Old Jul 16, 2012, 09:38 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
As we saw...
Well thats good you got your electronics.
Nice flying dan!
Alex Schauer is offline Find More Posts by Alex Schauer
Old Jul 17, 2012, 12:17 AM
idkstall is offline
Find More Posts by idkstall
Joined Jul 2012
Is my motor getting too HOT.
Eflite 300, eflite 10-amp esc and a sky lipo 500mah 3cell 20c and 9X4.7
i caant even hold the motor for long, it smells after maby 1.5- 2 min of flight is it just the prop or the 3 cell or both thank for any and all help
idkstall is offline Find More Posts by idkstall
Old Jul 17, 2012, 12:23 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
If this is your motor http://www.e-fliterc.com/Products/De...rodID=EFLM1150
Then you should prop down. It says 8x3.8 is the biggest you should go on 3s you can use the 9'' prop on 2s only
hone1er is offline Find More Posts by hone1er
Old Jul 17, 2012, 07:21 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
On that motor, use a 8x4.3 with 3 cell, or a 9x4.7 on 2 cell. You are pushing it a bit too hard.
cwojcik is offline Find More Posts by cwojcik
Old Jul 17, 2012, 08:00 AM
Woody_99 is offline
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
Trim Change??
I've notice on the 1st couple of flights, after taking the plane from a cool basement and car to outside that my trim needs a lot of adjustment.
Usually the rudder needs significant amount and some elevator. Aile not much, if any, trim needed.
When I look at the rudder, I can see that it is offset some and follows the trim input I made.
After a few flights, I find myself slowly removing the trim I put in and elevator, rudder are back to neutral.
Feels like something to do with temp change. The other morning when I flew, trim didn't change at all, but in the evening when temperature differential is 30 degrees from home to field I see this happen. One thought was the servos centering, but I don't think that's it, since the trim moves the rudder from neutral to fly straight.
Does EPP change shape a little from cool to hot environments? In storage, I hang the CY by the prop so it should be straight.
I'm going to experiment by leaving the plane in a warmer area next time to see if I have to trim on the first flights. I recall someone else talking about this, but can't find the post. Curious as to what his resolution was, if any.
Any thoughts on this?
By the way, this plane is great! My first 3D foamy and a ton of fun!
Woody_99 is offline Find More Posts by Woody_99
Old Jul 17, 2012, 08:14 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
You came to the right conclusion it is tempreture change that causes it. There has been a lot of talk about it on the various threads.
Aviefly is offline Find More Posts by Aviefly
Old Jul 17, 2012, 08:17 AM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Mine does that, also. I have a habit of NOT hanging it vertically when not flying, so the surfaces droop a bit. Try hanging by the tail or motor (not the prop, as the prop saver band will stretch and fail).
I just flew mine 10 min ago in the loading dock before heading in to work.
Sixinarow is offline Find More Posts by Sixinarow
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Yep, the temperature change causes the foam to expand and contract (but the pushrods do not). This is what causes your trim changes. It's all part of the game with EPP foamies. Just-re-trim and fly!
Old Jul 17, 2012, 08:31 AM
Woody_99 is offline
Woody_99's Avatar
Joined Jan 2009
WOW, thanks for the quick feedback!
Good to hear that it's inherent to EPP and not something else wrong. I can deal with that. Probably easiest to hang it in the garage while charging batteries to let it equilibrate.
Thanks again!
Old Jul 17, 2012, 09:09 AM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
So should we keep our planes in the heat for a little before flying and then trim?
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Jul 17, 2012, 09:33 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
There's nothing you can do really...just fly it when you want it and trim it.
Hanging the plane by the prop is a good idea because it puts no stresses on the airplane that can twisted or warp it over time, but it's not an absolute necessity.
Old Jul 17, 2012, 09:54 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
foamie storage coming soon to a Twisted Hobbys' website near you..
http://www.twistedhobbys.com/VFS-System-VFS.htm
cdee
cdee is offline Find More Posts by cdee
Old Jul 17, 2012, 09:56 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
cdee
NICE Cdee!!!
Old Jul 17, 2012, 10:06 AM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
cdee
I saw that on the Twisted site a day or two ago - congrats!
May have to pick one up if Brad keeps feeding my addiction.
That will hold 32" and the larger 43" & 47" planes won't it?
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Jul 17, 2012, 10:13 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
JC
Yes... I have everything from a UMX Beast to a PA Addiction hanging from my VFS System...
cdee
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
