'll recheck the CG and order the correctly weighted hub. Then I;ll have to get up the nerve to take her to the field...
Old Jan 09, 2013, 07:25 PM
loNslo is offline
wood is good
loNslo's Avatar
Joined Jun 2012
How about a stuffed "Snoopy" type character?
Old Jan 09, 2013, 11:33 PM
MerlinV is offline
Joined Mar 2009
OK... So, moving your engine back as you did, the CoG still was not too bad.
Old Feb 10, 2013, 05:16 PM
Thermalin's Avatar
Joined Jan 2005
Apologize for not posting here.... I'm in the middle of fixing up a crashed clipped cub since i'm stuck on the pilot.
I assume if I didnt have to move the motor back the CG would have been good but it didnt affect it much. The only 1/6 scale pilot I have been able to find that isn't $$$ is this gal and she does look the part. Figure I can tie a scarf around her / his neck... darken up the blue jacket with the brown/greyish paint and it'll pass...
http://www.hangar-9.com/Products/Def...ProdID=HAN9115
I suppose if I take off the lipstick and gruff up the face a bit.. who knows... for 7 bucks it's worth a shot so going to order her and see what we get. My daughter who has grown out of dolls, gave me permission to perform a beheading of Ken. He looks a bit to happy to be going off to battle and I have no idea how to get him in some cloths and goggles but placing him in the cockpit has re-ignited my juices to get this bird finished.
Old Feb 13, 2013, 09:04 PM
Thermalin's Avatar
Joined Jan 2005
I ordered this guy
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPZH9
and it's shipped. Going to paint him up and see what happens... I think it will be fun as I never painted a pilot figure before.
Old Feb 18, 2013, 06:08 PM
Thermalin's Avatar
Joined Jan 2005
Started painting the base colors. Painted a silver rim and brown on the goggles.
Old Feb 18, 2013, 10:14 PM
Thermalin's Avatar
Joined Jan 2005
Couldn't stop painting as it was a bit of fun... I think I need to take off some of the "dirt" on the face and fix up the lips just a bit. The goggles need to be shaved just a bit on one side so I can attach to the face better. Had some trouble with the lips getting a good pink... he looked like a drag queen there for a bit. Not to bad though considering I had no idea what I was doing... Some type of scarf should finish him up.
Wondering how to attach him now.. was going to put scruff up the inside and epoxy a thick slap of balsa to the inside base.
Old Feb 20, 2013, 04:36 PM
Thermalin's Avatar
Joined Jan 2005
He's ready for battle...
I used a rubber band for the headstrap and some linen type material for a neck scarf.
Old Feb 20, 2013, 05:32 PM
loNslo is offline
wood is good
loNslo's Avatar
Joined Jun 2012
That really looks good.
Old Feb 22, 2013, 12:59 PM
Thermalin's Avatar
Joined Jan 2005
Thanks...
I think in two weeks I take her up for the first flight. This weekend is bad and next weekend I leave for Brazil for work, back on Friday morning...we'll see.
Old Feb 24, 2013, 04:45 PM
wcessna is offline
Find More Posts by wcessna
Yes my name is Cessna.
USA, FL, Tampa
Joined Mar 2010
Yeah, he does look good. Nice job!
wcessna is offline Find More Posts by wcessna
Discussion All steel 1/6 scale R/C tank build. Help! LavaRed RC Tanks 19 Aug 17, 2012 09:25 PM
Question BUSA 1/6 Nieuport 17 Plans / Instructions Question Thermalin The Builders Workshop 15 Jan 08, 2012 10:03 AM
Discussion 4-Stroke Saito 50 Powered 1/6 Semi-scale Nitro-Trike Scratch Build Log CONDOR2 RC Paragliders and Kites 0 Jun 11, 2011 11:34 PM
For Sale 1/4 scale busa fokker dr-1 meihls Aircraft - Fuel - Airplanes (FS/W) 0 Feb 05, 2011 08:56 PM
Discussion busa 1/6 scale pup bottom an top wings incidence avionette Electric Plane Talk 5 Dec 07, 2007 03:11 PM
