Old Dec 02, 2012, 04:41 PM
Mr Whirl is offline
Find More Posts by Mr Whirl
Gone Gas! / Gone Crazy?
Mr Whirl's Avatar
United States, WA, Redmond
Joined Sep 2012
The Best of Crack Yak Tips & Tricks
I spent some time running thru the entire Crack Yak Std thread from beginning to end compiling many of the best tips & tricks. I figured before I built mine I could learn allot from others who are willing to share. If I am going to get addicted then I want to make sure I have got some super crack.
Crack Yak Build Tips & Setup Tricks
Plastic Painters Tarp
http://www.rcgroups.com/forums/showp...&postcount=155
CA or Welders glue
http://www.rcgroups.com/forums/showp...3&postcount=84
http://www.rcgroups.com/forums/showp...5&postcount=16
Control Rod Mounting
http://www.rcgroups.com/forums/showp...&postcount=264
http://www.rcgroups.com/forums/showp...&postcount=329
http://www.rcgroups.com/forums/showp...postcount=1580
Fuselage Alignment
http://www.rcgroups.com/forums/showp...postcount=1567
http://www.rcgroups.com/forums/showp...postcount=1594
http://www.rcgroups.com/forums/showp...postcount=1899
Landing Gear
http://www.rcgroups.com/forums/showp...&postcount=510
http://www.rcgroups.com/forums/showp...postcount=1523
http://www.rcgroups.com/forums/showp...postcount=1535
http://www.rcgroups.com/forums/showp...postcount=2691
Durability Enhancements
http://www.rcgroups.com/forums/showp...&postcount=838
http://www.rcgroups.com/forums/showp...postcount=1007
http://www.rcgroups.com/forums/showp...postcount=1382
http://www.rcgroups.com/forums/showp...2&postcount=18
Battery Mounting
http://www.rcgroups.com/forums/showp...postcount=1477
http://www.rcgroups.com/forums/showp...postcount=1481
http://www.rcgroups.com/forums/showp...postcount=3748
http://www.rcgroups.com/forums/showp...postcount=2901
Neutral CG
http://www.rcgroups.com/forums/showp...&postcount=162
http://www.rcgroups.com/forums/showp...&postcount=557
http://www.rcgroups.com/forums/showp...postcount=1456
http://www.rcgroups.com/forums/showp...postcount=1777
http://www.rcgroups.com/forums/showp...postcount=1779
http://www.rcgroups.com/forums/showp...postcount=3072
Motor Thrust Angle
http://www.rcgroups.com/forums/showp...postcount=2014
http://www.rcgroups.com/forums/showp...postcount=3013
http://www.rcgroups.com/forums/showp...postcount=2908
http://www.rcgroups.com/forums/showp...postcount=1358
http://www.rcgroups.com/forums/showp...postcount=3021
http://www.rcgroups.com/forums/showp...postcount=4894
Flight Trimming
http://www.rcgroups.com/forums/showp...postcount=2151
Alternate Servos
http://www.rcgroups.com/forums/showp...postcount=2097
Alternate Motors
http://www.rcgroups.com/forums/showp...postcount=1269
http://www.rcgroups.com/forums/showp...postcount=1974
http://www.rcgroups.com/forums/showp...postcount=2200
Alternate Propellers
http://www.rcgroups.com/forums/showp...postcount=1399
Alternate Prop O-Rings
http://www.rcgroups.com/forums/showp...postcount=2277
http://www.rcgroups.com/forums/showp...postcount=2278
Parallel Battery Charging
http://www.rcgroups.com/forums/showp...postcount=2678
Mr Whirl is offline Find More Posts by Mr Whirl
Old Dec 02, 2012, 05:11 PM
Mr Whirl is offline
Mr Whirl's Avatar
Joined Sep 2012
Crack Yak S (Super) Reporting For Duty!
Setup
2x 4g Digital servos (rudder/elevator) Twisted Hobbys
1x 9g Digital servo (ailerons) Twisted Hobbys
Out-runner1450kv 24g Twisted Hobbys
Esc 12 Amp Twisted Hobbys
2s 325mah lipo battery Thunder Power
9x4.3 Tuff Prop
AUW 194g
Super Crack Enhancements
Cross drilled carbon spar & hollow carbon tube torsion bar.
Carbon tube reinforcement tail
Carbon Control horn, push rod guides, motor mount & landing Gear.
Micro Ball Links
Rubber bushing motor mounting for adjustable thrust angle.
Polystyrene angle stk motor / fuselage reinforcement
Blenderm tape reinforced hinge points
Notes
I think there is still an additional 20grams that could be shed. Lighter 19g motor / 20g Lipo / 5g hollow carbon spar / Less Welders glue usage / Etc. My custom hollow spar turned out to thick 7mm & too heavy 15g so I opted with plan B an extensively cross drilled & lightened solid carbon spar 3mm thick at 10g. The stk wood spar weighs 7g but was not nearly as torsionally stiff. I also ended up with slight alignment issue with the elevator servo, control arm & push rod guides which reduced elevator travel to 45 degree verse a potential 60. A Lesson learned for next build. We will see if all the effort and R&D makes any difference in flight performance.
Old Dec 02, 2012, 08:35 PM
nkhamlue is offline
Find More Posts by nkhamlue
Build em lite......
Joined Apr 2012
Delete. Wrong group.....
nkhamlue is offline Find More Posts by nkhamlue
Old Dec 02, 2012, 08:41 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Setup
9x4.3 Tuff Prop
AUW 194g
Micro Ball Links
Notes
Great work! One thing to note: I built a very similar custom Crack Yak and did the exact same mounting method with the exact same motor, and the mounting ears on the motor broke off from vibration and a few crashes. These motors are most durable when mounted flush.
cwojcik is offline Find More Posts by cwojcik
Old Dec 02, 2012, 11:18 PM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
This would be great on the front page. I wonder if we can get it put there also? Great work
uptime4downtime is offline Find More Posts by uptime4downtime
Old Dec 03, 2012, 01:37 AM
Chris Arena is offline
Find More Posts by Chris Arena
oldguy
Gig Harbor, WA.
Joined Jul 2010
DW Rehab!
As an owner of a DW 9mm 300 Extra (1 /12 yrs old) and still looking and flying great and my Twisted Hobbies Crack Yak. (6 mo's old and flying great). I would LOVE to see some spirited, tonque in cheek competition from what I strongly believe are the two best foamy companies in the business.
Both work hard to compete and build excellent flying and high quality models
Both work to give excellent service.
Both will take more than enought time to answer any questions if you call em.
Both will deliver thier product in 3 days or less.
Can't go wrong with eather of these guys and some friendly competition will only give us better toys to play with!
Chris Arena is offline Find More Posts by Chris Arena
Old Dec 03, 2012, 02:05 AM
Mr Whirl is offline
Mr Whirl's Avatar
Joined Sep 2012
Cody thanks for your expert input. I inserted your warning into the tips & tricks post regarding thrust angle.
I highly respect your opinion on the Crack Yak & also 60 Extra EXP, i.e. vortex generators. I also wonder at times if Jewett should really be an full time aero engineer vs a financial advisor.
So if you had a properly balanced prop to mitigate vibrations & you’re aware of the increased fragility of the motor mounts, in subsequent crashes, do you believe the benefits out-weigh the risks regarding an adjustable thrust angle? Or am I just kidding myself thinking I can accurately & reliably dial in a malleable EPP plane that requires frequent flight trim anyway due to (ambient temperature related EPP expansion & contraction)? Put another way will I constantly have to adjust the thrust angle each flight session thus making myself completely bonkers?
You make the call & I will follow your sound advise...regarding the thrust angle topic...not regarding if I am completely bonkers, because I already know that I am just a little. lol
Old Dec 03, 2012, 08:28 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Thanks for the kind words!
I never wound up adjusting my thrust angle. The plane always flew fine with no right thrust or down thrust adjustments so I never bothered...these planes have so little momentum that as soon as you let off the throttle it's going to start to stall, so you may as well trim it for throttle-on flight. Also, the highly symmetrical shape of the fuselage mitigates the spiral effect of the propwash very well. However, I never really experimented with thrust angle, so if you want to try that you might find some benefit to it. I don't think the benefits outweigh the risks, but if you want to experiment, go for it! There's no reason you can't play with it for a while, then take the elastomers out when you are done.
However, keep in mind that as you play with thrust angle to fix some perceived trim change, you run the risk of harming other flying qualities as well. You're clearly experienced enough to know this, but for all of our other customers we will continue to recommend to just bolt the motor on and fly it!
Old Dec 03, 2012, 11:08 AM
Eganwp is offline
Find More Posts by Eganwp
Giant Scale 3D/IMAC & FPV
Eganwp's Avatar
Canada, AB, Calgary
Joined Feb 2008
Awesome posts on this page guys! Could we please get a moderator to copy/paste the first 2 posts onto the first page? I think everyone here would agree with the idea.
PS. My first CY should arrive in the mail today! Might have to retire the LeadFeather Yak
Edit: I've reported it to the mods so hopefully they will comply.
Eganwp is offline Find More Posts by Eganwp
Old Dec 03, 2012, 11:56 AM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Mods?
Can't hercdriver just update the page? He is around on here a bit. You can edit posts later.
jimbo320 is offline Find More Posts by jimbo320
Old Dec 03, 2012, 12:17 PM
Mr Whirl is offline
Mr Whirl's Avatar
Joined Sep 2012
I am glad that other members are finding the compiled information as useful as I have. Got to love these forums where the combined wisdom/experience of many is shared & discussed. I know that it is making me better at building, flight trimming & 3D flying.
I will let Chris make the call if he wishes to move the posts in part or full to the front page of the thread. Thanks Chris for all your efforts & support with this thread.
Old Dec 03, 2012, 02:23 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
CA or Welders glue
Fuselage Alignment
Landing Gear
Battery Mounting
Neutral CG
Motor Thrust Angle
Flight Trimming
Alternate Servos
Alternate Motors
Updated to front page! It's great posters and users like you guys that make this the best thread in the Foamy 3D section! Well done.
C
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Dec 03, 2012, 07:45 PM
Eganwp is offline
Eganwp's Avatar
Canada, AB, Calgary
Joined Feb 2008
Awesome! Thanks Chris & TheEarl!
Edit: Hey Chris I don't think the links copied properly to the front page. They don't work on my phone anyhow. You will likely have to edit his post in order to copy the full hyperlink paths.
Old Dec 03, 2012, 08:12 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, OH, Bristolville
Joined Oct 2010
My elevator servo is not working properly, it it always out of trim, and the servo will lock in position all the time. How do I remove the servo?
3Daddict is offline Find More Posts by 3Daddict
Old Dec 03, 2012, 09:35 PM
Mr Whirl is offline
Mr Whirl's Avatar
Joined Sep 2012
Chris I PM'd you the expanded links.
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 04:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 05:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 06:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 04:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 07:34 AM
