Old Nov 17, 2012, 02:56 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Originally Posted by Ohio AV8TOR View Post
Are you getting more flight time on 3S and did you change props during the battery switch? I am using the stock power setup from TH.
Personally im using the 8x4 yellow prop and i get the same flight times perhaps a few seconds less, but close.
Im finding that my model attrition is higher, all that extra power is affecting the models a bit more, crack yak rudder stopped working today, and the pitts prop came off, just with normal flying...
jimbo320 is offline Find More Posts by jimbo320
Old Nov 17, 2012, 03:09 PM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
Outstanding weather here in central PA. I got 8 flights in today averaging 6.5 minutes each.
No crashes, no broken props!
Crack Yak is Whack!
Whooohooooooo!!!!!!!!!
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Nov 17, 2012, 05:55 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Crack Yak is Whack!
Weather was good here as well though I flew the Pitts and my micro stryker the most. The Yak got airtime but no cam time.
What battery are you using to get that 6 minutes?
KamikazePilot is offline Find More Posts by KamikazePilot
Old Nov 17, 2012, 07:46 PM
TBone08 is offline
Find More Posts by TBone08
AirSurfer
TBone08's Avatar
United States, VA, Arlington
Joined Sep 2011
I had my maiden today and as much as it was fun it felt like I could use more power...
(ex. at time the hover just didnt kept its height, and not just towards the end of battery).
I am using the power setup combo settings, with Lipo Twisted Hobbys 2S 450mah 25~50C, and Prop Slow Fly 9 x 4.7 "Tuff Prop".
any ideas, or did you guys experience the same ??
TBone08 is offline Find More Posts by TBone08
Old Nov 17, 2012, 08:23 PM
Joined Sep 2011
The TH 450 3S.
Old Nov 17, 2012, 08:36 PM
Twisted Do Nut!
Joined Dec 2010
Tbone that's hinky, I've got power to spare with the same setup. Did you calibrate the throttle?
I'm lucky if I get 5 minutes on a 450 pack let alone 6. At 5 minutes I'll kill my packs, though I do fly aggresively.
Last edited by KamikazePilot; Nov 17, 2012 at 08:37 PM. Reason: posted part of it in the wrong thread
Old Nov 17, 2012, 08:54 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Phoenix
3D Fixed Wing
No Password
keithy4129 is offline Find More Posts by keithy4129
Old Nov 17, 2012, 08:57 PM
Eganwp is offline
Find More Posts by Eganwp
Giant Scale 3D/IMAC & FPV
Eganwp's Avatar
Canada, AB, Calgary
Joined Feb 2008
Hey guys,
Been flying the Leadfeather 3D EPP Yak 55 coming on 4 years now. 2s indoor on 9x4.7, 3s outdoor 8x4DD is my favorite setup on the Tunigy 2730 1500kv (1600kv real). Mental power. Weighs the same as this crack yak. I just built my second one about 3 weeks ago as my 3.5 year old Yak was gettin beat up.
So my question is, Crack Yak or the new Crack Yak LITE? I'm going to be outdoor flying 90% of the time, so 3s will be my setup so 1750kv is a little out of the question most likely. In fact, I don't even think I'm going to replenish my 2s lipo array as many of my old rhinos are getting tired. I do fly 3s indoor at times on my Yak now and yes it's INSANITY but sooooo much fun lol. Is the EPP thinner on the Crack Yak LITE? Since I wont be trying to save every gram of weight that i could using 3s, I'm leaning towards the regular Crack Yak as it should be more durable, handle wind better and is better built for 3s setup than the LITE.
Thoughts for those who have owned both?
Eganwp is offline Find More Posts by Eganwp
Old Nov 17, 2012, 09:38 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
how do I calibrate the throttle ?
Old Nov 17, 2012, 11:30 PM
the beave is offline
Find More Posts by the beave
ward cleaver's boy...
the beave's Avatar
waco,texas
Joined May 2008
Before plugging your battery to the ESC, put your throttle all the way up. Turn your radio on then plugg your battery in. You should hear the ESC make its usual noise followed by a couple of short beeps. When you hear the two short beeps pull your throttle all the way down and the ESC should finish arming as usual , now the throttle should be calibrated.
the beave is offline Find More Posts by the beave
Old Nov 17, 2012, 11:31 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
can I do so AFTER I have flown the plane ?
Old Nov 17, 2012, 11:33 PM
the beave's Avatar
waco,texas
Joined May 2008
Yes..... Shouldn't matter when you do it.
Old Nov 17, 2012, 11:35 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
thanks, and I just found this tutorial video calibration
http://www.twistedhobbys.com/ESC-Twi...ESC-TH-12A.htm
Old Nov 17, 2012, 11:36 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
does this suppose to give more power to the engine than without calibration ?
Old Nov 17, 2012, 11:40 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
It might but not always. It will make the throttle curve more linear.
hone1er is offline Find More Posts by hone1er
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
