Old Jan 24, 2012, 05:55 PM
bkent100 is offline
Find More Posts by bkent100
USA, NC, Charlotte
Joined Nov 2009
CG Location with Landing Gear
Guys,
Does the LG make a relevant difference in the battery location?
BK
bkent100 is offline Find More Posts by bkent100
Old Jan 24, 2012, 06:24 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Originally Posted by Madratter View Post
I broke down and ordered mine today. I'm getting the Orange Scheme with the landing gear. While I was at it, I also ordered a Sbach kit as a replacement for my Edge 540, when I determine it is finally too long in the tooth.
I don't know how differently the Yak will fly from my Edge, but it sure has a distinctive look being so angular.
I think you will find that it is a lot different than the Edge.
Originally Posted by bkent100 View Post
Guys,
BK
Yes, with the gear on the CG range for the battery should be from nearly centered over the spar to slightly forward of the top spar.
Without the gear it will be forward from that and I am in the process of building another production prototype without gear to verify but on the prototype it was closer to the Ail servo.
The battery location will change based on prop and setup.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jan 24, 2012, 08:15 PM
crobar is offline
Find More Posts by crobar
crobar's Avatar
United States, ID, Athol
Joined Apr 2009
Originally Posted by hercdriver7777 View Post
Welders is contact cement. After 5 minutes it is semi tacky and will be adjustable if you put on a thick coat. After 10 minutes it is instant bond.
Yes, I recommend centering all the servos and installing the servo arms prior to installing them. I always do it after so I do not have to fiddle with my transmitter while I still have sticky fingers and glue all over the bench. I'm building these things fast to get the build threads up before everyone gets theirs. If I had more time I would do it your way.
I haven't weighed the production model but it is 6.XX oz depending..
FYI - You can get a $6 servo & motor tester which allows you to test and center servos either in or out of the plane without a transmitter. It will test motors and esc's as well.
crobar is offline Find More Posts by crobar
Old Jan 24, 2012, 08:55 PM
c/f is offline
c/f
Find More Posts by c/f
c/f
Joined Jan 2004
Heres tonights first indoor maiden outing with mine.......
http://evansvillercclub.net/Video/Mi...ack_Yak-55.wmv
c/f is offline Find More Posts by c/f
Latest blog entry: Time Capsule Heli
Old Jan 24, 2012, 09:02 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Nice!
So what are our thoughts on the CY vs the other TH planes?
JC
ps - Congrats on posting the first CY video - you win!
JC Spohr is offline Find More Posts by JC Spohr
Old Jan 24, 2012, 09:17 PM
Columbia SC
Joined Feb 2005
Great stuff Mike! You sure built that quick! And, congrats on being the first to post vid!
Old Jan 24, 2012, 09:33 PM
Twisted Realm is offline
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
Nice maiden c/f, looking good!
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Jan 24, 2012, 10:19 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Ya know, I have kind of a critical eye and don't give compliments easily...but...
Excellent flying and fantastic airplane!!!!
Crack Yak?? OH YEAH!
KE Spin is offline Find More Posts by KE Spin
Old Jan 24, 2012, 10:20 PM
Columbia SC
Joined Feb 2005
Sweet man! Happy to hear it!
Old Jan 24, 2012, 11:39 PM
bkent100 is offline
USA, NC, Charlotte
Joined Nov 2009
Glue in eyelet on control rod support
Got a little glue in one of the eyelets of the control rod supports. Any idea how on how to loosen up Welders? Does Debonder work?
BK
Old Jan 24, 2012, 11:44 PM
Columbia SC
Joined Feb 2005
Use a small drill in a pin vise maybe.
Old Jan 25, 2012, 07:39 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Started building mine last night, it goes together really easily. I really love the indexing cutouts that both keep everything aligned and don't let you put anything together backwards. Very nice touch!
I'm running a slightly different set-up because it's what I have:
Hacker A10-13L w/ 8043
ZTW 12 A ESC
Hitec HS-65 on ailerons
Hitec 5045 on elevator and rudder
3S 350 mah and 450 mah Sky LiPo and Gens Ace packs
On this size plane I won't be using 3S any more, and here's why: it's difficult to find the right size 3S packs. To get the same weight as the recommended 2S packs, you need about 3S 300-350. These are more expensive than 2S 450 (there are lots of those on the market) and about the only high-C ones available are Thunder Power and they are very expensive.
My next RCF/Twisted plane will get the recommended power system for sure. The Twisted 2204-1800 is a very impressive little motor!
cwojcik is offline Find More Posts by cwojcik
Old Jan 25, 2012, 07:42 AM
justinsebastian is offline
Find More Posts by justinsebastian
Justin S
justinsebastian's Avatar
United States, NC, Mt Holly
Joined Nov 2010
BK
Wow, that's some late building, and even later support!
justinsebastian is offline Find More Posts by justinsebastian
Old Jan 25, 2012, 10:28 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
ZTW 12 A ESC
It will be a rocket on the Hacker and 3s, while waiting for the crack yak to come out I swapped the 2204-1800 and 2s for the hacker a10-13l 3s on my 3DHS 34 Edge and it did not have the same power as the Hacker, but the CY is going to be alot lighter than my 3dhs 34" edge
3drcparts is offline Find More Posts by 3drcparts
Old Jan 25, 2012, 10:31 AM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
I just finished building my first TH plane the other day, the Edge, and am about 75% done with building the CY. I used both the Edge instructions and the build info here, and choose to do my own thing with a few aspects.
The CY goes together really easy. The high you can get from Welders is a plus. A nice touch is the servo areas are already cut-to-size for the TH kit servos - sweet! Lasers cut foam nicer than I do.
Hella nice job on the CY, guys. Gonna maiden the Edge in the next day or so, then the CY. Fun times in 2012 and it's only January.
shunyata is offline Find More Posts by shunyata
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
