Old Jan 25, 2012, 10:51 AM
justinsebastian is offline
Find More Posts by justinsebastian
Justin S
justinsebastian's Avatar
United States, NC, Mt Holly
Joined Nov 2010
Chris, nice build thread!! I'm almost completely done with mine, and I wanted to point out something. The extended servo arms are not necessary to get the really high throws. But, I think you could get more elevator throw with the extended arm.
The thing I noticed is that the servo arm doesn't go on exactly perpendicular to the servo when electronically centered, so you lose a little movement (in my case, up) because of the sub-trim that's needed to get the surface centered.
Even with this, I'm still getting around 45 degrees on the "short" side of the elevator throw, which I'm sure will be enough. With the longer arm, I think you could completely max out the throw in both directions.
With the stock arm on the rudder, the rudder is within a 1/4" of the elevator, and I think I could get more...so absolutely no need for the longer arm there from what I see.
justinsebastian is offline Find More Posts by justinsebastian
Old Jan 25, 2012, 11:13 AM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
With this plane it is do responsive that you really only need about +- 35 degrees in the tail to get great 3D performance. In the Ails you definitely want as much as you can get.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jan 25, 2012, 11:34 AM
bjohnson80 is offline
Find More Posts by bjohnson80
bjohnson80's Avatar
Round Lake, IL
Joined Sep 2005
I have been out of foamy flying for some time, but still have some equipment. Do you guys think an Axi 2204/54 would work on this airframe? I always ran it with a 3s 450 pack, but not sure if that setup will be too heavy for this plane. Looks like I can run that motor on 2s, just not sure if it will be enough. Any thoughts?
http://www.modelmotors.cz/index.php?...e=54&line=GOLD
Thanks!
Brian
bjohnson80 is offline Find More Posts by bjohnson80
Old Jan 25, 2012, 11:36 AM
Justin S
Joined Nov 2010
Then you absolutely don't need to worry about the extended arms. I remember that it didn't need much elevator. It has a TON of aileron throw I have a feeling I'll be dialing back, or flying in a mid-rate configuration most of the time.
Old Jan 25, 2012, 12:38 PM
Justin S
Joined Nov 2010
By the way, for those of you using the 6 channel orange spektrum receiver (the one that TH sells), it helps a bunch to take the case off.
Old Jan 25, 2012, 01:05 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Thanks!
Brian
Brian,
I did some research and it looks like that motor will work well on 2s with a 9x4.7 prop if you want to use 2s. Another option is to just use 3s 350 or so if you want to stay around the same weight. I plan on trying both 350 and 450 on 3s, I'll let you know how it works with the heavier packs.
cwojcik is offline Find More Posts by cwojcik
Old Jan 25, 2012, 01:37 PM
c/f is offline
c/f
Find More Posts by c/f
c/f
Joined Jan 2004
Thanks for the kudos peeps,,,,,,,,,,,
Couple of thoughts, IMHO attending big events, the market of indoor F3P /3D is pretty standardized now on 50W with 20g batteries into a 8X4.3 Slo Fly prop on planes of 4-5 oz.
The CY falls nicely into this catagory with just bumping up the batttery to 30g and 60-70W into same prop, @ 5-6oz with durable EPP and supplied hardware/electronic setup. It really is exactly what I needed and wanted as the 4-5oz are purpose built and delicate with highly modified electronics and hardware.
My other new 2012 model I have had since 10/11, is the Telink Xtra Slick, it is a most excellant flyer and at 26oz with 400W static it slows to a snails pace as well, however 400W into an APC11X4.7 Slo Fly prop gets it moving in short order, I love to do WOT 75' loops off the tip of the TX and listen to the airframe whistle......
Then my next 2012 model I madened this month as well is the EF 48" Edge 540 with 800W into a Vox 12X6, To say that flying with Chris J and Chris H for a week @ triple tree in SEPT, has had a huge impact on my fleet would be an understatement, but this fleet has really opened my eyes to the ease of which a design can accomplish BIG TRICKS and precision, up to this point I felt where a lack of skillsets late in the game @ 50years old.
You can be assured that TEAM TW really sets the bar high in whatever CJ were to expect out of a 3D design and why I pay to play. I'm hooked, I just hit the SEND FUNDS icon.......
Now I just got to get NATASHA , to do the back against the wall CY pose in her 5" silettos with my CRACK YAK at E-fest......
c/f is offline Find More Posts by c/f
Latest blog entry: Time Capsule Heli
Old Jan 25, 2012, 01:52 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Very nice c/f. The Crack Yak looks even better in the air, can't wait to get my hands on one. What set up are you running? can't make it out in your vid but the motor looked gold.
Aviefly is offline Find More Posts by Aviefly
Old Jan 25, 2012, 03:20 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Speaking of E-Fest... Who is going?
Let me rephrase that as to stay on topic...
Which of you Twisted pilots are going to E-Fest?
(yup - that's better)
I'll be there on Saturday.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Jan 25, 2012, 04:39 PM
bjohnson80's Avatar
Round Lake, IL
Joined Sep 2005
Originally Posted by cwojcik View Post
Brian,
Great, thanks. Looking forward to your results with the heavier packs.
Old Jan 25, 2012, 05:55 PM
Ron_Dog is offline
Find More Posts by Ron_Dog
High Tech Red Neck
Ron_Dog's Avatar
United States, IL, Lawrenceville
Joined Nov 2011
Well,I just bit the bullet,and ordered one! (Like I need another plane) Ron
Ron_Dog is offline Find More Posts by Ron_Dog
Old Jan 25, 2012, 06:01 PM
3drcparts is online now
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
She's done and ready for maiden in the morning, AUW with battery is 6.5 oz so I'm really happy with this
3drcparts is online now Find More Posts by 3drcparts
Old Jan 25, 2012, 06:18 PM
David Kyjovsky is offline
Find More Posts by David Kyjovsky
David Kyjovsky's Avatar
Prague Ruzyne, Czechoslovakia (former)
Joined Jan 2003
the first video is posting right now...
posted! the plane is amazingly close to depron shocky performance indoors...
Twisted Hobbys / RC Factory Crack Yak (5 min 1 sec)
David Kyjovsky is offline Find More Posts by David Kyjovsky
Old Jan 25, 2012, 06:26 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Jan 25, 2012, 06:34 PM
Ron_Dog is offline
High Tech Red Neck
Ron_Dog's Avatar
Joined Nov 2011
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
