Old Oct 08, 2003, 08:56 PM
Shackas is offline
Find More Posts by Shackas
Joined Jul 2003
NiCad Delta Peak Charger with NiMH?
Hi all,
Am I risking anything by using a NiCd Delta Peak Detect charger (Hitec CG....can't remember the number) to charge NiMH packs??
Thanks in advance.
Dave
Shackas is offline Find More Posts by Shackas
Old Oct 09, 2003, 12:24 AM
CADman is offline
Find More Posts by CADman
CADman's Avatar
Sevier County, East Tennessee
Joined Oct 2001
If your charger is designed to charge only NiCd (like the CG-315, CG-330, CG-335) and you charge a NiMH, yes, you risk over charging your pack because the peak will not be detected. The CG-335 Pro & CG-340 is rated for both battery types.
CADman is offline Find More Posts by CADman
Old Oct 09, 2003, 03:15 PM
die fliedermaus is offline
Find More Posts by die fliedermaus
die fliedermaus's Avatar
Kansas
Joined Jul 2002
I have used a cg-320 (?) for a long time on nicads and nimhs.
Just don't leave it charging unattended. Sometimes it will apparently miss the peak and continue charging.
I recently bought a Hobbico MKII for nicads, nimhs, and lipos.
It misses peaks too so new is not necessarily better.
die fliedermaus is offline Find More Posts by die fliedermaus
Nicad charger with Nimh battery? wrenwright Batteries and Chargers 10 Aug 18, 2004 04:16 PM
NiCad Wall Charger with NiMH Transmitter Battery? T.J. Kong Batteries and Chargers 11 Jun 24, 2004 12:03 PM
FS: NiMH / NiCad Digital Peak Charger KnimRod Aircraft - Electric - Helis (FS/W) 1 May 02, 2004 07:00 PM
FS: Hitec Delta Peak Charger fchristian Aircraft - Electric - Airplanes (FS/W) 0 Dec 21, 2002 11:04 PM
FS: Hitec CG-330 Delta Peak Charger MX Aircraft - Electric - Airplanes (FS/W) 1 Dec 11, 2002 10:45 AM
