Old Sep 01, 2012, 08:57 AM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Originally Posted by RCAddict16 View Post
Stop crashing......
Crashes are inevitable while trying to do flips, knife edges, loops, inverted, 4 rolls in a row, with 8' tall stacks of banquet chairs as obstacles and some paper ball decorations limiting the flight ceiling to 15-20' and in a 60x100' room
Sixinarow is offline Find More Posts by Sixinarow
Old Sep 01, 2012, 08:59 AM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
Lol fly outside then
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Sep 01, 2012, 09:00 AM
Addicted
Joined Dec 2011
I usually do but yesterday was about 15 gusting 30. Nasty. I work 2.5 miles from APA's runway threshold. You know it's windy when a business jet is crabbing 10 degrees on final approach and can see the ailerons fighting to keep her aligned on the glideslope.
Old Sep 01, 2012, 09:40 AM
mikeumr is offline
Find More Posts by mikeumr
MVSA, St. Louis, MO
Joined Nov 2007
ESC problem with basically new Extra Slick
Please watch the demo of the problem below I do not know how to fix. I am not well versed in power systems, I'm a sailplane flyer mostly. Right from the start when this was brand new in the Spring 2012 I've had a problem where I get this up in the air and as soon as I start wiggling the sticks a little the prop cuts out. This happens on a fully charged battery. I have 2 Lipo's and it happens with both of them. As far as I can tell I've programmed the ESC properly for Lipo. The ESC is not labelled but came with the power system ordered through Twisted Hobbys.
https://vimeo.com/48649855
Any ideas? Please help, thanks!
mikeumr is offline Find More Posts by mikeumr
Old Sep 01, 2012, 09:46 AM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
How old are your batteries? If they are a bit old may want to try a new one. They could just be weaker. If that doesn't solve it I would contact brad and ship the esc back and have it checked out or replaced. Double check all the connections too if there is a loose one it may be trying to pull more current than is actually needed dragging the battery down. I had a similar issue on m Pitts and replacing the esc fixed it.
Aaeolien is offline Find More Posts by Aaeolien
Old Sep 01, 2012, 09:49 AM
Joined Apr 2012
That sounds like a cold joint in the motor or ESC. Send them to brad and he will fix them.
Old Sep 01, 2012, 09:54 AM
Aaeolien is offline
3d addict
Joined May 2011
Ok now that I've really watched the video. Definetly replacing the esc will fix that. Highly doubt it's the motor. I had a very similar issue with mine.
Old Sep 01, 2012, 10:02 AM
Logan4169 is offline
Find More Posts by Logan4169
Joined Nov 2011
Shouldn't there have been 2 beeps on start-up for a 2s battery?
Logan4169 is offline Find More Posts by Logan4169
Old Sep 01, 2012, 10:12 AM
Joined Nov 2011
Try to reset the ESC. Turn on the TX and go to full throttle, Then plug in the battery on the plane and wait for the beeps. Then throttle to zero. You should be good to go.
Old Sep 01, 2012, 11:12 AM
Twisted Realm is offline
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
mikeumr, its possible you have an older ESC which may be causing this issue. Give Twisted Hobbys a call or email, I have a feeling they can help.
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Sep 02, 2012, 05:03 AM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Looked out the window, flat calm. Took the crack to the park. It was blowing 10mph! Had one pack, hopeless. Back at the house, no wind! Aggg. Just my luck!
Btw what happened to rcaddict, he got himself suspended !
jimbo320 is offline Find More Posts by jimbo320
Old Sep 02, 2012, 06:27 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
I fly my Crack in 10mph wind on a daily basis
Kris... is offline Find More Posts by Kris...
Old Sep 02, 2012, 07:54 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
So do I, doesn't mean I like it tho!
Old Sep 02, 2012, 08:45 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
I have no choice its 10mph or no flying most of the time
Old Sep 02, 2012, 08:47 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Originally Posted by Nimbus Dave View Post
I believe you will be very pleased. The weight/power ratio seems to suit the Yak and Slick very well....good luck...cheers..
Tried the motor today was not unimpressed compared to the stock 1800kv it lacked grunt !
Took near WOT just to hover
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
