Old Jan 22, 2012, 04:51 PM
payne9999 is online now
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Contest
Funbuild 5 Multi-motor C-310 (L-27B)
Another entry in Funbuild 5:
This is a scratch built twin Cessna with retracts after a plane that is outfitted as a China Lake resident. The decals are available on the thread "Post your Scale Decals for Downloading" page 51. The design is by Pat and the vac formed parts are from Pats Custom as well.
I will be adding pictures and the final video as the plane is completed.
payne9999 is online now Find More Posts by payne9999
Old Jan 22, 2012, 04:59 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Wheel well construction
I had a bottle of Merlot that was just the right size
Robart 1/2A retracts installed
Old Jan 22, 2012, 05:01 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Testing with the fuse attached.
Old Jan 22, 2012, 05:03 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Radio Install
This is really not a difficult model to install retracts in and the weight penalty seems like it is going to be minimal.
Old Jan 22, 2012, 05:05 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Here is a short video of the landing gear test:
MVI_6368.AVI (0 min 18 sec)
Old Jan 22, 2012, 05:14 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Here are the tail peices after covering:
I decide to do the nose a little different with the vac formed part. I want the fit to be flush so I an making a sub former to go inside the cone. Last time I carved a nose peice (too much work) but this time it will also take a while to get the fit just right.
I cut off the top, bottom and side peices in order to mount the cone differently. The sub former is double stick taped in place for shaping:
Old Jan 22, 2012, 05:31 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Fuselage is about covered, adding markings:
Time to clean up my workbench:
Old Jan 22, 2012, 06:22 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Wing ready for final wiring to be pulled and then covering:
Nose cone with sub-former installed ready for trimming:
Nose cone test fit...about right! Also, my hand matches the federal standard color for Navy blue.
Old Jan 22, 2012, 08:48 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Fuse is covered and the markings on. I used a combination waterslide and cutout graphics (from white and red econokote) because waterslide decals are not as opaque and are somewhat prone to wear and damage.
Next time I think I will go to Kinko's and make laser printed waterslide since they are supposed to be more durable.
I love the way Parklite goes on compound curves in a big wad......
Then it comes out nearly perfect after some heat gun abuse:
Old Jan 23, 2012, 12:52 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Completed the nose cone:
Fuse and tail group is together. Elevator pushrod and rudder pull-pull linkages and windows are next:
Old Jan 23, 2012, 04:44 PM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Great job thus far ! Very nice choice of schemes for this one too
Cheers,
-John
jofrost is offline Find More Posts by jofrost
Old Jan 24, 2012, 10:30 AM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
It looks great.
Len
LenBFP is offline Find More Posts by LenBFP
Old Jan 24, 2012, 08:19 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Cheers,
-John
Originally Posted by LenBFP View Post
It looks great.
Len
Thanks guys, I had to take several steps back today. I accidentally had a drop of CA get away from me while repairing a former I cracked. Murphy's law dictated that it hit right on the steering arm of the nose retract. Totally my fault though.
So, that was the end of it's functional life. However, I was concerned about the nose retract because it was a cheaper one and not the Robart like the mains. So, I ordered a Robart nose retract today.
So in the long run it is probably better this way but I will not be able to make much progress for a week or so and the weather is shaping up to be perfect for Saturday. The nice thing about the Robart nose gear is it is 100 degree rotation instead of 90. I had to mount the other nose gear way up inside the fuse and at a funny angle so it would extend at the proper forward angle and still tuck up in the retracted position. The 100 degree rotation will help with the second installation.
Dave
Old Jan 27, 2012, 10:10 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Completed the wing, ailerons in and tested. The Ultracote midnight blue paint doesn't match so I have to custom mix some Model Master paint.
Pull-pull ruder system is in along with a carbon fiber elevator pushrod.
Old Feb 03, 2012, 12:54 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Getting close to completion. The Robart nose gear is installed an working. Painting the window frames tonight:
Hoping for a maiden flight in one or two days.....
Dave
Contest Funbuild 5 - "Multi Engines" - Winners Announced !!! jofrost Scale Kit/Scratch Built 31 Oct 04, 2012 07:27 PM
Contest Funbuild 5 DC-6B (C-118) Pats Custom kit payne9999 Scale Kit/Scratch Built 25 Feb 03, 2012 08:08 AM
Discussion R/C to C/L motor conversion?? gene6029 Control Line 11 Nov 16, 2011 03:54 PM
Help! Instructions for C&K 2C-20-310 motor Mike Seale Scratchbuilt Indoor and Micro Models 1 Apr 02, 2011 01:06 PM
