Old Nov 26, 2012, 06:56 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Dan5.0's Avatar
Joined Dec 2008
Yes...the proto. Ive never had epp foam retaiin its rigidness like this, and I've flown in snow rain, you name it. Typically epp breaks down over time and more resembles a wet noodle, but not this stuff. IDK what they do to this stuff, but I love it.
Dan5.0 is offline Find More Posts by Dan5.0
Old Nov 26, 2012, 04:39 PM
jmanopla is offline
Find More Posts by jmanopla
Joined Dec 2009
hi i Have a Crack Yak the Normal Version and i Have some 3S 460MAH BATTERYS CAN I USE THIS BATTERY WITH A 9X4,7 PROP THE RECOMENDED FOR 2S SETUP?
jmanopla is offline Find More Posts by jmanopla
Old Nov 26, 2012, 04:57 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Not recommended. 3S setup should use the 8" prop. You might get away with the 3S if you dial down the the throttle endpoint so you don't over amp the ESC.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Nov 26, 2012, 11:56 PM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
Sorry, but this is not a good practice. The ESC is basically a switch with high frequency, so it will briefly see full amperage (plus the heat generated by the switching) even when operated at part throttle. Use a 8" prop!
Stark is offline Find More Posts by Stark
Old Nov 28, 2012, 09:49 AM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
As a beginner one of the things I like best about the CY is that using the recommended motor, esc, prop has taken all the guesswork out of tuning the plane.
So I know it's me and not the plane!
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Nov 28, 2012, 09:57 AM
Eganwp is offline
Find More Posts by Eganwp
Giant Scale 3D/IMAC & FPV
Eganwp's Avatar
Canada, AB, Calgary
Joined Feb 2008
Watt Test Numbers
Well just placed my order for the Crack Yak gold, 26g motor, CS90D digital 9g servo, etc. Can't wait!!!
For those interested, here are some watt numbers (same prop swapped, same pack swapped) comparing a brand new 26g Twisted motor on my buddies Pitts, vs the Turnigy 2730 on my Leadfeather 3D EPP Yak 55. Testing done on almost new (2 cycles) Gens Ace 450mAh 3s.
Turnigy 2730-1500kv:
8x4DD
10.61a
10.59v
112.7w
8x4.3SF
12.39a
10.29v
128.1w
26g Twisted Hobby 1450kv:
8x4.3SF
13.87a
10.16v
141.6w
Went to test the 8x4DD on the 26g but the prop adapter oring broke and sent her sailing! Lol. That 26g is impressive. Didnt have my tach there for rpm but I'm almost positive it's a little higher kv than listed. Both have insane ballistic over-the-top power on 3s, and are great on the 9x4.7SF 2s indoor setup. You won't go wrong with either motor!
Eganwp is offline Find More Posts by Eganwp
Old Nov 28, 2012, 03:50 PM
deadbolt1970 is offline
Find More Posts by deadbolt1970
United Kingdom, England, Bristol
Joined Jul 2012
i am stuck need some help pls my cg is 11 cm from the wing leading edge. using 2s 450 mah it puts the battery way up front of the aireon server.
i am using land gear.
loking at the pics posted there battery postion is by the wood strip.
does this seam correct?.
deadbolt1970 is offline Find More Posts by deadbolt1970
Old Nov 28, 2012, 04:29 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
There is a possibility you used more glue than necessary toward the tail end or variances in the foam density to cause the need for the battery to be further forward than it is on some others. The important thing is it balances in the right place regardless of battery position. 110mm behind the leading edge is probably too far back for most peoples taste. Herc's original suggestion of 82ish mm behind the leading edge works a treat for me. Have you got your esc and rx as far forward as you can get them? as long as your pack doesn't clash with the aileron servo your good to go.
Aviefly is offline Find More Posts by Aviefly
Old Nov 28, 2012, 05:38 PM
Joined Jul 2012
will move every thing forward and let u know thanks
all sorted and battery in.
flys amazing the rdge 540 going to be on the shelf for now i think ;-)
Old Nov 29, 2012, 03:00 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Managed to grab a single pack before darkness fell. We are approaching the shortest day of the year, gets dark at 4.15, so not much chance for flying. I could hardly see the plane at all, let alone fly.
Crack Yak in the Dark (3 min 35 sec)
jimbo320 is offline Find More Posts by jimbo320
Old Nov 29, 2012, 03:49 PM
zhavener is offline
Find More Posts by zhavener
Extreme Flight
United States, GA, Athens
Joined Feb 2012
looks like a light set is in your future
zhavener is offline Find More Posts by zhavener
Old Nov 29, 2012, 03:56 PM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
You know ive been thinking about one
Old Nov 30, 2012, 06:51 PM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Anyone else see this? It's copied/pasted from DW's web site. It appears that whoever wrote this is on Crack! Advertising coming in at 10 oz. for a 31" foamy...wow!
The first of two designs to the hit the streets is the REHAB, getting you off the Crack YAK and into REHAB will not only improve your flying skills, but it will also be the next step for getting into larger airframes.
The REHAB is designed to be a throw around beater foamie for small spaces. The wing spans 31 and comes in under 10 ounces.
STLAV8R is offline Find More Posts by STLAV8R
Old Dec 01, 2012, 09:32 PM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
The REHAB. Hope it doesn't pull an Amy Winehouse and meet the fate of druuuugggss.
Sixinarow is offline Find More Posts by Sixinarow
Old Dec 02, 2012, 02:37 PM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
Well if the Pitts wasnt enough fun, the Crack Yak on 3S is just as great. In yer face, tail touches and hand catches galore in this one.
Crack Yak Rocks!
Hand Catch (6 min 14 sec)
Of course, full screen vimeo for glorious 1080P full HD.
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
