Old Jul 13, 2012, 08:01 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Speaking of Ron Dog has anyone seen anything of him? Not seen him around in ages
Aviefly is offline Find More Posts by Aviefly
Old Jul 13, 2012, 08:20 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Had a brief PM from him a couple days ago.
He's been indoors due to the heat plus the loss of his best friend still ways heavy on him.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Jul 13, 2012, 08:33 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
How long can you guys torque roll for? I think I hit about 6 seconds!
RCFS#40: Crack Yak Backyard TORQUE ROLLS! (1 min 57 sec)
Dan
DJO is offline Find More Posts by DJO
Old Jul 13, 2012, 08:36 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
http://www.youtube.com/watch?v=MlXdn1cjUKI
Dan
As long as I want to...
JC
ps - You're hover/torque rolls/pirouettes are much improved - nice job!
Old Jul 13, 2012, 08:37 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Originally Posted by Araya213 View Post
It works great, my buddy has the same radio, I haven't used mine yet. One thing I'm having trouble with is the throws. The Crack Yak manual says for sport flight (which I'm going to use to start out) to use 20 to 30 degrees of throw. I assume on the 7c that translates to endpoint adjustment, which can only be set in percentage. Am I correct in this? And if so, how do I go about converting the degrees into a percentage? And what is this a percentage of, 360 degrees or 180 or less? I'm sorry if the last couple of questions don't make any sense, I'm totally new to setting up this radio.
**EDIT** After using a formula I found online, I ended up with 41%, does that sound right or am I way off? This number comes as a result of assuming that I'm looking for a percentage of 180 degrees.
**DOUBLE EDIT** Nevermind, just RTFM and discovered that %100 percent equals roughly 40 degrees
You can use dual rates. Don't mess with the endpoints. You can tame down the rates with everything connected and the rx bound to the tx, and just keep turning the dial until you hit 40 degrees or whatever angle you desire. And assign it to a switch, (I frefer the triple switch) and you can have high rates (50deg) med(45 deg) and low rates (40 deg) or again whatever angle you want.
Alex Schauer is offline Find More Posts by Alex Schauer
Old Jul 13, 2012, 08:38 PM
Joined Feb 2011
JC
Show off
JK!
Old Jul 13, 2012, 08:43 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
See my blog post on measuring angles with a cheap tool from Home Depot.
http://www.rcgroups.com/forums/member.php?u=319558
Always setup your initial throws at MAXIMUM throw on the HIGHEST rate. Then use dual/triple rates for your lower throws.
Mine are typically setup for Triple rates as follows: Insane rate (max throws) / High rate (most 3D stuff) / Low rate (for precision flying).
JC
Joined Feb 2011
Same.
Old Jul 13, 2012, 08:49 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
JC
LOL... thanks! But what's a pirouette? Still a noob at plane 3D... go easy on me man!
Dan
Old Jul 13, 2012, 08:55 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Dan
When you're helping the torque roll by adding left aileron - usually full left aileron.
Torque roll is when you leave ailerons neutral and the motor "torque" causes the plane to slowly rotate left.
Hover is no rotation (requires that you feed right aileron to counteact torque effect.
You probably knew most of that but for those newcomers that read this later - there you go.
JC
Old Jul 13, 2012, 08:57 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Ah OK... it turns too slow for me if I don't help it out with the ailerons...
Dan
Old Jul 13, 2012, 09:00 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Dan
You'll get there - just takes lots of practice.
You're coming along quickly so it won't be long...
JC
Old Jul 13, 2012, 09:01 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
JC
Thanks! I just wish that I had access to a larger field more often. Because I really can't do much in my backyard, I have to be careful of all those stupid trees! LOL
Dan
Old Jul 13, 2012, 09:36 PM
Araya213 is offline
Find More Posts by Araya213
Joined Jul 2012
Originally Posted by jimbo320 View Post
I usually go for as much movement as possible!
This is pretty much exactly what I ended up doing, just setting them as much as I could without the servos binding and then backing off a bit and making sure the other side was pretty close to the same. Set dual rates, insane and candy-ass.
Maiden flight was great, but it didn't last long. I didn't crash it, but I had my CG all screwed up the first time I launched (forgot to check, just slapped a battery on the side to adjust subtrim and didn't move it back when I was done) and it flew real tail heavy. I brought it in for a nice soft landing and it still managed to rip a half inch slot under the motor mount, no big deal. Flew it around for 2 paks and then landed it to change batteries and the lower fuselage went ahead and finished ripping from the earlier spot to the bottom. Looked like someone took a bite out of it. I would expect the EPP to hold up way better than that, I was actually pretty proud of both landings because they were some of the better ones I've done, I think there might have been a fault in that spot. It's all patched up now but I had to bring it in for the night after 2 paks. It's a hell of a flyer, I'm not any good at 3D, still learning how to keep the thing in the air, so I'm pretty much limited to rolls, loops and snaps at this point. You guys weren't kidding about the rolls, this thing rolls fast! I spend a lot of time just doing that and being amazed at how agile the Crack Yak is. I was fighting some pretty decent wind so I had to switch to my wussy rate to get used to it at first, but it didn't take long before I was back to my high rate having a good time. I didn't crash it once, which is kind of a first for me. Going back for more in the morning!
I have a video, but the quality is crap and I kept the plane high most of the time so I could feel it out without danger. I'll post if if anyone cares to look.
Araya213 is offline Find More Posts by Araya213
Old Jul 13, 2012, 10:41 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Dan
You know you have reached true proficiency in 3D when you can stay on 3D harrier, Hover or T-roll as long as you desire. After that the doors of XA open up and the learning curve starts over..
hercdriver7777 is offline Find More Posts by hercdriver7777
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
