Old Nov 11, 2012, 11:01 PM
AirSurfer
TBone08's Avatar
Joined Sep 2011
what Amp Lipo setup you guys use (for charging the Twistedhobbies 450 mAh 2s1p) ?
TBone08 is offline Find More Posts by TBone08
Old Nov 11, 2012, 11:08 PM
Build... Fly... Repeat
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
charging batts on a Hi Tec X4 at 1.5 amps balanced... it"s a 5 amp per channel max charger...
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Latest blog entry: Insane upline on a crack yak
Old Nov 11, 2012, 11:13 PM
AirSurfer
TBone08's Avatar
Joined Sep 2011
for this bat I thought being 450 mAh then .45 or .9 ? not sure if the bat can handle it ?
Old Nov 11, 2012, 11:15 PM
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Twisted hobbies site says it can be charged at up to 5c or .45 x 5. I'd probably keep it to 3 or 4c though.
hone1er is online now Find More Posts by hone1er
Old Nov 12, 2012, 05:35 AM
Twisted Do Nut!
KamikazePilot's Avatar
Fort Worth
Joined Dec 2010
Originally Posted by ROLLING CIRCLE View Post
http://youtu.be/w1ahSrxdP4c
fwiw....this plane on 3S has the batt on top of the wing with about 3/4 of the batt in front of the spar... 450 mah gens ace 30c
Blue leds on a blue Yak, love it. Bet it lights up the night sky!
Though I have batts that are capable of charging at 5c I rarely do it. Thunder T6 with a paraboard works just fine for me.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Nov 12, 2012, 03:52 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
What is the best motor for the crack yak on 3s with an 8inch yellow tuff prop?
I need to upgrade mine.
Thanks.
jimbo320 is offline Find More Posts by jimbo320
Old Nov 12, 2012, 03:55 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
I know it's more $$ but if you invest in a four way charger you can charge at 1c and charge the battery in less that one hour, but do 4 at a time.
So effectively you are charging at 4c but not reducing the life of your batteries, as they are still charging at the optimum for prolonged life expectancy.
Old Nov 12, 2012, 04:02 PM
Twisted Do Nut!
Fort Worth
Joined Dec 2010
I run both motofly or the crack series motors now jimbo both handle 3s just fine.
That's why I went with the T6 charge 4 packs at 2c and you'll have them under half an hour. Or use the paraboard with 4 packs on it plus three other packs charging on the other ports.
Old Nov 12, 2012, 04:38 PM
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Thanks.
I see Mark has the X Series 1480kv motor back in stock. I'm not sure it's rated for 3S but I've been running them on it quite a lot and haven't had any problems. If we could get the 24g or 26g Crack Series motor I'd have said go for that but at least with the X Series motor you won't be changing your cog. Works well on 2S with a nine inch prop too but is more suited to indoor with very smooth throttling.
Aviefly is offline Find More Posts by Aviefly
Old Nov 12, 2012, 06:42 PM
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
I tested that motor on 3S and a 8x4.3 and it worked well.
cwojcik is online now Find More Posts by cwojcik
Old Nov 12, 2012, 07:02 PM
United States, LA, New Orleans
Joined Jan 2012
Well finally got a chance to maiden my first 3d foamie a crack yak and wow this thing goes where you point it. I finally understand what it means to power out of trouble. I think im going to enjoy this hobby a whole lot more now.
MountainMike is offline Find More Posts by MountainMike
Old Nov 13, 2012, 10:03 AM
Twisted Do Nut!
Fort Worth
Joined Dec 2010
Glad to hear you like the Yak Mike. Before you know it you'll have more.
The Crack Club is growing!
Old Nov 13, 2012, 12:14 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
Lots of crack heads about at the moment..
Old Nov 13, 2012, 04:33 PM
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Yes Indeed... lots of new faces (avatars) on the Twisted Hobby's Threads. Great to see, and for all the new members, welcome to the club.!! Feel free to post pictures and videos of your builds and flights, always nice to see how everybody does things a little differently... and most of all, if something does not make sense or you have a question, don't be afraid to ask..
cdee
cdee is offline Find More Posts by cdee
Old Nov 14, 2012, 09:43 AM
Twisted Do Nut!
Fort Worth
Joined Dec 2010
Yeah we need new pics and videos from the new guys. Going to get some video this weekend if the forecast holds up. Last weekend blew in so many ways!
cdee have you messed with the timing or start up on the new esc? Still trying to figure which is which with the sounds. Should have got the programming card last time I ordered. Will get it the next time I get some other stuff from TH.
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 521 Jun 12, 2013 08:06 PM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 992 May 31, 2013 03:19 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 178 Jan 02, 2013 11:05 PM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 76 Aug 30, 2012 12:08 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
