Old Dec 15, 2012, 03:20 PM
MaddSkillz is offline
Find More Posts by MaddSkillz
Intergalctic Coffee Enthusiast
MaddSkillz's Avatar
United States, OK, Tulsa
Joined Jun 2011
I guess I misplaced my aluminum prop adapter that goes in the back of my GWS prop and my brand new Hacker A10-13L. Anyone know where I can order that?
MaddSkillz is offline Find More Posts by MaddSkillz
Old Dec 15, 2012, 04:31 PM
MaddSkillz's Avatar
Joined Jun 2011
What the heck, is everyone out flying today?!
Old Dec 15, 2012, 04:35 PM
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
yep it was 55 degrees and no wind at all today
lugnutz is offline Find More Posts by lugnutz
Old Dec 15, 2012, 04:48 PM
MaddSkillz's Avatar
Joined Jun 2011
I know! Awesome out! I had new house stuff to do.
Old Dec 15, 2012, 06:39 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Temps were nice here but the wind was blowing. Had work to do all day as well. Another week and I got a whole week of flying, yahoo! Sorry mad no clue where to get the adapters never did get into running hacker motors.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Dec 15, 2012, 09:52 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
I have a whole bunch of them your welcome to. Shame they are the wrong side of a big pond, I'll post them if you want though.
Aviefly is offline Find More Posts by Aviefly
Old Dec 15, 2012, 10:09 PM
MaddSkillz's Avatar
Joined Jun 2011
The ones I have don't fit. I guess they're for different props. Let me check with my LBS first. It's crazy, all the ones I have in my other foamies are the wrong size! Like this one is an odd duck or something. Weird.
Old Dec 16, 2012, 01:35 AM
MaddSkillz's Avatar
Joined Jun 2011
Originally Posted by jcansdale View Post
I was surprised how much of a difference swapping my Sunrise for a ZTW ESC made! It really does give it a noticeable power boost. They also start the motor instantly and consistently (the reason I swapped out the Sunrise).
You don't get the extra power for free though. I had to adjust my timer from 4:30 to 3:40 (running batteries to down to 20%).
My ZTW 12A ESC won't program. Any ideas? I connect the battery with the throttle in full up and never get any beeps. I have to program it I guess because it won't spin the motor. I know the battery is fully charged cause I just charged it and the servos work fine...
Does anyone know what may be wrong? I'm running 3S 450mah batteries. Just trying to do final setup.
Old Dec 16, 2012, 01:53 AM
MaddSkillz's Avatar
Joined Jun 2011
Also, when balancing the plane in order to place the battery in the right spot... Some people say to use pencils other say to use their fingers but they never say where! Where you hold the plane makes all the difference here! So where do you hold it? Help a brother out!
Old Dec 16, 2012, 02:27 AM
MadMonkey572 is offline
Find More Posts by MadMonkey572
Boooriiiiing.
MadMonkey572's Avatar
United States, TX, Roanoke
Joined Sep 2006
I just placed another order. This time I doublechecked the address and didn't order batteries... hopefully the USPS doesn't (ahem) me this time
Looking forward to flying one of these finally!
MadMonkey572 is offline Find More Posts by MadMonkey572
Old Dec 16, 2012, 06:58 AM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
Are you sure you have the travel direction right on your throttle channel? the other the it could be is your end points are set too low or too high.
Have a look at the build video for the new CY Mini.
http://www.youtube.com/watch?feature...Vs046g#t=2612s
The way Herc does it in that is the way I do it. Mark your cog on the wing close to the fuse then just grip the fuse above that mark and with your lipo on the horizontal fuse slide it up and down till it feels right, mark the position then cut your slot. People are going to say to use velcro for mounting your lipo so you can use different sized lipo's, I prefer the slot method if you intend to stick to one size battery. Another method once you have marked the position of you lipo is to temporarily attach it to the fuse with pins, fly it and make sure it flies to your liking before cutting the slot.
I find Herc's 82.5mm from the leading edge of the wing works well for me.
Old Dec 16, 2012, 07:12 AM
Twisted Do Nut!
Joined Dec 2010
What Avie said plus, on the esc make sure your trim on the transmitter is either in the mid or low setting.
Avie wrote it just like what I and the guys I know do with the cg. One step I do is once I am in the ballpark I fly the plane and want it to fly level both upright and inverted. Cut a slot for the batt and I'm good to go.
Avie since you're on the other side of the pond. What's your take on desire power batteries?
Old Dec 16, 2012, 07:43 AM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
I've been quite happy with my 380mah 3s. I only got them because it was all I could find that weighed the same as my GensAce 450 2s. They cost a bit more than other brands and are supposed to be 30c but come out more at 22-23c which is fine as that gives them a continuous 8-9amps which works well for the Crack Series stuff. I've had them for a while now and they seem to be holding up well.
Old Dec 16, 2012, 09:38 AM
rcnxs is offline
Find More Posts by rcnxs
Alabaster AL
Joined Aug 2006
I am looking for the aluminum ring that adapts an APC-SF to 5.5mm to fit crack motor, is that the same thing you are looking for?
Sure would like to find a source....
RCNXS
rcnxs is offline Find More Posts by rcnxs
Old Dec 16, 2012, 10:16 AM
Twisted Do Nut!
Joined Dec 2010
Thanks for the report Avie. While surffing electricman I saw them and was wondering about their potential. The 300mah look like a nice fit for the mini.
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
