Old Dec 16, 2012, 11:42 AM
Intergalctic Coffee Enthusiast
MaddSkillz's Avatar
United States, OK, Tulsa
Joined Jun 2011
Originally Posted by Aviefly View Post
Are you sure you have the travel direction right on your throttle channel? the other the it could be is your end points are set too low or too high.
Thanks. I just checked and I do have the travel direction set correctly as when I push the throttle to full up the prop will try to spin and does sometimes but it never does. It may turn a quarter of the way, but that's it.. Then the motor just stutters and nothing ever happens. I'm growing suspicious of the ESC. I soldered the motor to the ESC wires. I don't think that would be the issue. It should still spin - even if it's the wrong way.
Have a look at the build video for the new CY Mini.
http://www.youtube.com/watch?feature...Vs046g#t=2612s
The way Herc does it in that is the way I do it. Mark your cog on the wing close to the fuse then just grip the fuse above that mark and with your lipo on the horizontal fuse slide it up and down till it feels right, mark the position then cut your slot. People are going to say to use velcro for mounting your lipo so you can use different sized lipo's, I prefer the slot method if you intend to stick to one size battery. Another method once you have marked the position of you lipo is to temporarily attach it to the fuse with pins, fly it and make sure it flies to your liking before cutting the slot.
I find Herc's 82.5mm from the leading edge of the wing works well for me.
Thanks! I was able to figure it out last night and I think I got it balanced pretty good.
MaddSkillz is offline Find More Posts by MaddSkillz
Old Dec 16, 2012, 11:43 AM
MaddSkillz's Avatar
Joined Jun 2011
Originally Posted by rcnxs View Post
I am looking for the aluminum ring that adapts an APC-SF to 5.5mm to fit crack motor, is that the same thing you are looking for?
Sure would like to find a source....
RCNXS
Not sure on the size. I have a Hacker motor. The A10-13L. But the prop adapters that I have for it don't fit the props. It's weird.
Old Dec 16, 2012, 11:54 AM
MaddSkillz's Avatar
Joined Jun 2011
Here's a video. Any ideas?
Bad ESC? (0 min 15 sec)
Old Dec 16, 2012, 12:05 PM
Alabaster AL
Joined Aug 2006
5.5mm is the same size as the hub on GWS-SF and the Twisted Tuff props. The Hacker ones should take and APC-SF down to 5.5 to fit any motor with a 5.5MM adapter. Unfortunately, I don't see them offered as a part by them self on the Hacker site.
RCNXS
rcnxs is offline Find More Posts by rcnxs
Old Dec 16, 2012, 12:44 PM
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Bad solder between motor and esc?
hone1er is offline Find More Posts by hone1er
Old Dec 16, 2012, 12:50 PM
MaddSkillz's Avatar
Joined Jun 2011
I was hoping this wasn't the case... I may have to try that but I really don't think that's it. I wonder if there's another way to test if the solder joints are good or not. Hopefully someone can confirm first before I do.
Old Dec 16, 2012, 12:52 PM
Alabaster AL
Joined Aug 2006
Ditto on the solder, joints making that issue. I don't know of anyway to test. Someone smarter than I might could chime in and determine if you could measure the resistance with a meter to tell.
RCNXS
Old Dec 16, 2012, 02:11 PM
MaddSkillz's Avatar
Joined Jun 2011
RCNXS
Have you seen a solder joint do that to a motor?
Old Dec 16, 2012, 02:42 PM
Crack Team
Dan5.0's Avatar
Joined Dec 2008
Yes...almost always the case.
Dan5.0 is offline Find More Posts by Dan5.0
Old Dec 16, 2012, 02:46 PM
MaddSkillz's Avatar
Joined Jun 2011
Excellent. I'll resolder then. It's got to be that.
Old Dec 16, 2012, 03:36 PM
Alabaster AL
Joined Aug 2006
Yep, I re-soldered the joint an fixed it, that was of course before my soldering skills where developed...
RCNXS
MaddSkillz's Avatar
Joined Jun 2011
I give up... Now the ESC beeps like it should but the motor doesn't turn. I wonder if there's some setup I have to do now. Ugh. Oh and sometimes it beeps louder and then sometimes it's more muted. I checked the battery and it's almost fully charged.
ZTW 12A ESC and Hacker A10-13L motor with 450mah 3S pack.
Old Dec 16, 2012, 04:22 PM
MaddSkillz's Avatar
Joined Jun 2011
The only other thing I can think of is the solder joints to the power JST connectors. I guess I'll check those FOR HEAVENS SAKES!!!
Old Dec 16, 2012, 04:28 PM
SLOW & LOW
ATCH's Avatar
United States, AL, Alexander City
Joined Jul 2011
I think it's a bad esc
ATCH is offline Find More Posts by ATCH
Old Dec 16, 2012, 05:08 PM
MaddSkillz's Avatar
Joined Jun 2011
I've been wondering that myself. I wish I wouldn't had Welders glued that thing to the plane yet.
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 510 May 11, 2013 03:11 PM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 990 Apr 19, 2013 10:38 AM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 178 Jan 02, 2013 11:05 PM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 76 Aug 30, 2012 12:08 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
