Old Nov 11, 2012, 01:49 PM
MountainMike is offline
Find More Posts by MountainMike
United States, LA, New Orleans
Joined Jan 2012
Well finally picked one up with power combo, got it all built and now 20mph winds. Waiting for a maiden soon.
MountainMike is offline Find More Posts by MountainMike
Old Nov 11, 2012, 01:57 PM
TBone08 is offline
Find More Posts by TBone08
AirSurfer
TBone08's Avatar
United States, VA, Arlington
Joined Sep 2011
I hear you. all I do the weekend in build, didnt get to fly yet...
TBone08 is offline Find More Posts by TBone08
Old Nov 11, 2012, 03:08 PM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
Finally nice out here in PA after Sandy. Flew another 4 batteries this afternoon. Was a bit windier then this morning. Had one tree incident where it took a bite out of the wing. I decided to keep flying and performance didn't seem to be hurt.
Found the chunk and just glued it back in place.
Just have to say it again, I love this plane!!!!
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Nov 11, 2012, 06:30 PM
Chris Arena is offline
Find More Posts by Chris Arena
oldguy
Gig Harbor, WA.
Joined Jul 2010
Warm vs cold weather foam expansion.
I went to fly my Crack Yak yesterday and when I turned it on to fly, I noticed that my elevator had about 1/8" of downtrim, the rudder and ailerons were also out of trim slightly. We have had a change in the weather over the last week and the temperature has dropped from about 60 degrees down to around 40. Could the weather have caused some expansion in the EPP foam? I have had a DW Hobbies 9 mm 40" extra for about the past year and a half and have never had this problem. This is my first EPP plane. Is this normal? No bigge, I love the model, but have never encountered this problem before.
Chris Arena is offline Find More Posts by Chris Arena
Old Nov 11, 2012, 06:43 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
where do I place the battery ?
I read that it suppose to be 8.5 cm from the leading edge but the photos show it on top of the wooden bar that crosses the wing ? maybe I missed something. your 2 cents appreciated.
also, does the number refer to the front part of the battery or the middle part ??
Old Nov 11, 2012, 06:50 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
This is normal for an EPP plane with long CF rods for Elevator and Rudder. Typically the ailerons are not affected do to the shorter control rods.
First flight of the day - check and readjust.
JC
ps - Make sure you always store the plane hanging from its prop in order to prevent warpage.
JC Spohr is offline Find More Posts by JC Spohr
Old Nov 11, 2012, 06:52 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
81.5 mm is the CG for this plane.
Put your plane on a balnce stand at that measurement and then place the battery on top of the wing next the fuselage to adjust CG. Mark the outline of the battery. Cut the hole about 2-3 mm smaller than the outline so it holds the battery in tight.
JC
Old Nov 11, 2012, 06:55 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
thanks. you mentioned 81.5: what are your thoughts about the written: "For totally neutral it is 3.25" or 82.55mm from the leading edge of the wing " ?
also, - backwards (from the place the front and inner part of the wing meets the fuselage) ?
Old Nov 11, 2012, 07:41 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Herc (Chris Jewett) designed the plane and I'd listen to him. I did. I'm flying the CY lite and he told me 81.5. My understanding is that this is the same CG for the non-lite version.
I doubt you will notice 1mm difference.
BTW - that measure is from the LE of the wing where it meets the horizontal fuselage.
JC
Old Nov 11, 2012, 08:23 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
What better source than the designer of the plane himself. I have my Yak setup at the recommended cg like JC and most other guys I know. Battery placement would be where the plane would be level at the cg mark. On mine I have it just ahead of the aileron servo. That’s with the standard power combo and no landing gear. Though I’ve seen others have it there or where Chris has his at the beginning of the build post.
Been awhile since I got a video here. So here's one from last weekend where the weather was playing nice with me. Unlike this weekend where the wind was throwing everything around.
Crack Yak (4 min 7 sec)
KamikazePilot is offline Find More Posts by KamikazePilot
Old Nov 11, 2012, 10:08 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
there's actualy over a CM between the two. the issue I'm having is that with the combo setup and no gear- the written CG (8.5) is bit behind the wooden wings enforcment, while on the CG machine with my setup, its balanced out when the battery is bit front of the ailerons (like mentioned earlier). there's like good 9 CM of difference.
Old Nov 11, 2012, 10:14 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Some people have had to put there battery ahead of the aileron servo while others ended up with the battery over the spar throughout the thread. It's a common thing. I guess it's the differences in the EPP between kits as well as how much glue is used.
Basically it doesn't matter where the battery actually ends up as long as the CG on the plane is correct.
Nice video Kamikaze. Is that a keychain cam?
hone1er is offline Find More Posts by hone1er
Old Nov 11, 2012, 10:18 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
thanks for the pointers guys. I guess then I'll just go by the CG machine set to designers recommendation - and place it where the plane keeps balance.
Old Nov 11, 2012, 10:33 PM
Twisted Do Nut!
Joined Dec 2010
Thanks, yeah it's the 808 #16 cam that Avie and Cdee mentioned on the Pitts thread, I got it after I was dissapointed with the Dicecam I got from Hobbypartz.
That's the best route to go. My cg machine is either my two index fingers or two dowels drilled into a block of wood with eraser caps on them. I'm cheap I know, but it works.
Old Nov 11, 2012, 10:41 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
GET YOUR CRACK YAK LIT UP INDOOR STYLE (2 min 57 sec)
fwiw....this plane on 3S has the batt on top of the wing with about 3/4 of the batt in front of the spar... 450 mah gens ace 30c
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Latest blog entry: The Crack Pitts - revisited :)
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
