Old Nov 11, 2012, 10:31 AM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Originally Posted by TBone08 View Post
thanks. theres no set rate from Twisted ?
Maybe and just maybe you could check the manual and maybe just maybe on page 18 you will find out what you are looking for.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Nov 11, 2012, 10:38 AM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
As much as you can get.
Then set your lower rate(s) from there.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Nov 11, 2012, 10:44 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
JC
What's that
JK I use lower rates on my balsa planes but for foamies i keep it in high rates all the time(which is as much throw as i can get with an expo that feels right to me)
hone1er is offline Find More Posts by hone1er
Old Nov 11, 2012, 10:52 AM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Originally Posted by hone1er View Post
What's that
LMAO
Those are the ones you set it to so other people can try your plane...
Old Nov 11, 2012, 11:12 AM
TBone08 is offline
Find More Posts by TBone08
AirSurfer
TBone08's Avatar
United States, VA, Arlington
Joined Sep 2011
great - the manual, didn't see it before.
I am having a problem with the build:
I place the metal part on the servo arm but the keeper does not hold the metal part in place...
how can I go about this ? does the metal part need to rotate or is kept in place at all time (aka. glue it...) ??
TBone08 is offline Find More Posts by TBone08
Old Nov 11, 2012, 11:24 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
It should be able to rotate so when the servo arm moves it won't bind.
Old Nov 11, 2012, 11:29 AM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Keeper required!
Make sure you are getting the keeper centered on the pin or it will not stay on.
Lick your finger tip and stick the keeper to it. Start the keeper by pushing it on the pin firmly. Not to hard or you will push the pin into your finger tip.
Finish the keeper using needle nose pliers to work it down snug with no play but still rotates.
JC
Old Nov 11, 2012, 11:31 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
thanks, is there a preffered side to push it unto ? (I see one side it more pointy than the other)
Old Nov 11, 2012, 11:34 AM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Pin goes into concave side. Cupped, not pointy side.
Sixinarow is offline Find More Posts by Sixinarow
Old Nov 11, 2012, 11:36 AM
cttrulson is offline
Find More Posts by cttrulson
United States, MN, Braham
Joined Jul 2011
The crown (pointy part) of the keeper must be facing away from the servo arm.
cttrulson is offline Find More Posts by cttrulson
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Pointy side away from the servo arm. If you stick the keeper to your finger like I suggested, then the pointy (convex) side will be stuck to your finger.
Old Nov 11, 2012, 11:59 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
yeh, and it feels real "good", too..
Old Nov 11, 2012, 12:01 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
bt.w I didnt get the wheels with the kit, is it not part of the kit anymore ?
Old Nov 11, 2012, 12:21 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
LG optional on the regular series.
The "Lite" series come with LG.
JC
Old Nov 11, 2012, 01:43 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
is all good, I don't plan to land at all...
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
