Old Feb 17, 2013, 12:28 AM
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
I love flying in the wind.
Don't get me wrong, I prefer to fly in no wind. In good conditions I can fly precise and smooth and so great stuff.
But when it is windy you can practice a lot of other techniques that are also fun. Playing with the wind and T Roll sliding down wind, reverse harriers, back up snakes, extreme waterfalls can be a lot of fun. Also, learning how to take out the burbles and smooth out a flight in turbulence is a great skill.
Lets face it, it is windy at least 50% of the time. Learning how to fly, "and have fun", during that other 50% is huge!
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Feb 17, 2013, 12:37 AM
Joined Jan 2006
Crack Yak vrs Crack Yak Lite AUW
Have set up both the Crack Yak and the Crack Yak Lite with the identical 'lite gear setup'.
Results:
1) Finished build weight:
Crack Yak - 132 grams or 4.6 oz
Crack Yak Lite - 122 grams or 4.3 oz
RTF weight: add 17 grams or .6 oz to above weights (Nano Tech 2S 300mah battery)
2) Set up:
Motor: Dualsky 1620kv - 20 grams with built in ESC
Servos: D47 or equiv.
Rx: 3 gram
Battery: Nano Tech 300mah 2S (35-70C). 4.5 minutes of mixed flying uses 170 mah, thus leave plenty of reserve battery.
3) Flight results:
Very satisfactory in all respects. Extremely low wing loading provides for soft flight characteristics while still maintaining the precise control response that the Yak has become so respected.
I believe that anyone whom truly enjoys the concept of building lite, and the resulting pleasant flight characteristics, will not be disappointed. Both these fine machines respond very well to the 'lite gear' set up.
Nimbus Dave is offline Find More Posts by Nimbus Dave
Old Feb 17, 2013, 02:43 PM
Bloosee's Avatar
United States, CA, San Diego
Joined Jan 2012
My CY probably has an extra half ounce of welders in it. I was worried about all the repairs building up over the months but I actually think I like it better with a little weight, vertical suffers of course, but I think it helps keep some momentum, which I like, makes it feel a little more like a bigger plane.
At my field, the guys all seem to like watching me fly the CY over my other 3D Planes, the Crack Yak is BOSS.
Bloosee is offline Find More Posts by Bloosee
Old Feb 17, 2013, 03:13 PM
Quad/3D/DLG/FPV-I fly anything
SuperBarlow's Avatar
United States, VT
Joined Aug 2012
How does flying the CY in RF 6.5 compare to real life?
SuperBarlow is offline Find More Posts by SuperBarlow
Old Feb 17, 2013, 03:37 PM
pilot_keeter's Avatar
United States, GA, Eastman
Joined Nov 2008
Its actually a really close representation of how it really flies. The CY in RF is a little too twitchy when hovering though. Its much easier in real life.
pilot_keeter is offline Find More Posts by pilot_keeter
Old Feb 17, 2013, 04:19 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
Got a couple of packs in at sunset, pretty windy so just cruising about.
Crusin on Crack (2 min 56 sec)
jimbo320 is offline Find More Posts by jimbo320
Old Feb 17, 2013, 07:02 PM
Build em lite......
Joined Apr 2012
Results:
2) Set up:
Rx: 3 gram
3) Flight results:
Excellent example of what can be done with some thought and effort. Well done. You have crossed the threshold and exceeded published specifications by a wide margin. Building heavy does not require much thought, building light to this degree requires thought and finesse....well done....enjoy flying lite.
nkhamlue is offline Find More Posts by nkhamlue
Old Feb 18, 2013, 01:37 AM
accel8or
accel8or's Avatar
Joined Dec 2010
Any chance somebody will model the CP in RF?
accel8or is offline Find More Posts by accel8or
Old Feb 19, 2013, 02:48 PM
accel8or
accel8or's Avatar
Joined Dec 2010
Waiting for better weather.
Old Feb 20, 2013, 05:00 PM
Columbia SC
Joined Feb 2005
Results:
2) Set up:
Rx: 3 gram
3) Flight results:
Nice work! Do you notice a big difference between the Lite and Standard being that the weight is now so close? I bet they still fly very different.
Old Feb 20, 2013, 07:08 PM
Joined Jan 2006
I believe I might best answer this by suggesting that the difference or, similarities, would depend significantly on flight style of the operator. You are correct in that they still have their unique flight characteristics, however with the added pleasure of extremely light wing loading. As always, both great machines......Cheers...D
Old Feb 24, 2013, 04:45 PM
andro34's Avatar
POLSKA
Joined Feb 2011
Hello! I also made the CRACK YAK is a great model.
at this time with us is winter and there is no forecast for the flights. so I decided to fly in the room...
look:
CRACK YAK- HOVERING IN THE ROOM (6 min 3 sec)
equipment which is used in my model:
motor:HK 2204 1700Kv
esc:Turnigy PLUSH 10A
serwo:ailerons-TP SG92R ;rudder and elevator -D0510MG 5,7g
batery:NANO-TECH 2S 300mAh and ZIPPY COMPACT 2S 350mAh
propeler:GWS SF 8x4,3
Weight ready to fly: 170g
greetings!!
andro34 is offline Find More Posts by andro34
Old Feb 24, 2013, 05:06 PM
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Nice at least when the Mrs gets back you can say you've done the hoovering just gota work out how to explain the chunks missing from the triffid
Like the anti torque rolls, those things just mess with my head.
Aviefly is online now Find More Posts by Aviefly
Old Feb 24, 2013, 08:27 PM
Joined Sep 2009
My cy has a million miles on it. Been happy with how it holds up.
fastlif is offline Find More Posts by fastlif
Old Feb 25, 2013, 07:51 PM
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
How so?
STLAV8R is offline Find More Posts by STLAV8R
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 521 Jun 12, 2013 08:06 PM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 992 May 31, 2013 03:19 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 178 Jan 02, 2013 11:05 PM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 76 Aug 30, 2012 12:08 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
